Old 04-27-2008, 06:46 AM   #26
chevychase
chevychase's Avatar
Re: Barn find resurrection
Nice find on the 010 block, it's also known as the racers block. What heads came with the motor?
Joe
chevychase is offline   Reply With Quote
Old 04-27-2008, 07:23 AM   #27
jorgensensc
jorgensensc's Avatar
Your going to want to look under the timing cover. If there is an 10 and a 20 then it is High nickel High tin content. Good strong block.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-27-2008, 03:49 PM   #28
Ilike 72"s
Shawn
Whats that mean, 10 and a 20? Is that ## stamped on the block? I have to go to central oregon today, so I can't look until tomorrow.
Ilike 72"s is offline   Reply With Quote
Old 04-27-2008, 04:00 PM   #29
bigsnookmaster
bigsnookmaster's Avatar
If you're lookin for performance,and your budget can afford it ,World Products Sportsman II heads are hard to beat for the money.Roughly $800 for a pair.Brand newcastings,stainless valves,hardened seats,thicker deck surface,and they flow better than any chevy head,right out of the box.When you get into re-building stock heads,for a few dollars more you can have brand new.Just my .02 worth.
bigsnookmaster is offline   Reply With Quote
Old 04-27-2008, 04:32 PM   #30
Ilike 72"s
My plan is to build with the best quality I can on a very tight budget. Then I will sell it to make money to put into my 71 4x4 project. I'm sure you have seen those pickups at swapmeets that have a quick paint jobs and look like cra@ when you get close. I want this one to look good and be affordable. I will do the complete build including paint to keep costs down.
Old 04-27-2008, 04:45 PM   #31
old Chevy guy
old Chevy guy's Avatar
Looks like the body is preety straight. wont need to much body work.All those west coast trucks look sweet compared to what we get to look at out here in little Rhody!!
old Chevy guy is offline   Reply With Quote
Old 04-29-2008, 05:04 AM   #32
Ilike 72"s
Shawn
took the engine apart today. Can you numbers guys help out again??
Old 04-29-2008, 05:14 AM   #33
jorgensensc
010, 020, high nickel high tin content. Good block.
Shawn
Old 04-30-2008, 04:07 AM   #34
RCbowtie69
RCbowtie69's Avatar
I read in in a book that 882 heads are not good for HI-Performance. It has double heat passage at the center exhaust passage, prone to to heat crack around exhaust valve seats, stock maybe, if you use them have check out, 993 are good heads, they are open chamber heads you may some them around i have 2 sets, 1 set came off of 74 Monte Carlo 4 bolt main, the other set came off of 76 2 bolt main, they are on most target master motor,if looking for a good set of heads Jegs has heads for HP, hope you find some thing out there, just look & ask, some body should have a set but have them check by good machine shop,
RCbowtie69 is offline   Reply With Quote
Old 04-30-2008, 06:39 AM   #35
1fun71
1fun71's Avatar
was it a four bolt???
1fun71 is offline   Reply With Quote
Old 04-30-2008, 07:02 AM   #36
GREASEMONKEY72
GREASEMONKEY72's Avatar
that surely is one good block youve got your hands on
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-30-2008, 07:37 AM   #37
Ilike 72"s
Yes it's a 4 bolt. Picked up rings ,bearings. elderbrock cam kit and other needed parts today. Painted the engine and transmision flame red ( to match future exterior) tonight. Will start assembly tomorrow night.
Old 04-30-2008, 07:43 AM   #38
Ilike 72"s
picture of 4 bolt block
Old 05-02-2008, 06:42 AM   #39
Ilike 72"s
Todays progress. New elderbrock cam, lifters,timing set,intake and carb. New rings and bearings.
Old 05-02-2008, 06:47 AM   #40
Billla
Billla's Avatar
The '010 block is defitely a keeper.
The 882 heads aren't bad from a flow perspective, but the chamber shape is the problem. They'll typically make 20-30 HP less than an "old style" head...and way less than a Vortec.
Billla is offline   Reply With Quote
Old 05-02-2008, 06:54 AM   #41
Ilike 72"s
All I had to do is replace the valve seals nd clean them up. They were in great shape so I used them. It's all about how little money i can spend and still end up with a quality driver. Having fun doing it.
Old 05-02-2008, 07:04 AM   #42
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Thats the combo my 383 stoker has. Its a .030 over 0010 block that has 993 heads with 2.02/1.60 SS valves and Melling MTC-1 cam.
It's an oldskool stroker.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-02-2008, 07:05 AM   #43
chevychase
chevychase's Avatar
Aint nothing wrong with that! I'm sure those heads will do just fine. Plus when you're ready you can just bolt on a set of your choice with that freshened 010 block you got!
Joe
Old 05-02-2008, 07:08 AM   #44
Ilike 72"s
I have a set of doudle hump 202 heads on my 56 chevy. Great power and never any problems.
Old 06-28-2008, 11:34 PM   #45
Ilike 72"s
Making progress.
Old 06-29-2008, 12:34 AM   #46
65ShortStep
Looking Very Nice!
65ShortStep is offline   Reply With Quote
Old 06-29-2008, 12:47 AM   #47
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
You're flying through this build man. That pain is looking great and so is the engine, keep it up.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 06-29-2008, 12:51 AM   #48
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
real good looking rig bud. I wish I could find something like that. Looks like it'll be a fun build
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-29-2008, 10:48 AM   #49
Ilike 72"s
Lowered it 3 and 4 useing blocks and coils. Saved money this way by not changing the front spindles to disk brakes. trying to keep it simple and stay in my budget. Got my engine set in and front mounts hooked up. I cant find my rear mounts. Tore the shop apart looking. Dog probably took it. installed some interior.
Old 06-29-2008, 02:32 PM   #50
*Dylan
*Dylan's Avatar
Nice wooden bumper you have there, that a custom touch?
1967 C10 SWB
Dylan
