05-07-2007, 11:59 PM | #1 |
Garage Queen Material
which trucks have the double hump crossmember?
simple question
any idea on which trucks have the double hump tranny cross member? i'm thinking or redoing my exhaust with one to make it flow a little better |
05-08-2007, 12:07 AM | #2 |
Re: which trucks have the double hump crossmember?
I had a 72 with TH350, that used the double hoop trans crossmember.
1970 long fleet, 355 4 speed, primer, walnut goodies |
05-08-2007, 12:14 AM | #3 |
05-08-2007, 02:16 AM | #4 |
glamoros piece o' lowlife
You don't need no double hump, what you need are these:
and a pair of these: and you're good. Oh, and some heat insulating stuff for the speedo cable, or yer ruck will smell like burnt rubber for quite some time (guess how I know). Pics of the setup tomorrow, too tired now after installing it for over four hours...
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
05-08-2007, 03:12 AM | #5 |
BAD BOW-Silverado XST
3/4 tons and 1 tons have the dual hump crossmember. Look for trucks with a BB or 350 SB with a 400th tranny.
I have a custom made cross member. However, i'm not sure how well it will hold up to the new engine. |
05-08-2007, 06:48 AM | #6 |
yeller
Eric, the early to mid 70's trucks had them, regardless of engine/suspension setups. I want to say 73-76. My '73 1/2 ton 350 equipped truck has one.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-08-2007, 06:50 AM | #7 |
yeller
Your crossmember will be fine no matter what engine you have installed.
05-08-2007, 08:01 AM | #8 |
paper or plastic?
I got one out of a 78' suburban 454/th400
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
05-08-2007, 09:14 AM | #9 | |
Insert Witty Text Here
When I was looking for one a couple of months ago, it looked like 3/4 and 1 tons had a taller frame. If you used all of the parts of a double hump crossmember, I don't think the brackets that mont to the upper part of the frame would reach. I don't know this for sure. It was just my observation. I got my double hump crossmember off a late 70s BIG 10 or Heavy Half. I don't remember which one it was. Slonaker |
05-08-2007, 10:16 AM | #10 |
ya'll know what size bolts hold it on??? incase i want to go to the junk yard?
05-08-2007, 02:29 PM | #11 |
I probably should have done that with mine but I didn't feel like hunting down a cross member.
The ultimate would be to fab up a tubular cross member if you or someone you knew could weld. |
05-08-2007, 05:32 PM | #12 |
Chris
Can someone post a pic of the said double hump crossmember?
if it's what I'm thinking of the 86 4x4 1/2 ton we had, had the double one on it, with a 700r4 and 208 t-case.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
05-08-2007, 09:16 PM | #13 |
My '74 C20 has one.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
05-09-2007, 12:41 AM | #14 |
Happy to be here
That was my solution...
05-09-2007, 01:08 AM | #15 |
alright, i need some plans on that so i can get it built myself. come on i know you got some measurements on what i need to do!
05-09-2007, 01:37 AM | #16 |
05-09-2007, 08:28 AM | #17 |
my exhaust runs above my trans crossmember, I have had dual 3" and no have dual 2.5"
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
05-09-2007, 09:35 AM | #18 |
I see that you have the cross member bolted into the top of the frame as well as the bottom, is there an OE cross member that bolts in the same way? I ask because I have a set of bolts hanging in that same spot with nothing attached to them. My cross member sits inside the frame and is only bolted to the bottom of the frame.
05-09-2007, 09:46 AM | #19 |
http://www.speedwaymotors.com/p/4219...temNo=91628903
Something like that should work if you want to make your own, assuming it is wide enough. Slonaker |
05-09-2007, 09:49 AM | #20 | |
EDIT: This is Capt Kaos's doublehump crossmember (top of photo) with the extra legs in place: http://www.captkaoscustoms.com/images/framecross3.jpg Slonaker Last edited by Slonaker; 05-09-2007 at 09:56 AM. Reason: added link to website |
05-09-2007, 10:41 AM | #21 | |
Great, one more thing for me to fix. |
05-09-2007, 11:18 AM | #22 | |
05-09-2007, 01:23 PM | #23 |
Low & Fast!
Here is what I got. I had to change it a bit to make it fit. but should work good.
http://www.*****************/S10CarrierBearing.php
05-09-2007, 02:06 PM | #24 |
In one of the doublehump crossmember threads, CaptKaos said he ran one without the extra braces behind a big block for several years without any problems. You will probably be fine without them.
Slonaker |
05-10-2007, 02:40 AM | #25 |
Right turn Clyde
The braces are a little over kill but to each his own. I can post a picture of mine tommorow.
Ivan D. Have any part numbers for those exhaust parts?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
