#26 |
Formerly yellow72custom
Re: Quest for the best milage from a C-10
Yup...work the math out before you do anything. If you are doing this just to save money it may take 50 or even 100 thousand miles to get the payback you need, since building a new EFI engine is going to take thousands of dollars....you may be better off to just buy something else that will get better mileage that your truck ever could, and keep the truck as a toy.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#27 |
I have a '70 LT1 350 with a small solid lift RV cam, Holley Strip Dominator intake, a Holley SA770 carb leaned out by drilling air bleeds all backed by a 700R4 and 4.11 gears turning 28" tall tires in my '64 long bed step and it gets 19.2 MPG @ 70-75mph on a good day. I am right at the brink of pinging all the time and have to run a bottle of 104+ octane booster every 2 tanks ( I fill up at half tank to keep it mixed as long as possible). I bought the truck with the engine/tranny already installed and put the SA770 carb on it along with a new HEI ignition. I am playing with the ignition curves to help get rid of the pinging. I may try some 1.6:1 roller rockers to get a little more duration out of the cam to bleed off a little cylinder pressure. I also have headers with 2 1/4" exhaust and Flowmasters turned down in front of the axle. The high compression is a big factor in efficiency at the 2600RPM it turns @ 75MPH . I may swap the intake out for a Performer RPM to get more low to mid-range TQ. out of it .
Rick Rick
1970 SS El Camino Resto-rod 1951 Chevy 3100 ( in pieces at the moment) 1964 C-10 Long Step ( new daily play truck) 1999 SS Camaro & 1994 BMW 740IL Daily drivers 1969 SS Chevelle ( next in the resto line) |
#28 |
I would rather drive an old gas guzzling Chevy than have to be seen in a little turd econo-box . Let the Fart-can kids have the "Crayolla" and drive your truck !
![]() You would have to drive that ricer for 10 or more years to warrant the payback in better MPG , $20,000 for a new Toyota is a lot of gas money for an old truck ![]() Rick
#29 | |
I love my truck to, but my car paid for itself in gas money 2 years ago, and I've only had it for 3.5. Sure, my truck is 10x more fun, but it makes zero sense to drive it anywhere near as much as I drive my car (at least 15,000 miles a year, including a lot of long trips).
#30 |
You were right, Brad. My bad
a quote from Mortec.com: 377 = 4.155" x 3.48" (5.7" or 6.00" rod) 400 block and a 350 crank with "spacer" main bearings. I was also wrong about the article I read. It was called "The 350 Chevy should have built". It uses a 327 crank in a block bored to 4.155 (30 over 400 block). It's got a table top flat 400 foot pound torque curve from 2500 revs and up. Makes for some good reading that gives a little insight into the benefits of long rod ratios and some causes of detonation too. Here's a link to ithttp://www.purplesagetradingpost.com...%20engine.html Am glad to learn also that Ohio Crankshaft can grind a blank to suit and eliminate any bearing spacers or extra thick bearings. All, granted it's a "specialty engine" that most of us wouldn't run right out and build. But as long as diggertodd's doing research on what small engine combos yield great results, it's at least worth reading. Also, it's contrary to the usual theme of "no replacement for displacement". However, it is in line with diggertodd's smaller CID 305 build concept, only without the disadvantages of shrouded valves and sensitivity to detonation. When it comes to fuel economy, a 350 SBC that uses cheap gas, has 11:1 compression ratio and yields 400 foot pounds of torque gets my attention (even if it does have Ford conrods in it). Okay, 'Nuff of the sidebar. Back to the stroker MPG question at hand.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 10-27-2007 at 07:24 PM. |
#31 |
I get 20mpg in my camaro that has a 305
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
#32 |
This is odd considering the 350 HAS THE SAME BOTTOM END as the 305. Perhaps you are thinking of the soft cams that GM used from the mid 70s to the mid 80s. I also disagree with not saving any gas using the 305 compared to the 350.
#33 |
diggertodd
Corolla - heh.... funny
![]() Its worth every penny to drive a client to lunch or dinner in my C-10 and better yet - clear the throttle in the motel parking lot while all of the salesmen drones are climbing out of their taruss ... and Corollas. I'll shoot for 20 mpg and make my drives much more enjoyable... Leaning towards a fresh 355 flat top, zero gap rings, .480 hydraulic roller cam and small runner, 76 cc chamber heads and dual plane intake and the EFI for those that asked, you can see the TCI 4L60E contrller mounted on the passenger front wheel well Since completed in August, I have driven her from central Illinois to Cleveland, Columbus, Memphis, Detroit and Indy twice... And won't quit driving the wheels off of her....no matter what the milage. ----- and always remember... read Drag News Last edited by diggertodd; 10-27-2007 at 11:34 PM. |
#34 |
![]() Join Date: Nov 2004
I don't think you ever answered my question? How sure are you that your speedometer/odometer is 100% correct?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#35 |
diggertodd
As far as the actual speedo - it is one of the new Autometer electronic units that feeds from the pulses from the 4L60E sender, push a button drive exactly 2 miles (used a hand held GPS) and push the button again. Used the same GPS to set the TCI computer pulses per mile. No gear ratio - to tire diameter variables.
-Diggertodd ------ and always remember, read Drag News |
#36 |
That sounds cool!
Based on your RPM's I'd say your rear axle guess of 3.73 is probably right. Maybe try a set of 3.42's?
#37 |
Why not put a GEN III motor in it??
#38 |
![]() Join Date: Jun 2003
I found the article on Sumner’s site while surfing for 87 Octane engine builds. I also found several more articles on so-called 87 octane high horse power engine builds. I went so far as to write to and email the publisher of the article” The 350 Chevy should have built” asking if the engine was ever installed and road tested. I did not receive a reply. I did find an article from another magazine following up on their version of the 87-octane engine build. This magazine did road test their version. They reported that the power curve was not suitable for a daily driver and they were ending their work on the design. I deleted my bookmarks after reading this article.
I now am looking for a more traditional engine that will give me decent mileage with an overdrive and 3.42 rear end. |
#39 |
go ahead and get some kind of fuel injection for it, get one of those retro full roller cam jobs, clean up the heads, or maybe just get some already done up aluminum heads that are matched to your cam and purpose, (talk with comp cams). the with that get to a dyno and dyno tune it, then with that you will know where your making good low reving power and then setup your rear end gearing for optimal gas mileage.
#40 | |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#41 | |
A few I found tonight 87 Octane Sites http://www.compcams.com/information/Articles/ For the following two articles, states the original publication source http://www.compcams.com/information/...HP0401-001.asp Agent 87 on Comp Cams Site http://www.compcams.com/information/...HP0201-001.asp 411 Horsepower on 87 Octane AIRFLOW http://www.airflowresearch.com/artic...le03/A3-P1.htm The 350 Engine Chevrolet Should have Built Summers Page http://www.purplesagetradingpost.com...%20engine.html The 350 Engine Chevrolet Should have Built Hot Rod http://hotrod.com/techarticles/engin...ild/index.html DART 450CI Small Block (on 87 Octane) Popular Hot Rodding-350 Bolt On Power Mods http://www.popularhotrodding.com/eng...ons/index.html This mag had another article on a high horsepower 350 on 87 octane but I could not find it again MAS Performance 87 octane crate in this article http://www.superchevy.com/technical/...mbo/index.html Car Craft (this one is a ford 460, reading this will confirm why most of us choose Chevy’s) http://www.carcraft.com/techarticles...460/index.html |
#42 | |
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
#43 |
![]() Join Date: Jul 2004
We built a roller cammed, swirlport headed 305, 20 mpg - details are in the link
http://67-72chevytrucks.com/vboard/s...d.php?t=262413
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
