Old 02-28-2008, 04:46 AM   #26
stope4
Re: Factory A/C or aftermarket.....
Andy, this is getting off topic but I think what you are experiencing has to do with how much air is blowing over your condenser in front of the radiator. If you sit at idle in your driveway and spray water on the condenser, I believe the 134a will cool at idle just as good as R12. The problem, how do we get there when we are idling in traffic. You need a stronger gan and more than likely a bigger condenser.
stope4 is offline   Reply With Quote
Old 02-28-2008, 05:03 PM   #27
Andy4639
Old member
Andy4639's Avatar
The condensor is as big as it can be for the area in which it sit's. It was also ordered for 134-A. I have a little electric fan hooked to the A/C switch so it comes on with the A/C. I think it's just part of the 134-A cooling effectness.
I agree a bigger condensor would do the trick but the space is limited on how big you can go.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-29-2008, 12:41 AM   #28
stope4
I always thought someone should make one with a third row, similar to radiators.
For the person who started the thread, the 134a vs R12 issue applies whether you go aftermarket or original. I would stay R12.
Old 02-29-2008, 02:54 AM   #29
Andy4639
Old member
Andy4639's Avatar
134-A is the only way to go. I wouldn't want to have the R-12 inless it's a orignal car or truck that already had it in it. The price is doubled for the R-12.
Old 02-29-2008, 06:13 AM   #30
hambone1958
hambone1958's Avatar
I did the vintage air and love the way it cleaned up under my hood. There are pics at the link below.
Alan
hambone1958 is offline   Reply With Quote
Old 03-25-2008, 07:18 PM   #31
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Andy:
Is that the stock evaporator??
If not how did you end the 2nd smaller tube on the top end of the evaportor??
Did the fitting have to be changed to match up with the new Accumulator??
jayharrell is offline   Reply With Quote
Old 03-25-2008, 09:10 PM   #32
Psycho71
Psycho71's Avatar
I bought a kit locally from Lucky's Rod & Custom in Ennis, Tx. The installation went very smooth. I have yet to use it, since the truck's not complete yet. But it looks like it'll work just fine. Mine was a factory air truck, and just to replace the missing/broken pcs (w/new pcs) would have cost me more than the aftermarket kit. And as a bonus, I now have a much cleaner looking firewall. And a lot more room in the engine compartment.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
