Old 10-30-2007, 04:33 PM   #26
LAFNATU
LAFNATU's Avatar
Re: fuel injected engine for my 66????
I was also thinking about fuel-injection, a friend of mine told me where I can get a 8.0 leter already pulled and complete for 3500.00$ but as crazy as this may sound to some of you, I think it will be too much for my truck. I just like to drive it not try to get killed in it.... besides it has enough power with the 302...
LAFNATU is offline   Reply With Quote
Old 10-30-2007, 05:15 PM   #27
63 & 64 Bowties
and a few others
Originally Posted by Fastrucken View Post
How about a genIII engine. Here is my 5.3 swap and run by megasquirt.....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-31-2007, 01:10 AM   #28
Chevysdominate
Chevysdominate's Avatar
Are you running one of the new sequential/coil on plug megasquirts? What kind of meagsquirt do you have going on if not the new sequential version? Do tell.
Chevysdominate is offline   Reply With Quote
Old 10-31-2007, 05:06 AM   #29
Fastrucken
Junior Member
Fastrucken's Avatar
Right now i'm running MS1-extra. I'm also switching off with msII-extra. Both work, I am having a crank trigger issue. Its not bad.. I use the truck as a daily driver. Its just not up to full potential yet.
As far as running the coils. They can be triggered right off the led output in a wasted spart configuration with no issues at all.
The engine is actually from a 2005 suburban I picked it up from the j/y for 1000$ and included the transmission and acc with only 6k miles. Swaped to a drive by cable throttle body and swapped coil with the wifes 03 tahoe only because of clearence to the firewall. GM switched to a sqaure coil some time in 05.
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 10-31-2007, 07:52 PM   #30
Chevysdominate
So, you use the 8 coils like the ford edis systems firing 2 cylinders at once? I thought you might be a tester for B&G at first.
Old 11-01-2007, 08:40 AM   #31
Fastrucken
Junior Member
Fastrucken's Avatar
For me sequential fuel injection is not needed since I don't have the ability to tune each individual cylinders. I also already have a MS1 and a MS2 computer built so in my situation its just kind of a waste of resources. The new board is definitely sweet and is a good option if someone doesn't want to build their own board. I’m just waiting for the GPIO board so I can control the trans and get rid of the tci tranc computer..
To the OP megasquirt is also a good cheap way to run a tbi or tpi.......
Graham
