Junior Member
![]() Join Date: Aug 2004
Big Block in 4x4
Need some input on putting a big block in a 72 4x4. I heard it was a pain, but would like to here from some of you who have done it. It would be an older 400.
Thanks Bill B
1972 Fleetside LB 4x4 |
Re: Big Block in 4x4
Clearance issues are in the future if you do it.You can move all the crossmembers forward but new d shafts will be needed.You could add a body lift,or take your favorite hammer to the firewall and make room
![]() I would modify the firewall if I was doing it as I hate body lifts and wouldnt want to move the motor and t case crossmembers forward and have longer d shafts made. Last edited by 1969k10stepside; 01-13-2007 at 01:22 AM. |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I had a 396 in my '71 which was an original 350 truck. The people that put it in didn't change anything, all they did was dent the firewall were the distributor is. You wouldn't have to do that if you get a distributor that is made for tight places.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Post Whore
![]() Join Date: Feb 2000
A guy over on www.ck5.com is dropping his motor 1 inch by using spacers to drop the engine crossmember - he states that is working for him. Be sure to check out my sig for more info on my bbc install pain.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
check out my sons suburban build we put a 502 in we purchased a universal cross member from summit it works good moved motor forward a couple inches not much 68 suburban buil thread
Junior Member
Thanks for all the input. That will help me out a bunch. I will post pics. of the project when I get around to it.
#7 | |
Now the valve covers...that was a different story.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
KEEP ON TRUCKIN'
You have the tall valve covers? Mine had the stock low covers on it. I have since taken the bigblock out and put a 350H.O. in it.
#9 | |
KEEP ON TRUCKIN'
That is tight!
#11 | |
Aluminum slot wheels rule...
I used a motor mount/cross member from an 80'. Also, used rest of drive train from 80' (3/4 ton). Using stock holes in frame for motor mounts...(added some to utilize all bolts on new cross member. Whole set-up ended up forward about 2". Had to extend 4-speed shifter hole a bit. 80' rear shaft too long anyway, so had it shortened to needed length. Front shaft no mods (slip-yoke). This was my first time, and If I had to do it again I would find stock mount/member. I still have very little clearance on valve covers, but lots on distributer.
#13 |
KEEP ON TRUCKIN'
No crossmember or driveshaft changes. When I put the smallblock back in I changed the fan shroud and the alt. and powersteering brackets. Whoever put the 396 in it left the small block stands in it and that made the header on the driverside rub the stands. Real tight header clearance.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() Last edited by Bishops Trucks; 01-16-2007 at 10:07 PM. |
#14 |
i had a 427 tall deck in my 1969 k10. a little clearencing the fire wall in valve cover area with BFH.i even ran the truck oil pan,it barely cleared the axle.i ran that old engine for about 15 years,until the truck fell apart.saved engine,junked truck.it would pull all i could haul on my trailer.i had more than one scary moment with them drum brakes.
#15 | |
Barring external size itself a BB will bolt into anything a SB will. No drivetrain mods required at all. The next time I have mine apart I'll be swapping to the 73-up crossmember. 4 reasons; 1. The 73-up style motor mounts are much better design than the older ones. 2. Now I have to unbolt the crossmember and slide it forward to remove the engine. (The newer one should eliminate this). 3. With the newer crossmember I can remove the oilpan without removing the crossmember. (Hope I don't have to do that though!) 4. Additional clearance for headers.
#16 | |
Post Whore
Small block dimensions 26 width 28 length 27 height 575lbs Big block dimensions 28 width 30½ length 29 height 685lbs That extra height and width cause the firewall issues for the 67-72's.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-17-2007 at 11:42 AM. |
#17 |
![]() Kinda hard to see the dent I made in the firewall so the driver's side valve cover would clear. The head it self is about 1/4" away from the sheetmetal. ![]() I started with a 73+ crossmember but then it cracked, I welded the crack but then decided my 454 needs more support under there so I changed to the ORD one: ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#18 | |
#19 |
Jake,your gonna kill yourself
#20 |
Hehehe, I know where theres a running 402 resonably cheap.
![]() Last edited by JAKES 68GMC; 01-17-2007 at 07:33 PM. |
#21 |
Dibs on the v6
#22 | |
Your dream come true! Better grab that 402!
#23 |
#24 | |
One problem....it's a 4 speed truck. That's a whole new bag of worms. Clearance and mounts are gravy issues, but the clutch linkage is sorta complicated. These trucks are designed to use the front pivot hole, (in the engine block) for the clutch Z bar. Since every BB manifold I've ever seen, (and headers too), cover up that pivot hole, you need to use the rear pivot hole in the block but yet retain the angle of the clutch pedal rod that goes through the firewall. I know of a couple guys that have moved the engine forward for this reason alone. Personally I'm not a "move it forward" kind of guy, so I fabbed up a linkage system that uses the rear pivot in the engine and retains the stock clutch rod angle going through the firewall. Before long I'm going to be swapping in a NV4500 5 sp and switching to hydraulic clutch release bearing though... ![]()
#25 | |
novak sells this kit: http://www.novak-adapt.com/catalog/kit_hcr3.htm its a bit cheaper than you usually have to fork out for factory hydro clutch parts (which probably need replaced after 20 or so years of use anyway), and kinda cool too.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
