Old 07-19-2007, 11:39 AM   #26
edflores
Re: Air Ride
if you wanna show off, do the viair 480's with at least 1/2 inch line. 200 psi compared to 150 is a big difference. if you dont care about speed, run one of the manifolds that kp carries. you may want an engine driven comp if you play a lot. that would be faster than any electric compressor out there.
edflores is offline   Reply With Quote
Old 07-19-2007, 07:40 PM   #27
Gimix
Gimix's Avatar
Re: Air Ride
What do you mean by show off? what would you recommend running for someone who just wants it to look good(slammed), be quite, and ride well?
Travis
72 short bed Fleet side
Gimix is offline   Reply With Quote
Old 07-19-2007, 10:08 PM   #28
culookn
culookn's Avatar
Re: Air Ride
i would jsut piece a kit together b/c you often get a better quality/faster setup
culookn is offline   Reply With Quote
Old 07-20-2007, 04:04 PM   #29
edflores
Re: Air Ride
show off like snap your front up quick hit side to side etc. if you just want to look good, go with a setup like the one kp(Kontrol Phreaks) suggested bt maybe add some mufflers on the dumps to give you better control and quiet it down a little
Old 07-20-2007, 09:43 PM   #30
Gimix
Gimix's Avatar
Re: Air Ride
That's what I thought. To much for me
Travis
Old 09-12-2007, 03:04 PM   #31
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Air Ride
Originally Posted by Kontrol Phreaks View Post
You'll still need to run an upper mount to locate the bag, but the lower
doesn't require a cup since the bag bolts directly to the lower control arm.
Is this for all bags? I'm wanting to remove my cups (Tall) and I was considering
going to the short ones, but if LCA's require no cups? I wanna go that route
*Edit: BTW, How much lower will I get from just that 1", 2", maybe even 3" ???
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
