#26 |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Solid Piece Glass
Hmm I wonder if he forgot to cut down or replace 2 of the hinge bolts for clearance of the front channel assembly..... Seems I remember reading about having to do that other-wise it wouldn't work properly.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#27 |
I have no time for this
Captkaos ,it's afreind of mines truck and he put away for the winter.I used the short bolts and I even ground the nuts on the inside of the doors,the doors are gm factory doors I just was not able to adjust the mechanism enough to get it all the way down it was either to tight at the front going down or to far bacck at the top and there was a gap at the front lower corner of the window. Like I said earlier it seems as though they glued the rollers onthe windows in the wrong spot on the glass Igot it good as i dared to mess with for fear of dinging the out side of the doors this truck has a real fire paint job on it and I was not wanting to start banging ond grinding on the doors.He's pretty happy with it as is aand hardly ever drives the truck anyways so hes ok with them only rolling down 3/4 of the way.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
#28 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Ok, just figured I would throw that out there, if you needed it. You could call Ben also. I guess if he is happy though everything is ok.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#29 |
Thanks for the input I might play with them some more this summer.
