diggertodd
Quest for the best milage from a C-10
Ready to start a new project - to outfit the highway hot rod with a new engine for the ultimate milage. I currently have a TCI 4L60E trans installed with a mostly stock 355 with edelbrock carb intake and headers. Tweaking and tuning has my besy highway at 14.1 mpg. I travel lots of miles on business and my wife and business partner would like to see fewer gas recepts.
No V6 or diesel - have my hot rod pride My thoughts are a late model 305 roller cam block with small runner aluminum heads and the new Comp Cams/FAST elecronic fuel injection unit that bolts on like a carb with no manifold modifications. Have lots of friends at Comp for actual cam specs. ![]() Any other suggestions????? My engine builder for my dragster thinks a 383 combo would actually do better if I control the shifts lower with the 4L60E and will push the brick down the highway better ![]() Any other suggestions????? |
I have a radical idea!
Re: Quest for the best milage from a C-10
An EFI 350 is hard to beat. I have never really seen a 305 or a 383 (or 400) do any better overall than the 350 in a truck. A 327 might, but I've never seen many of them retrofitted with EFI for the street. In stock form, the 327 is a little better than the 350. The 305's 3.75" bores choke it so much that it can't breathe, and the long 3.75" stroke of the 383/400 sucks the fuel. The thread below contains various combos and MPG.
http://67-72chevytrucks.com/vboard/s...d.php?t=208202
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-26-2007 at 12:22 AM. |
what gears you running? I think with a 4L60E 3.42 or maybe 3.23s would be the optimal gearing for mileage. 3.08s and OD is too high of gearing.
You might also look into some of the OEM fuel injection. I know some of the TBI 305 camaros could put out some decent MPG. I'm partial to TPI, but it may give up a mile over TBI. Of course you could really step up to the plate and put in a gen III 4.8L and you'd probably be 22+ with the proper tune....but that is a tad more than a bolt on deal ![]() |
Stick with the 350 idea....305's have notoriously bad bottom ends after 90k and you won't save any gas in the process.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 10-26-2007 at 05:48 AM. |
I agree. I've never seen a 305 out gas a 350 in a heavy vehicle.
I think smaller displacement(283/307),RV cam,open breathing/flow,hot spark,and EFI or small 4bbl.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-26-2007 at 09:25 AM. |
I have a carburated 350 with a 700R4 and 3.73 open rear axle and I get 16 mpg if I keep it around 60 and 15 mpg around 70-75mph. As has been asked, what's the rear axle? 4.10?
You currently have a great set up. Have you checked to see if your odometer is even accurate? Mine is off 9%.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
diggertodd
The big dummy that I am, I did not count the gears when I replaced the cover this spring - I was too hell bent on getting it running, I'm going to make an educated guess it is a 3.73. With the 4L60E in OD and converter locked... I'm at 1850 RPM at 65 MPH. I am not afraid to throw a new Ring and Pinion in her.
You're talking me out of 305, but there are lots of decent looking 283 cores that can be had on ebay for a couple of hundred bucks. But now your all talking me into sticking with a 355. |
Hardware wise, I too think you have the best combo already:
355 4l60E (make sure the lockup converter is working) 3.73 rear gears less than 2000 RPMs @ highway speeds. 1st I'd work on the air fuel ratio with an O2 sensor and an a/f meter/gauge. (There was a neat article a couple of years ago in CHP magazine called "old school meets new school" [or similar] where a techie tuned the idle circuits of a Demon carb on a LS powered weekend warrier Gen 3 Camaro to get 25 MPG. ) Then I'd call the comp cam friends of yours and make sure your current cam's LSA isn't creating too much overlap for those low engine RPMs/Torque requirements. Your engine may actually be turning below its optimal efficiency point. Another dimension of this argument would be the size of your intake runners (manifold and head both). If they're too large for the miniscule CFMs you're flowing at 1900 RPMs, then the intake air velocity could be too low causing the flow to start/stop every time the intakevalve opens and closes and the fuel droplets to attach to the port walls and intake valves. Next, I'd try a set of skinny hard tires to see if rolling friction is taxing things too much, plus check to ensure the brakes aren't dragging. Last, I'd try a smooth surfaced topper the same size as the cab, or remove the tailgate, or add a chin spoiler etc to improve the aerodynamics a little. To encourage you a little, I once got 25 MPG in my ugly as sin 61 Apache stepside. It had a 3 speed tranny, 3.90 rear gearing, 16" military tires, a 283 with small headers and a tiny Rochester 4 barrel carb and manifold. It was a 100 mile R/T test run (about 20 city, 80 highway) so I took off real easy, kept the RPMs low and stayed under 55 MPH. It can be done. Good luck.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
well,
i have thought about building somthing like this a long wile for the boys truck. my idea was to use a small jug block like a 283 or such, then stick a 400 crank in it. small cubes yet enough tork for some highway gears. with the more torque you can run lower rpm. anyway this was just an idea not sure if its realistic. |
#11 | |
All this gets me to thinking about an article I read a few years back called (I think) "The engine Chevy should have Built". It was the 377 (400 block with a 327 crankshaft I think). While it didn't have much more output than the 400 (no replacement for displacement), it came real close even though it was down about 30 cubes. It used 6"+ long 6-cylinder Ford rods, revved higher and could run higher compression ratio/lower octane fuel/more timing than a 400 and still not detonate. All this made it a more economical alternative for delivering about the same performance. Besides the scarcity of 400 blocks today, the main drawback of building one from parts today is the 327/400 crank to block main bearing diameter differences (hard for us to solve, but would have been real easy for Chevy to use 327 cranks with extra large diameter main journals.) Fun food for thought. Thx, Sailplane
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 10-26-2007 at 09:22 PM. |
#12 | |
Are you running an aftermarket controller for the 4L60E? Or is it an OEM unit and feeding it TPS and MPH data somehow? Assuming it's aftermarket, how much more work to upgrade the controller to a OEM ECM and TBI setup? Though certainly not easy, the ECM/TBI path would ensure an efficient 14.7:1 a/f ratio.
#13 |
Out of the carpool lane.
I thought the 377 was a 400 block with a 350 crank.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#14 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=164908 |
#15 |
OOPS- I could have sworn it was a 350 crank. It seems I've heard of someone doing just that, but maybe I'm mistaken.
Ok, back to my L6. ![]()
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 10-26-2007 at 10:42 PM. |
#16 |
#17 |
AHA! I didn't think I was that crazy!
#18 |
Old member
I have a complete 305 HO motor 700-R4 transmission out of a camaro with 4:10 gears and I get 18 on the open road. The same thing is the problem with my 07 Tahoe to high of gear kills the milage. 3:08 gears keeps the Tahoe in the wrong RPM range all the time sucking gas.
If I drive the 71 at 55-65 I could probably get over 20 just can't make myself drive that slow. Oh I have over 200,000 on this setup that I installed back in 1989. It's my daily driver too! The 305 has performed well with no issues.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 | |
blood type; Retumbo
as for MPG, have you thought about throwing an EGR into the mix? you can run higher compression for full throttle power and have it lean the mix out some for cruising. |
#20 |
a smaller engine needs to work harder in the truck and therefore wears faster and suckle more gas
about the 400 crank in the little bore block : yes it could work but i dont think it will make mush power since the bores are still shrouding the valves about the 350 327 crank in a 400 block :crumpy jenkins made a lot of those engines they rev like mad , he solved the problem with the smaller diameter of the mains by putting in a set of old 400 bearingshells and pin them down , then he would line bore the lot and put 350 bearning over the 400 ones
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#21 |
diggertodd
Yes, I have the TCI 4L60E trans controller - it works fantastic, you can plug in a laptop and move upshift and downshift points as easy as a multiple choice/ chart. There is also an optional program where you place a simple grounding toggle switch on your dash and you can move the shift points and shift firmness (mine is set with a 10% increase) with the flip of the switch.
As far as the different cranks in different blocks, my magazine relationship with different companies such as Ohio Crankshaft, the new blank crankshafts they can use have enough material to pretty much grind any journal or rod diameter and with your desired stroke without the need for spacer bearings, But I cant get them to agree on what combination would be the most efficient to push the ultra aerodynamic and lighweight C-10 around. I am going to throw the 377 thoughts at them. ![]() ------ www.dragnews.com Last edited by diggertodd; 10-27-2007 at 09:31 AM. |
#22 |
I am running a 305 0.30 overbore, iron heads, flat top pistons, Edelbrock performer aluminum intake, 500cfm carb and of course A/C on the '47 which weighs about the same. It is hooked to a TCI 700R4 with lock-up converter, 20-inch rear wheels 9Unsure of rear tire height and stock '65 Chevy truck manual gears ( i believe are 4:11s) and I get 20mpg. The lock-up converter really helps.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
#23 |
just put in the engine that goes with that transmission you have. the lq9! 6.0l vortec! 5.3l vortec! 4.8l vortec!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! ![]() |
#24 |
I am a Referee of life.
Just my thoughts.The 377 seems to be more of a high RPM screamer.The truck will have to use the RPMs and gearing to push it hiway speeds.
I think a 355 would be a good choice.Keep the C/R about 9.5:1 or so and use a roller cam with little or no overlap,roller rockers(keep the friction down),the EFI will also help.Most of this is the same as a late model so a gear ratio of about 3.42:1 should net about 20.With a great tune and optimized fuel/timing curves you should be able to push that a MPG or two.Couple that with modified driving habits and it could climb to 23 or so.I doubt you are going to do much better than that. I believe "Hot Rod" did a 302 in a Chevelle using a set-up close to this and got 22 on power tour with a 5 speed(all of this is IIRC). The main thing is to build the engine to run optimumly in the RPM range where it will be used most.If you are running 2200 RPMs with the gears,tire and tranny set-up then you need to build the engine to run best at 2200 RPMs.This will give you less top end but should keep the milage better. One thing i see the aftermarket really needing is a two speed rear end for light trucks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-27-2007 at 10:14 AM. |
#25 |
Buy a Corolla.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
