Old 11-21-2007, 08:47 PM   #1
1984 swb chevy
1984 swb chevy's Avatar
20 inch wheels with 5/7 drop
I would like to run 20x8.5 up front and 20x10 in the rear. I have an 84 c-10 . I ike the big lip look in the rear and need to know what backspace I will need front and rear so they dont rub.Any help on tire size also. Thanks for the help in advance
1984 swb chevy is offline   Reply With Quote
Old 11-21-2007, 09:33 PM   #2
pcmcobra
pcmcobra's Avatar
Re: 20 inch wheels with 5/7 drop
im running that wheel combo on my 86
5.5" bs on back, and 5.25 up front.
245/40 front
295/45/20 rear
no issues at all, could probably go with a little bigger tire up front.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 11-21-2007, 09:37 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
I have been looking for about year on what I was going to get. And I have just ordered them.
Here is what you need.
front 8.5 wheel BS 5" with 245-40-20 or 255-40-20
Back 10 wheel BS 4.5 with 295-40-20 this will give you a little dish.
Trav
tvblazer78 is offline   Reply With Quote
Old 11-21-2007, 10:32 PM   #4
1984 swb chevy
Thanks guys for the info. PCM COBRA could you tell me if you were to lower your truck more would your wheels and tires tuck with out rubbing. I am 5/6 now and may lower the rear one or two more inches Thanks again for the help I just want to make sure I know what I need before I buy.
Old 11-21-2007, 10:35 PM   #5
1984 swb chevy
Hey TVBlazer78. Do you have a pic of your wheels so I can see the offset you have. will your wheels tuck without rubbing. Thanks
Old 11-21-2007, 11:39 PM   #6
pcmcobra
pcmcobra's Avatar
ya, mine would tuck.
Old 11-22-2007, 08:39 PM   #7
1984 swb chevy
Thanks again for the info. I will call and order my wheels this week.
Old 11-23-2007, 12:33 AM   #8
tvblazer78
Low & Fast!
tvblazer78's Avatar
here is one of my old 17x 9.5 BS 3.5, had to roll the lip of the fender up to make them fit..
Old 11-23-2007, 05:29 PM   #9
AirMale
AirMale's Avatar
Trav
I disagree here on the rear back space:
Should be 5.5 on a 10" wheel.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 11-23-2007, 05:34 PM   #10
AirMale
AirMale's Avatar
rear wheel is 9.5 with 5" BS
86 SWB 9.0 LITER
Old 11-23-2007, 08:06 PM   #11
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sorry that you do, but I have a 9.5 with 3.5 BS on it. It's a stock 12 bolt out of a 4x4 blazer. Here is the pic.
Old 11-23-2007, 09:01 PM   #12
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
I have 20x10's w 5.25 BS... I was going to go 5.00 but I run the disc covers and a 1/4 spacer as well. (I use the 1/4 spacer to keep my dust covers off of the drum weights; so they dont get dented)
CLASSIC87' is offline   Reply With Quote
Old 11-24-2007, 10:34 PM   #13
1984 swb chevy
Thanks again for all the info. The 5 to 5/14 inch backspace looks like the way I need to go if I want a 20x10 to tuck without rubbing. If anyone has any good pics of 20 I would like to see them.
Old 11-25-2007, 06:24 AM   #14
AirMale
AirMale's Avatar
good move getting at least 5" backspace. Here's a pic before I installed a 4 link.
86 SWB 9.0 LITER
Old 11-25-2007, 08:46 PM   #15
1984 swb chevy
Very nice truck Airmail. Thanks for the picture.
Old 11-25-2007, 08:49 PM   #16
1984 swb chevy
Hello Airmale could you tell me what size tire you are running
Old 11-25-2007, 11:40 PM   #17
SCOTI
SCOTI's Avatar
Rear 20x10's w/the equivalent of 5" BS was dead-on for my daily 5/7 static-dropped driver..... As you can see in the pic, the rear tires are slightly tucked @ ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-26-2007, 09:07 AM   #18
AirMale
AirMale's Avatar
front tire is 255/35/20 rear 295/40/20
86 SWB 9.0 LITER
Old 11-27-2007, 12:50 AM   #19
1984 swb chevy
Thanks again guys. Now I can order my wheels and know they will fit.
Old 11-27-2007, 06:16 AM   #20
AirMale
AirMale's Avatar
I would order 245/40/20 tires for the front, just to get some extra sidewall.
86 SWB 9.0 LITER
Old 11-27-2007, 04:33 PM   #21
evan
evan's Avatar
Would an extra 1.7" in total height still work?
Evan B.
evan is offline   Reply With Quote
Old 11-27-2007, 05:22 PM   #22
AirMale
AirMale's Avatar
divided by 2. the only height added is below the spindle the rest is in the wheel well
86 SWB 9.0 LITER
Old 11-27-2007, 11:39 PM   #23
evan
evan's Avatar
I was thinking of clearance issues more than ride height.
Evan B.
Old 11-27-2007, 11:42 PM   #24
AirMale
AirMale's Avatar
SCOTI should know this???
86 SWB 9.0 LITER
Old 11-28-2007, 09:12 PM   #25
1984 swb chevy
I ordered my wheels and tires today. I got 20x 8.5 with 5.25 backspace in the front and 20x10 with 5.00 backspace. I also got 295/40 /20 tires for the front and they said I could run 255/40/20 in the front. I wanted 245/40/20 but they do not have that size. Will I have a problem with the 255/40/20. My truck is an 84 C-10 with 5/7. The tires I ordered are Toyo Proxy.
