#26 | |||
"I ain't nobody, dork."
Re: Cleaning up old nuts and bolts ?
This...
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#27 |
Oxalic acid. Inexpensive, removes the rust and coats with a zinc coating.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#28 | |
![]() Join Date: Jul 2001
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
#29 |
i agree vinegar will surprise you what it does to anything rusty.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#30 |
Old member
White vinager and let them sit over night. Take them out and wire brush them, let dry and paint them. Poke the bolt through some cardboard and paint the heads.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#31 |
Active Member
![]() Join Date: Jul 2007
Since I posted this, I have accumulated more nuts and bolts of all kinds in different containers. I have tried different methods inluding the automatic trans fluid. I placed a bunch of bolts in a large can with a lid and filled it up with transmission fluid. It took a long time but the bolts did come out clean. I've wire wheeled some and cleaned some with diesel but never tried the muriatic acid.
This apple cider method sounds interesting. I may try that on the batch that I have next. Do they have to be cleaned of grease first? |
#32 |
I take mine to my local plater. They strip the then plate them for about 20 bucks for a 2 gallon pale full. I have gotten zinc and black phosphate done.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#33 | |
I've used a can of carb cleaner with the basket in it for nuts and bolts a lot to get the grease off. You can only soak a few at a time but you just throw a handful in the the basket put it in the can and let it soak for a couple of hours and pull it out and rinse it off. I use "Oil Eater" to clean larger parts where I spay it on with a squirt bottle, let it soak, scrub it with a parts washing brush and hose it off and have great results. Some of the local shops are using it in their hot tanks because it is biodegradable unlike the old caustic powder we used to put in hot tanks. some of that in a five gallon bucket would work great for cleaning small parts but you still will have to deal with the rust. A rock or shell tumbler and some abrasive powder might work to clean small batches of nuts and bolts. just put them in and let them turn. |
#34 | |
Then store them all in oil and they are better then new. ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#35 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Muratic acid is diluted Hydrochloric acid and is widely used in swimming pools for cleaning and for lowering PH in the water, BAD STUFF! Even though it is the primary acid in your stomach, I'd stay away from it for reasons already indicated. Phosphoric acid, used in most "Cola's"(in trace amounts) is the acid used in the "rust converters" such as "Naval Jelly." It is much less harmful and reacts with iron oxide to form a "black phosphate" that is an "inert compound" and when painted with a zinc primer will remain inert to any further oxidation. Many nuts and bolts as well as many parts such as carburetor's on many older motorcycles are no longer available so careful restoration and cleaning is a must. Many restorers are using "Lemon Juice" to clean aluminum, brass, and copper parts followed with a sodium bicarbonate solution rinse (baking soda & water) to neutralize any remaining acid. Iye treated headers, truck beds, and many nuts and bolts with Phosphoric Acid and have very good results! My 72 bed had 4 areas where the rust had eat completely through the bed. Most rusting problems with these trucks and most older vehicles is directly related to poor grounding and "Electrolysis" takes over! Most rusting can be stopped dead by using "Anodes" placed at various locations on the truck or vehicle such as the bottom of the battery tray.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#36 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#37 |
If it's more grease than rust, I keep a 5 gallon bucket of Pine-sol as a degreaser, even takes the grease stains out of cast aluminum. You just throw them in there for a few days or a week and it doesn't kill the plating. If you want to brighten up the plating fill a container 1/3rd full of your bolts about half Ajax scouring powder and the rest water and shake. It's cheap use lots and it will make the mixture viscus enough to keep the nuts and bolts from nicking each other. Anyway, motorcycle restoration tricks where almost every nut and bolt is visible in the end product.
..Oh and rust well that you just kind of wipe it off whith your fingers, I see it once in a while here in Southern California, you're talking about that light orangishy dusty stuff that accumulates on stuff right? Although I'm not sure why you'd have any on a vehicle that is only 40 years old. Last edited by skorpioskorpio; 01-03-2013 at 02:32 PM. |
#38 |
I have always used white vinegar .Works great,removes all the rust . just soak for 24 hours.
''Whether you hear cheering or booing,as long as you still hear noise you still got it.'' Dale Earnhardt |
#39 |
vinegar is the best
coca cola works well also |
#40 |
Moderator
![]() Join Date: May 2007
Anything acidic will clean off rust...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#41 |
The Older Generation
Check this thread out. http://67-72chevytrucks.com/vboard/s...d.php?t=452909 The cement mixer is what I use, only I do it outside so I don't need the cover. Works good and you can do a lot at once... LockDoc
#42 |
Evapo-Rust from Autozone. Soak overnight...the best.http://www.autozone.com/autozone/acc...er=643195_0_0_
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#43 |
![]() Join Date: May 2011
I kept every original bolt that I could. Blasted them all in a blast cabinet. One at a time. The blackones I sprayed with black epoxy. Zinc ones I replated with zinc kit from eastwood.
Took a long time but I would do like ten a day or so and all that original hardware looks great in there. Looks of them have very neat stapings on them, not like the generic china bolts of today. |
