03-18-2007, 11:40 AM | #26 |
Re: 1972 8"lift I got questions?????
Here they are, Don't mind the front driveline, I need to pull it and have it lengthend.
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
03-19-2007, 07:00 AM | #27 |
What a hunk! I love`um like that.What wheels are thosr?Nice.
03-19-2007, 08:02 AM | #28 |
They are called 41 40 offroad, They are 17x10. I bought them at les schwab in town. They are so easy to keep clean. I'm still waiting for the front to settle, If you look just right the front tires sit a little far forward. They told me it would settle out. I hope!!!!
03-19-2007, 10:01 AM | #29 |
I did see that.Heck,alot of guys move them forward for clearance(mostly on`Yotas,I believe).Now,if they`ll settle,will you figure that in to your front shaft length?(a bit?)What`s it gonna take to settle those springs?Can we get a close-up of a wheel?One more question...what size and brand tires are those?( 2 Qs in one)
03-20-2007, 01:01 AM | #30 |
Toyo M/T 37/13.50/17 try to get pics when the dust settles. Just got the wifes new project home 68 camaro, and trying to get the 70 done for a show this weekend.
03-20-2007, 06:33 AM | #31 |
Good things are worth waiting for.
03-20-2007, 09:18 PM | #32 |
Chevys Kick A$$
Looks great to me!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
03-20-2007, 10:59 PM | #33 |
Looks great, The only problem is mine looks like a low rider with its 4" lift.
03-22-2007, 08:21 PM | #34 |
Problem Child
Awesome
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 I Survived Norwood |
03-23-2007, 08:59 AM | #35 |
Post Whore
Looks good to me. You could always move your front spring center pins if they don't settle enough and the axle being forward bugs you. That or a ORD Zero Rate would shift it back. Will your front driveshaft handle the angle it is at?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-23-2007, 09:29 AM | #36 |
Why on God's green earth would you need 8" for 37" tires? Although honestly, it looks like your wheels are a bit fwd in the openings. Are you using stock spring mount locations?
I had my 70 LWB springs re-arched and 2" add a leaf, and with the slightest bit of contouring, 35" tires should be no problem. for 37" tires, a 6" lift should be plenty. There is one spot on the front of the front wheel opening where the edge comes off the radius to make a tangent line straight down. If you form that to continue the curve, you could probably do it with a 4" lift, and probably have room to spare without doing anything really noticable. Less cool, but easier would be to remove the bottom 2" of the lower fender from the wheel opening fwd to the bumper. Does anyone have pix of lift/tire combos? Particularly front wheel closeups?
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. Last edited by martinkh; 03-23-2007 at 09:37 AM. |
03-23-2007, 09:44 PM | #37 |
I figured out why the wheels are forward, Superlift put the shims on bakwards! So the springs need to do the flip flop.
03-24-2007, 07:06 AM | #38 |
Silly Superlift
So,does that throw your pinion angle down,giving your shaft that horse with a hard...you know....look?
03-24-2007, 07:19 AM | #39 | |
*37" tires require that much lift to clear factory sheetmetal if you want full range of articulation. *35" will rub a bit with 6" lift on one off my`72s and that`s just on road driving.I have 37s I`ll run,but I know I`ll need to be careful. *Most guys don`t like to go hackin`up fenders,unless it`s a dedicated trail rig. *There`s a "Sticky" @ the top to answer your last question.Check it out. *I`ve run 37" rubber with a 4" lift.I cut both ends of the front wells and the leading edge off the rear well.
03-25-2007, 12:55 AM | #40 | ||
03-25-2007, 09:41 AM | #41 |
I think the front fender opening can be re-contoured w/out hacking, but I know you were just using a figure of speech.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
03-25-2007, 10:25 AM | #42 |
Hacking,aka:altering.Yeah,proper metal working techniques hardly qualify as hacking.
Jason.I have 10" rims and Ez-Ride springs.I`ve heard them lightly rub cutting into an uphill turn-out.I`ll be running 37s with care.Are you talking about with a motor installed and driving or as it is,now?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-25-2007 at 10:27 AM. |
03-25-2007, 12:20 PM | #43 |
Tire width rim width and size is all facters in it and the look you want. I'm sick of guys judging everybodys lifts and etc. It's all in the owners choice.I put 8" because I use this truck to go get fire wood cutting and I take it hunting in some places guys would not take a jeep! But I love this truck I don't want to bash on it. I would love to restore it someday, since I'm the 2nd owner!!
03-25-2007, 02:05 PM | #44 |
You need a faded blue hood.Black hoods are dumb.
03-25-2007, 06:22 PM | #45 | |
03-27-2007, 12:19 AM | #46 |
hey guys,
does anyone have a part number for a longer parking brake cable (about 10 or 12 inches longer) or is there another way to get them back on |
03-27-2007, 06:26 AM | #47 |
www.inlinetube.com call and tell them how long you want.With a 6" lift,I added 5" which was plenty.
03-27-2007, 06:56 AM | #48 | |
Putting add-a-leafs on rearched springs would no doubt allow for 35's cause your overall flex is going to be minimal with that set up. |
03-27-2007, 08:12 AM | #49 |
K It is a faded blue hood, It just has black primer over it to protect the faded blue, from leaving forever!!!!!!!
03-27-2007, 10:11 PM | #50 |
OK,so it`s a custom flip-flop fade-out paint job with black primer over the faded blue up front and faded blue over the black primer in the rear.Now I dig it!
