Old 07-28-2016, 07:33 PM   #26
hardwaycooke
hardwaycooke's Avatar
Re: Tri-Y headers: Doug's, Stan's, Thorley, or??
Originally Posted by Jim_PA View Post
Any experiences with any of these? Are there any other options?
Doug's 372Y-R: http://store.summitracing.com/partde...5&autoview=sku
Stan's 172Y: http://www.focuztech.com/xcart/produ...2-283-400.html
Thorley 372Y: http://store.summitracing.com/partde...rsview=sku&Ns=
I used many different headers before I choose Dougs Tri Y. The number is either 372y or 371y. They fit perfect. They add torque. They are made much better than any others I've used. The ones I have are for lowered trucks, says so in the Summit description. My truck is lowered 5 1/2 in in the front and you can even see them from the side. Love them!!
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 07-28-2016, 07:54 PM   #27
nuke82
nuke82's Avatar
I wish Doug's still used the ball and socket flange. Stan's does but they cost a lot more. Thanks for the reply's! I think I'm gonna go with the Doug's.
72 Chevy C-10 w/ 67 front clip
355 ci Vortec
79 Lincoln Versailles 9" rear end, 390 gears
700R4 tranny
McGaughy's 2.5" Front Drop
Fatbar 4-Link
nuke82 is offline   Reply With Quote
Old 07-28-2016, 08:50 PM   #28
hardwaycooke
I went with turbo clamps, or whatever they're called. metal on metal and nothing to leak.
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 07-29-2016, 05:18 AM   #29
I've run flange collectors on vehicles for a long time and don't consider leaks an issue. Only had to replace a gasket a couple times and it couldn't be any easier. I just did heads on my '72, so had to disconnect the collectors for the first time since 2004 when I put the headers and exhaust on. same headers went back on... Hedman Torque-Steps.
Old 12-24-2019, 12:45 AM   #30
warrfarr
I just installed the Doug's D371Y headers on my 66, they fit great even though they are listed for 67-72's. I measured and trimmed roughly 1/2" from the top frame rail but really only needed to remove 1/4".
warrfarr is offline   Reply With Quote
