Old 02-13-2007, 12:24 AM   #26
scoot
scoot's Avatar
Re: Cargo 3rd light LED interest?
didn't 3rd brake lights go out of style in 95?
scoot is offline   Reply With Quote
Old 02-13-2007, 11:22 AM   #27
C3500
yeah what he said
C3500 is offline   Reply With Quote
Old 10-06-2007, 06:34 PM   #28
svgould
Active Member
svgould's Avatar
Any updates on this?
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 10-06-2007, 08:33 PM   #29
Musclerodz
The supplier I was originally hoping to use, has put this on the backburner for another projects unless I wanted to buy say oh.....a thousand of them. i picked another LED manufacturer last week and I will be able to get them made through him. Not sure at the cost though, I am hoping very reasonable so not to alienate to many customers on a budget. Anyways, he will also be doing full panel LED's exclusively for us as well. Stay tuned........
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 10-09-2007, 04:10 AM   #30
gringoloco
A guy with a truck
gringoloco's Avatar
As leverage to get the guy to produce them, they are the same thing as Camaro back-up lights. He could sell a few more that way I'm sure.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-09-2007, 10:53 AM   #31
Musclerodz
First gen? STD or RS?
Mike
Mike Redpath
Old 10-09-2007, 02:51 PM   #32
gringoloco
A guy with a truck
gringoloco's Avatar
Pretty sure it's 67-69, but not 100%. I know from the factory, GM used both left and right assemblies, because some of them have the wiring exiting towards the passenger side.
EDIT: I found the answer here on the board. '69 RS
-Chris
Old 10-10-2007, 02:51 PM   #33
magsnubby
magsnubby's Avatar
I converted the cargo light on my '71 to a third brake light using mostly junk yard parts. Pretty simple job really if all you want is a third brake light and don't want to keep the cargo light.
I used (i think because it's been awhile) JB WELD to attach the new socket to the Chevy housing. Then scrounged the van section of the local Pick-A-Part until i found a lenses i could cut down and used some black silicone to make a gasket. You could check your local hobby shop for some red lexan to use for a lenses. I used the original cargo light wiring, one for a ground and ran one to the brake light switch so it would be separate from the brake lights.
Dave at Early Classic Enterprises seemed to like it so i guess it wasn't to redneck.
magsnubby is offline   Reply With Quote
