Old 05-30-2008, 03:15 AM   #26
byrd
Union Electrician
byrd's Avatar
Re: Brake Lines
Unless you have a 71-2 x-member, no the 71-2 lines will not work for your application. The brake lines 67-70 are in the rear of the front x-member and 71-2 are on the front of the x-member
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-30-2008, 04:00 AM   #27
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
well are your lines going to the front or rear of the cross member. mine are in the rear and it's a 71.
Gulf Rat
Gulf Rat is offline   Reply With Quote
Old 05-30-2008, 04:20 AM   #28
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
Here's my rusty old 71, but as you can see lines go down to the back of cross member.
Name:  brake setup 001.jpg
Name:  brake setup 004.jpg
Name:  brake setup 005.jpg
Name:  brake setup 007.jpg
Gulf Rat
Old 05-30-2008, 04:27 AM   #29
byrd
Union Electrician
byrd's Avatar
Re: Brake Lines
THey all go down the back,but the 71-2 go over the x-member and across the front to the caliper, the 67-70 stay on the back side of the x-member, look at the pics on this page and you will see my 67 truck with a 72 x-member and discs.
http://67-72chevytrucks.com/vboard/s...=209710&page=2
Also in the 2nd pic you posted of your 71 showing the shock up close, see the little flipped up tab at the end of the x-member without a hole in it? That is where the 67-70 hard line would stop and changeover to flexible lines to the drum. That same flipped up tab is on the front and back of the x-member, again 67-70 used the back tab, and 71-2 used the front tab.
Zip:40272
Old 05-30-2008, 04:37 AM   #30
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
k, well if he is changing all the lines does it matter? BTW that frame looks great, soon I'll be get there.
Gulf Rat
Old 05-30-2008, 01:23 PM   #31
byrd
Union Electrician
byrd's Avatar
Re: Brake Lines
Gulf Rat
Yes you still have to use the correct lines for the year x-member you have, discs or not. The little tabs I mentioned are on both front and back,but will only have the hole in either the front or back.
Thank you on the comments on my frame, it was a lot of work.
Zip:40272
Old 06-01-2008, 02:56 AM   #32
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Originally Posted by 70GMCer View Post
All I can say is I paid $100 for the complete kit including mc lines at http://www.finelinesinc.com/
Email or call them and they will set you up. If not, then you can buy the "higher priced spread"....
How long did it take for FineLines to send the brake lines?
VDOG is offline   Reply With Quote
Old 06-02-2008, 04:50 AM   #33
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
I got mine in 3 days, if your going to do this pick a year 71 or 72 get your lines we all here can help you with pic's or fab ideas if needed. Lets get your brakes on and working! Hard to drive without good brakes.
Gulf Rat
Old 06-02-2008, 04:54 AM   #34
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
1 more thing do your lines going to frame to the inside or outside of the frame? Pictures would be nice of lines, upper control arm area both sides front and back views, something like I took.
Gulf Rat
Old 06-02-2008, 10:31 AM   #35
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Gulf Rat
My lines run inside the frame and behind the crossmenber. I ordered my lines on Friday, but I think they were closed because my order on their page has showed pending ever since. I will check this morning.
Old 06-02-2008, 02:12 PM   #36
70GMCer
70GMCer's Avatar
Re: Brake Lines
I bought mine at a show they were at. Check there show schedule. They might be near you. They also give show discount prices.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-02-2008, 03:20 PM   #37
Gulf Rat
Gulf Rat's Avatar
Re: Brake Lines
Found this pic of brake setup for 71-72 hope it helps.
Name:  71-72 brakes.jpg
Gulf Rat
Old 06-02-2008, 05:35 PM   #38
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Attachment 364992
Gulf Rat
Thanks for the photo. My truck is a 69 and I talked to Bill at Finelines and he said I need the disc brake conversion set. There on the way. Hope this works cause im all out of options.
Old 06-04-2008, 04:40 PM   #39
tommypic
tommypic's Avatar
Re: Brake Lines
talking lines where can I get the clips that hold them to the frame ? I am puttting fuel tank in rear too
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 06-04-2008, 08:17 PM   #40
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
The above link is where I ordered my brake lines. They sell line clips also.
Give them a try? Or www.inlinetube.com, someone here used them.
Old 06-04-2008, 10:44 PM   #41
twotrucks
Junior Member
Re: Brake Lines
If you don't change the crossmember all you have to do is fabricate some little brackets to secure the transition from the metal brake line to brake hose from the caliper. I have a 68 and used lines from finelinesinc for a 72 model.
twotrucks is offline   Reply With Quote
Old 06-10-2008, 04:52 PM   #42
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Gulf Rat
Brake lines came today, no pictures or instructions. I will take pictures of the frame and lines. Need to figure out how to run the lines.
Old 06-10-2008, 07:50 PM   #43
byrd
Union Electrician
byrd's Avatar
Re: Brake Lines
What was the total cost and what did you get? IE front only, rear only, or front and rear?
Zip:40272
Old 06-10-2008, 07:56 PM   #44
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
I got them from Finelines, the cost at first was $73 with shipping, but the hold up was they had to adjust the shipping cost for the west coast so it went to $78 Its called the Disc brake conversion kit. I needed the lines to connect to the proportation valve, so they connect at the uninos for the front and rear, I guess. Not complete front and rear lines.
Old 06-20-2008, 02:43 PM   #45
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Did anyone else have to move headers or exhaust to install the prebent brakelines? Looks like thats what im going to have to do.
Old 06-20-2008, 06:03 PM   #46
cparman
sharp as a marble
Re: Brake Lines
Great picture TCB-1!! If you look at this picture, you can see that TCB-1 used ONLY one of the front brake line ports. If you run a 3/16 line from the prop valve to the T located just inside the L.F. wheel that will supply the front disc brakes just fine. The other line 1/4" goes to the back.
do not be afraid of the infamous DOUBLE FLARE. It just takes a bit of practice. you can do this!!! I have a flaring kit I bought from Matco, and hated doing this until I did my last car. I made up my mind that I was doing it, and doing it well. Now it is just like scratching my elbow. Practice makes perfect. If you send me an email I will send you pics of my 69 with power disc brakes. They work, I double flared em, and it anit hard
cparman is offline   Reply With Quote
Old 06-20-2008, 06:07 PM   #47
cparman
sharp as a marble
Re: Brake Lines
VDOG, if you buy a line kit for the prop valve from Master Power Brakes, it will bolt to the valve with a little wiggeling. I really like those guys, and ask for Pat when you call . send me am email, or teach me how to post a pice and I'll show you my truck
Old 06-21-2008, 01:06 PM   #48
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Brake Lines
Of course its an after thought now. I picked up an MC, prop and booster for $65 a couple of weeks ago. Got my old lines off.
The flaring tool you have is hydrallic im assuming.
Old 06-21-2008, 02:07 PM   #49
cparman
sharp as a marble
Re: Brake Lines
VDOG I PM'd ya
Old 06-21-2008, 02:12 PM   #50
cparman
sharp as a marble
Re: Brake Lines
my flaring tool is a plain old manual flaring tool. It does a good job on steel lines, but Stainless is a good bit tougher
