#26 | |
Re: Strong Arms (tubular) vs. Stock A arm
Josh |
#27 |
Active Member
Some more info for you;
The CPP lower control arms come fully assembled on new 4130 billet shafts, patented non squeak bushings, and with the correct ball joints for year. These are designed to go as low as possible. The lowest part of the front suspension will be the U-bolt that goes around the cross shaft. The second lowest point is the cross member, the third lowest point will be the arm. This applies to both the coil spring and air bag control arms. Stay away from arms that lower your truck. They move the spring mount down. This means the arm is the lowest point; this lost ground clearance will limit how low the truck can go. Also stay away from any arm that uses a “rubber” spring isolator. In order for that to work you will loose precious ground clearance. The CPP upper control arms are made longer so that the truck can be easily aligned after it is lowered with coils or bags. These also come fully assembled on new 4130 shafts, patented non squeak bushings, and the correct ball joint for you year. Danny Nix CPP |
#28 |
thanks dan from CPP. Now what kind of discount do you offer to 67-72 board members?
![]() Last edited by jlaird; 02-29-2008 at 06:32 AM. |
#29 |
Active Member
We offer everyone a discount!!
![]() ![]() ![]() Send me a PM with what you are looking for. Danny Nix CPP |
#30 |
Tot Roddin'
Dan I've heard that other board members have had issues with receiving parts and overall poor customer relations... has this changed?
How do your products compare to ECE?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-29-2008 at 07:26 AM. |
#31 |
i just recieved my order from them, disc kit, coils, shocks, upper tubular control arms anf i had no prolems with them at all, now if i would have know about the deal!!!lol oh well
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#32 | |
Questionable
![]() Quote:
All in all, their service has been great - everyone has a bad day, and it's unfortunate, but it happens. Hell, the first part I ever ordered from ECE was their nice replacement tranny crossmember - and it arrived with one corner dinged in and a crack in the powdercoat (which I patched up). I'll be damned though - ECE's parts are great as are CPP's, and Mark and the other guys at ECE and the guys at CPP also are great, they all put out quality products (although, as with everyone, seems like everything is overpriced everywher eby ~20%, especially ECE with their $800 replacement gas tanks ![]() Ultimately, I bought CPP's tubular tranny crossmember to replace the ECE one, because I feel CPP's piece it's of better quality and fitment, IMO. They have their benefits - I like CPP's notch, ECE's shock relocation kit, CPP's tubular tranny crossmember, ART's tubular arms...unfortunately, no single manufacturer makes all the bomb-ass parts. I think it's all a matter of interpretation - and you know how it goes - one or two people have problems with an order, or gets a salesperson on a bad day, tells their friend, then they tell a forum online and all of a sudden....EVERYONE says they suck, and EVERYONE had a bad experience. Take everything with a grain of salt. And Dan - welcome to the forum. It's unfortunate that you came when you did, because if I'd have known there was any chance to get a discount through CPP, I'd possibly have ordered my tubular arms from them. I learned about your 67-87 related tubular suspension stuff via CCT, from the articles you guys did between Nov 2006 -January 2007. I actually just cracked those open tonight to re-learn how to install the notch I just bought from you guys. Can you tell me something - are your tubular arms setup and ready to go for bolting in airbags? The ones you installed in CCT had the lowers molded for springs, but there didn't seem to be provisions to bolt a bag to it.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 08:37 AM. |
#33 | |
I really don't get this logic so maybe you can shed some light. Someone that would buy a-arms that help lower their truck is going to be concerned w/clearances. The 'down-side' (pun intended) to lowering w/OE parts is that more shims are required to regain proper alignment. Those extra shims widen the track width which in turn reduces some of that clearance lowered vehicles need. If you're making arms from scratch anyway...... why not shorten the lower arms vs. lengthening the uppers? Shorter lower arms will keep the track width near stock or maybe even narrow it slightly, either way helps clearance issues. Just to be clear, I'm not picking on just CPP. Air-Ride did something similar. When their Strong-Arms first came out the lower a-arm shock mount was the lowest part of the arm...... meaning the first thing that would contact pavement. The explanation was that when these arms were prototyped, the truck used stock spindles so there was no issue w/the mount being too low. How many guys swap in an air suspension that aren't trying to get that sucker lowwwwwww?? One of the first & easiest ways to get low is using drop spindles. I know there's alot of guys w/older trucks that don't/won't swap to discs. But I'd being willing to bet there's more 'classic trucks' out there that do have discs & use drop spindles for lowering. Of course, ART's arms have now been revised to correct this 'flaw'.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-29-2008 at 09:34 AM. |
#34 | |
#35 | |
This would keep track width right around stock.
#36 |
Questionable
do the current ART tubular arms use the stock shock mounting hole on the framerail, or do they come with some kind of adapter to adjust/strengthen the shock mount?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#37 |
They come w/an adapter for the frame that raises/reinforces the top mounting location.
#38 |
Questionable
Drilling required? I know CPP arms showed the install as needing to extend the stock hole, weld a washer on the backside for stability, then install their adapter.
(trying to figure out if I need to get this done before frame goes off for blast & powdercoat)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-29-2008 at 11:11 AM. |
#39 | |
To answer somebody's question above, there are two versions of the CPP lowers, one with spring mount and one for an airbag. |
#40 | |
Formerly LSC71
#41 |
Tot Roddin'
Thanks for the shed of light on the subject Shifty. I figured that some orders might have had "outside influences" affect their outcome, but it's good to hear that you and several other members have had good luck with them. Their kits tend to be a little cheaper than ECE's so I didn't know how they could account for the cheaper price.
Danny (DKN) first off welcome to the board. It's good to have some of the top named distributors on the board. I bet you would receive quite a few orders from members if you became a board supporter. Don't feel like I was striking against CPP, because from what I've seen you sell some great products, heck Classic Parts of America sells quite a few. My build will suck every penny I have to put it together, like many other members, so I'm just looking for the best deal on price without sacrificing quality. Again welcome to the board!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-29-2008 at 06:26 PM. |
#42 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-29-2008 at 06:49 PM. |
#43 | |
Formerly LSC71
#44 |
Active Member
First I want to thank everyone for the warm welcome response. I will to try to answer as many of these questions as I can. If I miss one ask me again.
The shock mount in the magazine: The truck came to us with the frame damaged at both shock mounts. The welding was done only to repair the frame back to the original strength. The shock studs are available new. And the reinforcing bracket is our version of the bracket GM used on the 4 wheel drive shock mounts. We cleaned up the appearance a bit, but the true credit for the concept belongs to GM. The lower control arms are available in an air bag version, the rear trailing arms work with air bags or coils. We did not shorten the lower arms because there was a measurable difference in bump steer. There is a new spindle and brake kit shipping in the next couple of months. The spindle is a 2-1/2” drop that does not move the wheels out wider like every other drop spindle made. These are intended to be used with larger wheels that the OE 15 inch. The spindle does not have a caliper mount cast into itself. Instead there are 2 large mounting bosses that accept a caliper mounting bracket. We have 5 and 6 lugs hubs made from billet aluminum. The hubs are a little wider than a drum brake hub, but almost 1 inch narrower than factory disc brake. This new hub will pull the wheels in away from the fender. We have 13 inch rotors in stock now, and Wilwood should have finished their 14 and 16 rotor kits by the time these spindles ship. We also have the rear big brakes ready for these. These spindles will be available with all of the ball joint tapers to fit which ever year truck you have. So we have addressed the need to narrow up the front end a little differently, and you do not need to buy new arms to do it. If you have any other questions just ask. Danny Nix CPP |
#45 | |
Señor Member
Tony??
#46 |
Señor Member
Oops... too late. I got one of the first-run sets. Had to fix them myself.
#47 | |
What calipers? Is the rotor a spec made piece or off the shelf stuff that's machined for the truck 5x5/ 5x6.5 patterns? Solid, drilled, or multiple options? And the big question everyone always wants to know..... how much? Do you have to purchase an entire kit or are other options available? Makes sense. I just didn't think less that 1" would make a "measurable difference" but I'm glad you guys researched that fact.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-29-2008 at 11:59 PM. |
#48 |
Active Member
The CPP rotor is a CPP design. We use it in all of our 13 inch front and 12 inch rear. We make them with a different hub pilot hole and lug patterns for the various applications. We plan on offering the spindle by itself and in different kits. It will work with the factory disc and calipers; the caliper bracket for this is also in stock now.
As far as the cost I expect them to be close to the same price they are now. I can not tell you exactly how the Wilwood kits will be, that’s up to them. In the past when we complete a new spindle design we have sent 1 spindle to all of the brake manufactures who asked for one of them so that they can make their own brake kits. By the way this was on display at SEMA with different optional upgrades to the brakes. Danny Nix CPP |
#49 | |
#50 |
Daily Driver
nitrous...the equal opportunity destroyer. |
