#26 | |
Grand PooBaa Member
Re: Wheel Backspacing
Yes its the offset. My offset on my 15x10's was 6 1/2 inches toward the front of the rim. My lip was 4 inches. I did not want to tub my truck. Again at the Swapmeet yesterday, nobody had 10's with the right offset or right price. |
#27 |
You guys are getting offset and backspacing confused. Offset is measured in inches positive or negative from the centerline of the wheel. If you offset was 6 1/2 toward the front, you would have to be running around 15 x 15 wheel. I think you mean backspace which is measured from the rear lip of the wheel to the inner center that touches the drum also known as the mounting surface. Want to help you guys get this straight because if you talk to someone that knows wheels, they won't be able to help you because you won't be giving them the correct measurement!
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque |
#28 |
Why will or why won't a wheel spacer work? In my case a 1" in the rear would be good. running a 20x8.5 with 5.4 backspacing.
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
#29 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-11-2007 at 11:28 PM. |
#30 |
Active Member
![]() Join Date: Dec 2004
A spacer is a hunk of metal that goes between the wheel and hub, using the existing studs. They are not recommended over a 1/4 inch or so for the reasons stated above. They are commonly used to solve problems of interference between a hub and wheel. They sell for around $8 a pair.
Billet adapters are thick pieces of aluminum that are drilled to your existing bolt pattern, and have new studs mounted in them, either in the same bolt pattern or a different bolt pattern. They mount to your existing studs with nuts, then your wheels mount to the new studs like they normally would. They are most commonly used to change bolt patterns when you want to run a wheel that isn't made with your existing pattern, or to mount wheels that have a drastically different offset than your factory wheels, such as Corvette wheels on an old truck. Because of the way they work, they can't be manufactured less than 1" thick, so sometimes people that are trying to change bolt patterns run into trouble because the adapter is now pushing the wheel out an extra inch towards the outside of the vehicle. Aluminum adapters start out around $80 for a pair, and large ones for things like Corvette wheels can run up to $200 each. Spacer: ![]() Adapter: ![]() It gets more confusing when people call adapters with the same bolt pattern on both sides "spacers", as I found in my Google image search.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
#31 |
put me in line for 10 in. ralleys if you decide to sell. thanks
#32 |
The adaptor is the way to go then. Are these a safe alturnitive?
#33 | |
Grand PooBaa Member
Now why would you need adapters or spacers on rims that are 20x8.5? |
#34 |
the rims are 20x8.5 with 5.4 backspacing. I don't know this for sure but the wheels my sit real far in the fender wells. anybody have some pics of this situation?
