Old 02-04-2007, 03:14 PM   #1
timzrides
timzrides's Avatar
Strong Arms (tubular) vs. Stock A arm
what's your opinion, when going with an air bag setup, are you having better luck with the stock arms or is the tubular upper and lower the way to go on a 1967-1972. in my case, who's going to see the tubular arms or is it money well spent to spend more.
thanks
timzrides is offline   Reply With Quote
Old 02-04-2007, 05:39 PM   #2
jimmydean
jimmydean's Avatar
Re: Strong Arms (tubular) vs. Stock A arm
It depends. Nobody will see them, but they are nice. If your stock arms are in good shape, then stick with them. If your just going with a basic bag setup, then stock arms work great.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-04-2007, 07:54 PM   #3
BigShoe24
True Addiction
BigShoe24's Avatar
My stock arms were in pretty bad shape, and who doesn't aftermarket
BigShoe24 is offline   Reply With Quote
Old 02-04-2007, 08:01 PM   #4
[ol'Blue]
[ol'Blue]'s Avatar
have pictures of your deflated?
[ol'Blue] is offline   Reply With Quote
Old 02-04-2007, 11:58 PM   #5
SCOTI
SCOTI's Avatar
ART's tubular arms offer revised geometry for the lower ride height vs. stock arms.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2007, 03:39 AM   #6
Raguemoe
Junior Member
Raguemoe's Avatar
Some pics of mine! ART Strong Arms & CPP Drop spindles. Stock crossmember 1/2" off ground with 20's.
Raguemoe is offline   Reply With Quote
Old 02-05-2007, 12:39 PM   #7
jimmydean
jimmydean's Avatar
I thought that was the case as well, but I wasn't 100% sure and I'm still not sure on how much.
I will be switching to tubular arms at some point, but I am torn between that and the C4 drop member. It comes down to performance/bling vs. low and laid out.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-05-2007, 01:02 PM   #8
b&a72
Active Member
b&a72's Avatar
Raguemoe that is a sick looking truck. What did you use for wheel well's?
b&a72 is offline   Reply With Quote
Old 02-05-2007, 01:37 PM   #9
craig@ridetech.com
Formerly LSC71
Adding the Strong Arms does give you 3 degees more caster than the factory set up. One more thing to consider if you are trying to decide what to do is if you are going to keep your factory arms and put all new bushings and balljoints in them it isn't much more to go ahead and get the tubular arms with all the new stuff already installed .
craig@ridetech.com is offline   Reply With Quote
Old 02-05-2007, 02:03 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Not trying to hijack the thread, but who has the best tubular A-arms for the money ?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-05-2007, 08:23 PM   #11
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Trailer Fenders.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 02-05-2007, 11:34 PM   #12
BigShoe24
True Addiction
BigShoe24's Avatar
Nice truck Rague, What kinda of bags are you running, and whats going on out back for suspension. Thanks bro
Old 02-06-2007, 03:21 AM   #13
Raguemoe
Junior Member
Raguemoe's Avatar
They are modified trailer fenders by Devious Custom. I believe the are Firestone bags all around. Here are some pics of the rear 3-link!
Old 02-06-2007, 12:50 PM   #14
Tony@AirRideTech
Junior Member
Dude.. install and fab work look great! My only suggestion would be to upgrade to the new Kevlar sleeved bungee straps. With the original bungee I think you will notice wear thru and fatigue issues.....
Tony@AirRideTech is offline   Reply With Quote
Old 03-01-2007, 01:02 AM   #15
Big Ants71
Big Ants71's Avatar
RAGUEMOE what kind of hood hinges are those? I'm having clearance problems
with my 20"
BIG ANTS 71
Big Ants71 is offline   Reply With Quote
Old 03-01-2007, 01:49 AM   #16
Raguemoe
Junior Member
Raguemoe's Avatar
They are Mercedes hinges (very strong-no side movement).
Old 03-01-2007, 01:37 PM   #17
XXL
Señor Member
XXL's Avatar
I'm not so sure we want to see his "deflated"
XXL is offline   Reply With Quote
Old 02-27-2008, 09:54 AM   #18
shifty
Questionable
shifty's Avatar
Another question to ask may be, "who makes tubular arms that use the stock 73-87 balljoints?"
At least - after mulling over the comment above (and researching to find) that it'll cost me $250-300 to buy replacement bushings, etc. and I'm going to hafta pay $50/ea pair to have my arms sandblasted and coated...it almost makes more sense just to spend the add'l $300 and get tubulars all the way around. I found that Godfather Customs here in town has the DJM 73-87 tubulars for around $600 out the door (with 10% off, no tax and free shipping, if possible.
Sorry for the year-old post bump, but I just haaated seeing questions go unanswered
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-27-2008, 05:11 PM   #19
jlaird
jlaird's Avatar
At least - after mulling over the comment above (and researching to find) that it'll cost me $250-300 to buy replacement bushings, etc. and I'm going to hafta pay $50/ea pair to have my arms sandblasted and coated...it almost makes more sense just to spend the add'l $200 and get tubulars all the way around. I found that Godfather Customs here in town has the DJM 73-87 tubulars for around $550 out the door.
DJM has good prices but the lowers are setup for a spring and not a bag.
jlaird is offline   Reply With Quote
Old 02-27-2008, 05:42 PM   #20
craig@ridetech.com
Formerly LSC71
[QUOTE=shifty;2598188]......
QUOTE]
The Air Ride Technologies tubular arms use the stock size ball joints. You can order them for any year truck 63-87 and they will have the correct ball joint combo for your year, or you can order the 73-87 set up for those spindles if you wanted to put the factory style disc brake kit on the front of your 68 for example. We use the 73-87 style of upper and lower cross shafts that allow them to fit all of those years with the ability to interchange the different ball joints in the same control arm. You can pretty much come up with any combo for those trucks and still make it work. If you guys have any more specific questions feel free to give me a call. My name is Craig, my direct line at Air Ride Tech. is 812-481-4707
Old 02-27-2008, 09:57 PM   #21
shifty
Questionable
shifty's Avatar
i have a less specific question: where can i get a 20% discount coupon? i'm working on a hell of a budget
Old 02-27-2008, 10:50 PM   #22
craig@ridetech.com
Formerly LSC71
Check with some of our dealers. Sometimes you can negotiate a deal with one of them.
Old 02-28-2008, 12:13 AM   #23
PBFAB.COM
PBFAB.COM's Avatar
I know where you can get 5%
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-28-2008, 12:19 AM   #24
craig@ridetech.com
Formerly LSC71
I didn't think it would take Nathan too long to catch that.
Old 02-28-2008, 12:19 AM   #25
shifty
Questionable
shifty's Avatar
10% + free shipping and you got a deal
Paypal or otherwise, I'm all fired up and ready to go
