Old 05-18-2007, 02:03 PM   #26
thekid54
Re: Need underhood pics of bagged trucks
jjk3 and Raguemoe, thanks for tracking down the info on those MB hinges, those just may be what I need on my truck!
thekid54 is offline   Reply With Quote
Old 05-18-2007, 08:42 PM   #27
1LoC10
Insert Title Here
1LoC10's Avatar
do those hinges hold the hood up, or do you need a prop rod
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-22-2007, 11:02 PM   #28
jjk3
It's just a check engine lamp.
jjk3's Avatar
Stock (for the CLK) there is a small shock on each hinge. You can see the small ball mounts on the upper and lower part of the hinges. As for this application, you'd have to ask Raguemoe what worked for him. John
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
Old 05-23-2007, 02:17 AM   #29
Raguemoe
Junior Member
Raguemoe's Avatar
Just the hinges-no hood prop! I use my head or a broomstick!
Raguemoe is offline   Reply With Quote
Old 05-23-2007, 11:09 AM   #30
bad_burb
bad_burb's Avatar
So it seems the consensus is trailer fenders or no inner fenders. Is the any other options people are using?
'73 C-30 3+3 Dually 454/TH400
'74 Fleetside 350/TH350 (SOLD)
'69 Nova 350/TH350 (project FOR SALE)
'63 Nova 305/TH350 3.73 posi (the wife's project)
bad_burb is offline   Reply With Quote
Old 05-23-2007, 01:06 PM   #31
BigTruckDriver
BigTruckDriver's Avatar
I am thinking of using the race tubs to fill areas that I will cut out for tire clearance. Either that or going to the junk yard and getting some spare fender wells and and piece them in. If I decide to use the full race tubs I was thinking of cutting and pulling in the center to make them look better and free up some unused space in the tire well. I like the idea of a enclosed look,no dirt water flying up into the engine compartment. I think the only reason people use the trailer fenders because its the easiest .
BigTruckDriver is offline   Reply With Quote
Old 05-23-2007, 04:17 PM   #32
randomhero472
randomhero472's Avatar
i've got a question, you guys running a 20" front wheel and just a bolt in bag setup, would the tire touch the stock inner fender before the front was fully aired out??
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 05-23-2007, 05:03 PM   #33
SCOTI
SCOTI's Avatar
Don't forget.... they look clean when installed (*if done properly).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-23-2007, 05:03 PM   #34
SCOTI
SCOTI's Avatar
If it's tall enough (+ 27"). . ..... yes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-23-2007, 08:05 PM   #35
randomhero472
yes it will touch or yes it'll clear?
Old 05-23-2007, 08:30 PM   #36
PBFAB.COM
PBFAB.COM's Avatar
It will TOUCH.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-23-2007, 08:48 PM   #37
SCOTI
SCOTI's Avatar
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-23-2007, 11:11 PM   #38
randomhero472
Originally Posted by porterbuilt View Post
It will TOUCH.
well ****.. how much drop will i be losing by keeping them in there, and whats the easiest thing to do, take em out and weld in some trailer fenders??
Old 05-23-2007, 11:35 PM   #39
SCOTI
SCOTI's Avatar
The easiest thing to do is take them out & stop there (the hard part is finishing the job).
I like sectioned/raised stock wells best but that's a bunch o' work. The trailer fenders would be next; & then race style wheel tubs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-23-2007, 11:43 PM   #40
randomhero472
what are the real draw backs to not having the fender wells.. this truck wont see much rain ect.. but want to keep a clean-shaved look under the hood, and am unsure if not having inner fenders will mess that up
Old 05-23-2007, 11:57 PM   #41
smbrouss70
smbrouss70's Avatar
rocks thrown up into the underside of the hood, causing dents
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-23-2007, 11:58 PM   #42
SCOTI
SCOTI's Avatar
D I R T.... (alot of it) & rock chips from stuff slung from the tires.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-25-2012, 03:49 PM   #43
ramega
ramega's Avatar
hey there can you gett those hood hinges ? and do they work with stock fenders?
ramega is offline   Reply With Quote
