Old 06-26-2007, 10:42 PM   #1
hyde
hyde's Avatar
Air Ride
Guys what kits are yall buying for yalls truck or are you piecing them together? I am looking to go ahead and purchase mine for the Blazer and wanted some ideas
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
Old 06-26-2007, 10:57 PM   #2
72CSTC5
72CSTC5's Avatar
Re: Air Ride
Hyde, you would be better off asking in the suspension forum which is why you haven't gotten any hits here. Try ***************** Best prices for the money.
72CSTC5 is offline   Reply With Quote
Old 06-26-2007, 11:02 PM   #3
hyde
hyde's Avatar
Re: Air Ride
I know....But You aint told me what to get yet...Hook it all up and send me the link....Im on a spending spree...Got alot done on the truck....
Old 06-26-2007, 11:18 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Air Ride
How nice do you wanna go ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 06-26-2007, 11:22 PM   #5
steveo10
steveo10's Avatar
Re: Air Ride
i would say suicidedoors also thats where i got all my stuff.
steveo10 is offline   Reply With Quote
Old 06-26-2007, 11:23 PM   #6
72CSTC5
72CSTC5's Avatar
Re: Air Ride
You really need to rethink the hours of operation of your company. 14 days off at a time is DANGEROUS for you.
Old 06-26-2007, 11:58 PM   #7
randomhero472
randomhero472's Avatar
Re: Air Ride
go to suicidedoors.. they have everything listed for our trucks, i'm running slam re7's all the way around, you can get the bolt in plate for the front, and the rear... im actually not sure on the blazer, but they have everything you need
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-27-2007, 07:54 AM   #8
hyde
hyde's Avatar
Re: Air Ride
Damn man that hurts...I thoght we were friends....I have re thought it...Im going to try to make more cash so I can spend more!!!!!!!!!
Old 06-27-2007, 03:38 PM   #9
itsmike2k
Re: Air Ride
I havent priced everything out yet but it seems to me you can get better deals on EBay piecing a system together. Like dual 380's are about $15.00 cheaper shipped then SD's price w/o shipping.
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 06-27-2007, 07:37 PM   #10
hyde
hyde's Avatar
Re: Air Ride
Well guys the air ride is handled....I bought RE7 bags all the way around, all the lines, fittings, 6 valves brackets, dual Viair 380's and the Digital Air management system today. The only thing I didnt buy was the tank or tanks cause im not sure on where I should mount them and the room availible under the blazer...Once I get the tub off I will purchase my tank or tanks......I feel i did good on the price...Jerid at Suicide was good to deal with...I picked up the compressors off of ebay...
Old 06-28-2007, 11:08 AM   #11
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: Air Ride
Blazers are the same as the trucks up front and you can our standard upper mounting plate, RE7 airbags, and a lower cup as shown below. You can also install a set of drop spindles to help the truck get down even lower.
In the rear you can choose from several different options. We do make a notch for the 67-72 trucks that is contoured to match the bends in the frame. We also offer a weld-on parallel or trianulated 4 link kits that you could use and you can run the bags off the axle. Or you can buy our 73-87 cantilever attachment and weld it onto the rear frame rails. The cantilever system would locate the shocks and bags for you and allow upto 12 inches of travel. Here's some images of a Blazer I did with some of the components listed above.
All the products that I was refering to can also be seen on our website, http://www.kpcomponents.com
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 06-28-2007, 12:57 PM   #12
edflores
Re: Air Ride
Kp has some nice stuff. my friend has an 01 fullsize with the 6 link and that thing is sweet. brackets for the front can be bought from suicideddoors.com those with some re-7' and you will lay on the control arms. if you want to spend some money, buy the porterbuilt crossmember with airide arms. for the rear...... i unnno. i wouldnt want to hack up a blazer. you may want to run the behind and under kit from sd with a parallel 4 link and sleeve bags or re-8's. you have leafs in the rear???
edflores is offline   Reply With Quote
Old 06-28-2007, 01:20 PM   #13
b&a72
Active Member
b&a72's Avatar
Re: Air Ride
Don't mean to hijack but do you need to run lower cups or can you just fab up a plate to mount the bottom of the bag to?
b&a72 is offline   Reply With Quote
Old 06-28-2007, 01:33 PM   #14
edflores
Re: Air Ride
im not using cups but i would certainly get more lift if i did. and my bags are not all the way compressed when im layed out.
Old 06-28-2007, 01:34 PM   #15
Kontrol Phreaks
Re: Air Ride
Most definatley need lower cups other wise the bag is just floating in the lower coil spring pocket, which will cause it to fail down the road. You can run tubular upper and lower control arms which will allow the truck to get down lower then if it has stock arms.
With lower control arms, spindles, and the upper plate you should lay front crossmember like a champ, even on 22's like these trucks.
If you installed the Porterbuilt dropmember then you can take it even lower to the pavement and use either factory or tubular control arms. Stay tuned as we build a C10 with all these products and put the rockers on the ground.
- Clint -
Old 06-28-2007, 01:42 PM   #16
b&a72
Active Member
b&a72's Avatar
Re: Air Ride
So with tubular arms I dont need cups? Also you can cut the cups down can't you.
Old 06-28-2007, 01:50 PM   #17
edflores
Re: Air Ride
EDIT: i still run a lower plate attached to the lower arm to keep my bag in place
Old 06-28-2007, 02:59 PM   #18
b&a72
Active Member
b&a72's Avatar
Re: Air Ride
Do you have a picture? Also did you just fab one up out of flat stock and drill holes through the bottom of the a-arm?
Old 07-18-2007, 12:12 AM   #19
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Air Ride
Hyde, I was wondering what size valves, lines, compressors, and tanks you are going to to run. I have RE 7's all the way around, and was think 2, 5 gallon tanks, 2 Viair 480C's. I plan on running 3/8 line and Valves, but have no idea which kind to run. If anyone can suggestion what valves they like, please say.
BigShoe24 is offline   Reply With Quote
Old 07-18-2007, 01:17 AM   #20
edflores
Re: Air Ride
bad idea. im rubbing now. i bought lower plates from suicidedoors. we are gonna get some tubing to make cups for the bottom which sucks cause i dont lay anymore after i went to a 29" tall tire. but i dont have spindle and im only about an inch from the ground. that porterbuilt piece looks like its well worth the money so you may want to look into it.
Old 07-18-2007, 03:17 AM   #21
Gimix
Gimix's Avatar
Re: Air Ride
I'm still a noob with air rides but does someone who just wants a nice air ride need 2 480's for a 1/2?
Travis
72 short bed Fleet side
Gimix is offline   Reply With Quote
Old 07-18-2007, 06:23 PM   #22
djw32
Re: Air Ride
Kontrol Phreaks,
Who makes the upper/lower control arms in this picture? I searched your online store, but could not find them.
djw32 is offline   Reply With Quote
Old 07-18-2007, 06:31 PM   #23
Kontrol Phreaks
Re: Air Ride
Those control arms shown above are the ART upper and lower arms that were taken apart and paint body color to match the vehicle. They worked out nicely on the truck, especially once they were painted and installed to compliment the rest of the suspension.
- Clint -
Old 07-18-2007, 06:33 PM   #24
Kontrol Phreaks
Re: Air Ride
You'll still need to run an upper mount to locate the bag, but the lower doesn't require a cup since the bag bolts directly to the lower control arm.
- Clint -
Old 07-18-2007, 06:39 PM   #25
Kontrol Phreaks
Re: Air Ride
Two 5 gallon tanks would be the right amount of air for your truck. Now when it comes to compressors and valves there are plenty to choose from. If you're not looking for a super quick speed then you can run a 3/8" setup and use the Viair 400C compressors. They're the fastest filling compressors out and the most affordable. I'd suggest running (2) 5 gallon tanks, (8) 3/8" GC valves, 3/8 hose and fittings, and (1) 400C Dual Compressor Combo Pack. That pack comes with (2) compressors, pressure switch, and the relays.
That system would be very responsive, sufficent air supply onboard, and the air recovery time would be extremely quick. The system would be moderatly priced, especially when compaired to a 480 compressor system.
If you would like more information, or prices, please feel free to call, pm, or email me. I do offer discount prices to member of this forum and would be more then happy to put a package deal together for you.
- Clint -
