Old 09-06-2007, 05:22 PM   #1
68gmsee
Active Member
68gmsee's Avatar
Cleaning up old nuts and bolts ?
Does anyone know of a good way to clean the rust and grime off? I'd like to reuse the ones that are in good condition in my old trucks and others that I've accumulated over the years.
I've used petroleum jelly and other rust removers before but these won't protect the metal once the rust is gone. I'm hoping there is something else out there that works better.
68gmsee is offline   Reply With Quote
Old 09-06-2007, 05:57 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Cleaning up old nuts and bolts ?
Either have them beadblasted, or just buy new ones. Nuts and bolts are cheap. I've also tumbled some in my brass shell casing tumbler.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-06-2007, 06:07 PM   #3
Stoney
Farm Truck
Stoney's Avatar
Chemtool Carb Cleaner That You Soak Carbs In Works Good Too.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 09-06-2007, 07:11 PM   #4
cdowns
cdowns's Avatar
places like eastwood harbor frieght northern tools as well as tptools have a media vibrator thats inexpensive simply put its a bucket of blast media that vibrates you put the small objects like nuts and bolts in come back later and theyre done ready for paint or oxide coating or however you want
Old 09-06-2007, 08:07 PM   #5
ratrod67
ratrod67's Avatar
Make a buzzwheel from an electric motor and a wire wheel. Works good.
ratrod67 is offline   Reply With Quote
Old 09-06-2007, 09:23 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Ratrod... Not sure what a buzzwheel is.
re: other options. I do have a can of carb cleaner. I'll try that. I'm also going by Harbor Freight to see what they have.
The ones I'm thinking of reusing are mainly the sheetmetal type. I'd like to reuse some of the ones I have since they look to be in good shape other than surface rust. Hate to just discard them.
Old 09-06-2007, 10:29 PM   #7
oldsmobilekindofguy
just soak them in WD-40, may sound like a hick but you will be surprised how well WD-40 works on stuff. I have used it to take tar off the side of my 1970 olds, and it should even protect the nuts and bolts
oldsmobilekindofguy is offline   Reply With Quote
Old 09-06-2007, 10:38 PM   #8
Billla
Billla's Avatar
this is what I do. I use the Caswell black oxide process.
www.caswellplating.com
Otherwise...
www.totallystainless.com
Billla is offline   Reply With Quote
Old 09-06-2007, 10:49 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Alot of the original bolts for my 66 Chevelle and 72 GMC truck have certain markings on the head of the bolt. It's hard to find them like tha anymore. For instance, the front end body bolts on my 66 and 72 have big "C"'s in them. I just used a wire wheel, and a pair of needle nose vice grips. Then I poked the bolts thru a cardboard box and shot the heads of the bolts with a clear spray.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 09-06-2007, 11:59 PM   #10
prg machine
prg machine's Avatar
Here is what I do and it works well. Wire brush the heck outa em. De-grease with a powerful detergent like POR 15 Marine Clean, then Soak in Ospho, POR 15 Metal Ready or something like Rust Mort. They are Phosphouric acid based. Leave them in a plastic coffee can over night submerged. Take them out and rinse off, maybe clean the residue with a soft brush. You want to leave the powdery looking finish, or etching. Then paint over them with a thin layer of Rust Shield or POR 15 followed by a thin coat of any flat black, I use Rustoleum. Look good.
I know that new ones aren't that expensive, but if you like original stuff and love doing it yourself................go for it.
I have also used the salts for the black oxide finish before. It is equaly as fun!!!!!
Google it, buy the chemicals from chemistry supply source and throw it in a steel can or old pot and heat up to a liquid. Very inexpensive fun and another one to stay outside outa the way with so ya don't lose piles of truck points!!!!
prg machine is offline   Reply With Quote
Old 09-07-2007, 12:01 AM   #11
prg machine
I forgot to mention that this is the fstener of choice finish I use for all of my engine bolts. Black just looks right!!!!
Old 09-07-2007, 12:14 AM   #12
Aarons72s
To get all the old rust, grease and paint off dunk them in a mixture of muratic acid and water. Strips it all off quickly. I use it to clean up all my rust encrusted parts. Just be sure to do this in a well ventilated area and wear protection. You will also need chemical resistant gloves. As the fumes are strong and the acid will burn you. They sell this at hardware and pool stores. I got a 5 gallon bucket, 40% acid to 60% water, to dip parts and stuff. As for keeping them from rusting when done paint them or plate them, your choice.
Aarons72s is offline   Reply With Quote
Old 09-07-2007, 10:33 AM   #13
Orange
Licensed to Thrill!
Orange's Avatar
Eastwood has quite a few options.
http://www.eastwoodco.com/jump.jsp?i...emType=CONTENT
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-07-2007, 10:49 AM   #14
Musclerodz
I do the same thing. Works great
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 09-07-2007, 02:11 PM   #15
68K20 x Drill
I toss a few handfuls into a Gatorade bottle, fill halfway with old ATF, put the lid on, and then let the bottle roll around in the back for the truck for a week or two. this removes all the loose crap, and most of the rust. Best of all, it takes very little effort.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 09-07-2007, 04:54 PM   #16
68gmsee
Active Member
68gmsee's Avatar
Now, that's my idea of cleaning bolts. I'll throw the bottle in the back of my bush hog shredder. That'll bounce them around some. May even throw in a handful of sand to help.
I've gotten quite a few ideas, appreciate the suggestions. I hadn't thought of the muriatic acid thing. I still have some left over from some gun barrel cleaning and bluing I was doing last year.
Chevydog, I also wanted to keep the original look on these bolts. I went to one of the local places and they were selling a similar looking bolt- .41 plus tax (almost .50) each.
Don't want to sound cheap, but if I can clean them for a few pennies and reuse them, I'll save a few more dollars for the paint job later.. I have a lot of them from an old truck I dismantled years ago. And I have two classics I'd like to fix up.
Old 09-07-2007, 07:58 PM   #17
bad6772
Official Site Guitar Shredder
bad6772's Avatar
ya beat me to aaron lol ... this works i learned it from my father years ago
bad6772 is offline   Reply With Quote
Old 09-07-2007, 10:49 PM   #18
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
the wire wheel takes 20 seconds...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 05-27-2012, 10:44 AM   #19
superlifted
superlifted's Avatar
Ok guys I'm about to blow your minds. I tried a bunch of solvents that only halfway works and made my garage stink to high heaven but not anymore. Instead of buying clr or evaporust for 15 + dollars a quart you can just go down to your Lucan Walmart and pick yourself up a gallon of apple cider vinegar. 3.50 I think is Wat a gallon goes for but this stuff WORKS.i grabbed all my rusty hardware in a gallon bucket and let it sit a few days and this nasty looking surface foam started to appear but the bolts look brand new. It won't peel paint its non toxic and cheap. Try it put see if it works for u guys. But n
superlifted is offline   Reply With Quote
Old 05-27-2012, 10:48 AM   #20
leddzepp
Moderator
leddzepp's Avatar
apple cider vinegar (or even regular vinegar) work great.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-27-2012, 11:17 AM   #21
jocko
jocko's Avatar
one note on the cautions already mentioned with muratic acid. As a high school kid, I discovered just how well muratic acid worked and used it carefully to clean a bunch of old parts down to bare metal and get rid of the rust. Two lessons I learned the hard way... Disposal and storage. To give you an idea of how caustic the stuff is - I poured a little out on the blacktop driveway and it ate straight throught the driveway. Then, I made the mistake of leaving the container open in my dad's workshop only to come out the next morning to find the finish eaten off his tools just from the fumes.
Be very careful using this stuff. I believe chem gloves were mentioned - but an absolute must is a good set of safety glasses that SEAL. You can be careful all you want, but accidents happen even when you're careful, so be prepared. A couple rusty bolts aren't worth an eyeball. On that happy note.... I agree, muratic acid is a great way to do this stuff - ok, an effective way, anyway. But there are MANY other very safe products out there nowadays that have come out in the last 10 years or so that work just as well. Yes, I still have some in the garage - it's in a very tightly sealed container... I can still remember the look on my dad's face when he saw his tools. i thought I was a dead man
Old 05-27-2012, 11:35 AM   #22
vectorit
What?
vectorit's Avatar
I just use Castrol Super Clean.
Works great, and I just steal wool the rust off.
I put all the nuts and bolts in a shallow pan, so that I can fish them out with pliers.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-27-2012, 12:01 PM   #23
brianthelion02
Overdrive club
brianthelion02's Avatar
Vinegar works great!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 05-27-2012, 01:04 PM   #24
50bomb
50bomb's Avatar
I have hoarding problem when it comes to saving nuts,bolts and washers too. Even if they are rustier than rust.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 05-27-2012, 01:27 PM   #25
67anthony
I have used a rust converter works good.
67anthony is offline   Reply With Quote
