Old 11-28-2007, 10:16 PM   #26
SCOTI
SCOTI's Avatar
Re: 20 inch wheels with 5/7 drop
Originally Posted by 1984 swb chevy View Post
I ordered my wheels and tires today. I got 20x 8.5 with 5.25 backspace in the front and 20x10 with 5.00 backspace. I also got 295/40 /20 tires for the front and they said I could run 255/40/20 in the front. I wanted 245/40/20 but they do not have that size. Will I have a problem with the 255/40/20. My truck is an 84 C-10 with 5/7. The tires I ordered are Toyo Proxy.
255/40-20's up front on 8.5's w/5.25"BS will fit. The main concern will be rubbing the top of the inner wheel well on bumps/dips w/the 5" drop. Mine does on larger bumps in the road or smaller ones @ greater speeds but my front wheel/tire combo is < 27" tall; the 255/40-20 is 28" tall.
The 295/40-20's on 10" w/5.00"BS won't be a problem @ 7" drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2007, 10:29 PM   #27
1984 swb chevy
1984 swb chevy's Avatar
Can anyone tell me what size I can run up front so I dont have an issue with the inner fender. Thanks
1984 swb chevy is offline   Reply With Quote
Old 11-28-2007, 10:55 PM   #28
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
heres some 20s for you its on my moms truck. she didnt lower casue she loves using her truck, that and it a 4 wheel drive, but still a very nice truck
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 11-28-2007, 10:56 PM   #29
Srubydo1986
The Crazy Machanic
highs ive hear witha 2wd with out lowering is 31s.
newest additions
Old 11-29-2007, 12:05 PM   #30
AirMale
AirMale's Avatar
The issue we all have when running large wheel and tire combos up front is not the fender or lip, it's the inside of the wheel well. It will only rub when you hit a nice dip or bump but don't worry you're not alone.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 11-29-2007, 12:13 PM   #31
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
DITTO... and I will add this: remove your jack, bolts, etc. from the drivers side wheel well. At least install C/S or small head bolts (if you dont remove the jack).
CLASSIC87' is offline   Reply With Quote
Old 11-29-2007, 09:24 PM   #32
1984 swb chevy
Thanks again for all the info. I am going with the 255/40/20's up front. I need the ground clearance for my lower control arms.I will take the jack out so I dont have to worry about that . I guess I will take my chances with the inner fender clearance. Thanks again.
Old 11-29-2007, 10:55 PM   #33
slugish
Slugish
Wink Re: 20 inch wheels with 5/7 drop
have 5.5 front drop with 8 in. tt 2,s 255x17x50 . Only problem is lower control arm rub when making sharp turn ( NEED TO GRIND OFF A LITTLE WHERE THE BACK OF THE RIM RUBS & SHOULD BE OK ) No problem with upper fender rub , still have bump stops on . if bump stops were removed im sure tire would hit fender well on bumps & dips . Hope this helps . You also can cut a little off bump stop & be ok.
slugish is offline   Reply With Quote
