Old 05-10-2007, 04:13 AM   #26
crossy
Oh,you can't buy that new
crossy's Avatar
Re: which trucks have the double hump crossmember?
Originally Posted by bigblock73 View Post
Eric, the early to mid 70's trucks had them, regardless of engine/suspension setups. I want to say 73-76. My '73 1/2 ton 350 equipped truck has one.
yep, they got rid of em when cats came along, thats why only heavy series trucks,over 8600lbs. had them after that, 9no emissions required).
Slonaker mentioned the taller frames. I never really saw a need for the upper piece (brace)and that is the only thing different on 3/4 or 1 tons because they are longer for the taller frame.
A Good source is dead diesel trucks and there are plenty of those around.
If the bolts are original they shoould be 7/16 diameter with a 5/8 head but i've unbolted a lot that had only the 3/8 bots with 9/16 head.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 05-10-2007, 09:14 AM   #27
jseifert
Originally Posted by N2TRUX View Post
That was my solution...
Did you buy or fab that???
That is exactly what I need!!
jseifert is offline   Reply With Quote
Old 05-10-2007, 09:39 AM   #28
bigblock73
yeller
bigblock73's Avatar
Both, He paid to have it fabricated.
bigblock73 is offline   Reply With Quote
Old 05-10-2007, 05:49 PM   #29
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
thanks Slonaker for posting the link. I was about to post that. I did not run the supports for about 5 years and it was a 454/4 speed truck that I didn't mind abusing... OFTEN. They are overkill, I only put them on there because I had the opportunity.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-10-2007, 06:05 PM   #30
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I hesitated putting the link up because it uses your bandwidth. I didn't want to put it on my site since it is your photo. I compromised by using a link rather than inlining it. I figured it was probably okay since you were inlining it in other threads on the topic...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-10-2007, 09:48 PM   #31
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Those top bolts for the side brackets are a really big pain. You have to pry up on the cab floor to get them in and out. I will try and get the picture up friday.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 05-10-2007, 11:47 PM   #32
jseifert
so let me change my question around a little bit...
"Where can I get it from????"
and for what kind of price...
Old 05-11-2007, 07:40 AM   #33
bigblock73
yeller
bigblock73's Avatar
Really? The bolts on mine came up from the bottom...so I simply put a wrench on the nut (top of the frame), and loosened the bolts from underneath.
Old 05-11-2007, 08:11 AM   #34
bb1979
bb1979's Avatar
The other option if the bolts head is on top of the frame is to undo the cab mounts and lift the body about an inch. Thats how I did mine when i swapped from a granny 4 speed to a Turbo 400
bb1979 is offline   Reply With Quote
Old 05-11-2007, 10:12 AM   #35
neverfinished
Mine were easy enough to get to without messing with the cab floor. I put washers and nuts on them to keep them from rattling around until I could figure out what they were for. The angled brackets don't look they would be much trouble to put in using an air ratchet on the bottom side.
neverfinished is offline   Reply With Quote
Old 05-11-2007, 03:03 PM   #36
Captkaos
Captkaos's Avatar
73-75 pickups 1/2T- up (maybe 76, can't remember)
76-up 3/4T up pickups.
How much, it really depends. $75?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-12-2007, 01:45 PM   #37
Yankeelights
Yankeelights's Avatar
Where did you get "these & those?" I have the non-double-hump cross member and I just don't feel like scrounging around for another crossmember at this point in time, but I am considering dual exhaust with headers.
I wouldn't mind seeing the photos of the install so I can see how you used the offsets.
~ Dave
[QUOTE=Ivan D.;2163907]You don't need no double hump, what you need are these:
and a pair of these:
Yankeelights is offline   Reply With Quote
