#26 | |
Re: Big Block in 4x4
I'll be using a internal hydro throwout bearing myself, (just because that's what my NV4500 requires), but even though the Novak kit looks like a quality setup I actually prefer facory parts when/if I can use 'em. Not because i think they're better but because if i happen to break something when I'm away from home I can usually find a replacement at the local parts store.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#27 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I haven't posted about my experience for several years so here goes:
When I put my BBC in, I also put a 700R4 in. I moved the motor crossmember about 2" forward. I would never move weight forward in my Camaro but in a 4x4 I don't really see what difference it makes. It won't be carving corners. This moved the motor away from the firewall enough so that no clearancing of the firewall was necessary. It also put the motor in about the same spot that a big block resides in a 2wd truck. So, the fan shroud and all of the bracketry for a 67-72 2wd truck goes right into the same places that it should. I somehow lucked out in that once all of this relocation was done, the transfer case shifter (NP205) came right up through the center of the hole in the hump right where it was supposed to. I had to have a rear driveshaft made for the truck but the front driveshaft required no modification. I had planned on changing the rear driveshaft anyway because I was changing from a Rockwell to a NP205. The entire affair was relatively painless (except lifting that 700R4 and NP205 into place!).
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" Last edited by breeh; 01-19-2007 at 02:27 AM. |
#28 |
Junior Member
![]() Join Date: Aug 2004
Thanks for all the input guys.
So if I put a 73&up crossmember will I eliminate the driveshaft issues as well as the clearance problems. ?
1972 Fleetside LB 4x4 |
#29 | |
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
#30 |
The 454 in my '72 K-20 was put in with very few mods...........They modified some SBC mounts, but kept the engine in the same location because the driveshafts/trans mounts weren't moved. The biggest problem they didn't take care of, was the fact they should have ran headers instead of the stock manifolds, because on the passengers side they had to cut a hair out of the frame flange on top. The distributor was just a hair away from the firewall, but no problems other wise.
I can take pictures of the mounts they mod'ed, because I promptly tore that BB out of there when I got it. ![]() ![]() ![]() ![]()
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
#31 |
Aluminum slot wheels rule...
TP, you had a 4-speed in that truck with the 454 right? What did the PO do about the clutch linkage? Is it modded or stock?
#32 | |
I've got a few pics if my setup.
#33 |
i've read a story once of a guy that got tired of making room on the firewall and bending sheetmetal to fill the gaps (think he builded stockcars for a living ) , he started using the bottom part of the steel bucket of a wheelbarrow cut to fit and welded intoo the firewall .... looked like factory stock and gave lots of room .
might just be an idea if nuttin else works
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#34 | |
Nothing extreme if you/or know someone who can weld, and to be honest, it looked like who ever did the one in mine was still learning, but it worked ![]() I know on that setup, a aftermarket distributor would have made room between it and the firewall, compared to that huge GM piece that was on it. Also, a pair of headers would have solved their frame grinding issue on the passengers side. But the way the truck looked, they made the swap years ago when parts weren't available from the aftermarket, so they mod'ed stock stuff to work.
#35 |
Thanks for the info TP. Appreciate it.
