Old 02-22-2008, 01:58 AM   #26
Number98
Prestige Worldwide
Number98's Avatar
Re: mcgaughys vs. chassis tech drop spindles
I can not speak about the Mcgaughy's but I had a friend that worked at a huge supplier of AIM's down here in Atlanta and he said there were tons of calls and returns on them....
I went with Early Classic because they fit perfect and I will say that my overall experience with those guys at ECE has been great with lots of help and advice when I needed it.
And thats just my 2 cents..... man I think I am out of cents...
Number98 is offline   Reply With Quote
Old 02-22-2008, 02:33 AM   #27
pissonNOS
senior member
pissonNOS's Avatar
yep the guys at ECE are excellent to deal with
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-22-2008, 03:21 AM   #28
shifty
Questionable
shifty's Avatar
Originally Posted by Shane View Post
67 cst answered the question already ... any time you mix a dropped spindle, a small diameter wheel and have insufficient back spacing you're gonna have interference issues ... regardless of manufacturer.
Only thing is, I know 100% for a fact that I've read other people on the forum say they've managed to run 15" wheels with drop spindles before. Maybe it was just special backspacing or something, I dunno.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-22-2008, 04:03 AM   #29
Number98
Prestige Worldwide
Number98's Avatar
I bolted up my 15x8" rallies to the dropped spindles and they cleared before I tore it all apart to restore....
Old 02-22-2008, 07:26 AM   #30
slammed1
1972 Chevrolet SWB
slammed1's Avatar
I personally have ECE dropped spindles and coils on mine and have no issues with the 15x8 stock ralleys but have heard of some people having to fold over the lower control arm lips or even trim the lower lips because it would touch on tight turns. I have installed numerous ECE kits and McGaughys kits as well and either are a great choice. Listen to the advice here about Chassistech and AIM though,seems every forum has shared horror stories of customer service,and lack of quality control or quality at all.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-22-2008, 08:47 AM   #31
RCbowtie69
RCbowtie69's Avatar
i have ece drop spindles on my 69 swb & 15 x 8 ralleys no problems looks great,i like them. did,t have to change any of tie rods, drag link, it fits 69 tie rod ends ,they machine them to fit the year of the truck, other company's you may have to change the outer tie rod ends, ccp has the ends if you use there spindles. i've brought parts from them to. have'n had no problem, i brought a steering box, quick ratio. love the way ece will answer your question, so many parts vendors are out there, if you choose one ask question, most them have tech help, have fun with your project.
RCbowtie69 is offline   Reply With Quote
Old 02-22-2008, 11:44 AM   #32
67 cst swb
67 cst swb's Avatar
Originally Posted by 67 cst swb View Post
I've heard the 15" rim interference is regardless of manufacturer of spindle. Its a mathmatical issue.
As you lower the ride height of the spindle, it raises the center point of the rim higher in relation to the lower control arm. so, the rather small diameter of a 15" rim causes the rim to hit the lower control arm while turning....
So, my memory tells me its a drop spindle issue, not a who manufactured the spindle issue...
I must clarify that most stock steel rallys have NO problems... it's the aftermarket aluminum or alloy rims....
Im hoping the person that gave me this info will jump in to clear up the spindle with 15" rim issue...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-22-2008, 12:33 PM   #33
19stepSide72
wanna be 67
19stepSide72's Avatar
you guys are great. Thank you for the information.
Last edited by 19stepSide72; 02-22-2008 at 12:34 PM. Reason: correcting spelling errors
19stepSide72 is offline   Reply With Quote
