05-28-2008, 08:39 AM | #1 |
Grand PooBaa Member
Brake Lines
Ok, I did the disc brake conversion on my 69. Now im going to install a master, prop valve and booster off a 72 Blazer. My problem, which brake lines do I need to connect the prop valve to the front and rear brakes? I tried to do the brake line flare, (*^%$ THAT) so the kit will be going back to CPP tomorrow.
I did a search, but all I find is disc conversions or booster installs and not the brake lines. Also do I need to run the whole line from front to back or just use a piece with a union? |
05-28-2008, 09:05 AM | #2 |
Re: Brake Lines
I just finished the project this weekend. I had done the 5 lug disc conversion from a square body truck. So of course, I changed the brake booster and master cylinder too along with prop. valve all from the square body. My 69 had the same prop valve as you have in the pics where one line is for the rear and the other to the front brakes. I ran the one to the rear with a union but had to run two individuals to the front because thats how the square bodies are. Pretty simple... took two lines, bent them, and took the t adapter off and ran one line to the left and the other to the right. any questions let me know i could try to guide you thru any obsticles.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
05-28-2008, 09:49 AM | #3 |
Grand PooBaa Member
Re: Brake Lines
Tried to bend and flare a line using the kit from CPP. When I tried to flare, all I did was expand the line opening, no flareing. Also what year brake lines did you use?
05-28-2008, 01:32 PM | #4 |
Re: Brake Lines
I am doing the same thing ( I guess ) . I have a booster setup off a 72 , but what I want to know is where or how did you run your new lines to the rear ( Disk on 4 corners ) . I don't have any lines to run back now . I am going to need new 1's and the clips that hold them to the frame ( gas line to ) . So what I am wanting to know is where can I get new , good used lines or make them myself ? The frame should be back from powder coating this week . I want to get everything in line to go back on . I needs a good Blazer gas tank too . I am having new trailing arms made ( lucky me FREE ) by my son who works in a fab shop , got the rear axles turned down going with 5 lug . going with caprice brakes on the rear . So right now I am just and trying to get every thing to gather
My ZipCode = 29673 2008 Silverado Z71 LTZ Wrecked New Ride SOLD 71-72 Custom A/C Parts Truck < selling parts 67 Chevy ShortStep SOLD 67 GMC SWB Step <-- For Sell 67 Chevy SWB Step <-- working on 2000 Road King <-- SOLD 97 F150 my ride for now 2006 Escape wifes ride HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2 |
05-28-2008, 01:48 PM | #5 |
Re: Brake Lines
This is where I bought my kit. Great prices, great fit & great customer support. No fabbing. Went right in.
http://www.finelinesinc.com/
1997 GMC Sierra Ext 1965 Mustang |
05-28-2008, 05:44 PM | #6 | |
Grand PooBaa Member
Re: Brake Lines
05-28-2008, 09:39 PM | #7 |
Re: Brake Lines
I tried finding me receipt for my line kit, but couldn't. Give the a email or call them. They will set you up. Mine fit perfect from front to back. They have a kit for disk conversion for 67/70 trucks.
05-28-2008, 10:56 PM | #8 |
Nothing to see here.....
Re: Brake Lines
I spliced my front and rear lines in with a union approximately 8" above the frame and bent my own lines from there. piece of cake with practice.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
05-28-2008, 11:14 PM | #9 |
Grand PooBaa Member
Re: Brake Lines
The bending of the line I can get close to what I need, the flaring is the pain.
When I flared a pratice tube, all I did was make the opening wider, no flare what so ever. |
05-29-2008, 12:56 AM | #10 |
Re: Brake Lines
Trying to double flare small stainless lines without a hydraulic flaring tool is an exercise in futility.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-29-2008, 01:11 AM | #11 |
Grand PooBaa Member
Re: Brake Lines
Your right!! Thats why this flare kit will be back at CPP tomorrow. The Hydraulic Kit I saw from Master Power Brakes was 385.00. Its not that serious. So can I use 71-72 brake lines?
05-29-2008, 01:43 AM | #12 |
Re: Brake Lines
If I'm not mistaken, you can single flare a stainless steel brake line. Double flare are for straight steel brake lines.
67 GMC 4x4, 305 V-6, 4-spd 86 S-10, 2.8 2WD LWB 01 Suburban (family hauler) 13 Honda CRV (wife's wheels) 03 Malibu (daughter’s car) |
05-29-2008, 03:22 AM | #13 |
Grand PooBaa Member
Re: Brake Lines
05-29-2008, 06:18 AM | #14 | |||
Union Electrician
Re: Brake Lines
I used www.inlinetube.com.
They seem to be cheaper than the other place metioned and I really liked their customoer service, so much that I will be ordering from them again in the near future. Full stainless brake line kit $185 or $155 for stock compared to $206 for stainless on the other site.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
05-29-2008, 07:24 AM | #15 | |
Grand PooBaa Member
Re: Brake Lines
05-29-2008, 12:53 PM | #16 | |||
Union Electrician
Re: Brake Lines
I bought the complete kit, but I called and had the package modiied for my truck. I have a 67 frame, and a72 suspention. I bought the booster kit from Brothers.
05-29-2008, 02:04 PM | #17 | |
Re: Brake Lines
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 05-29-2008 at 02:05 PM. |
05-29-2008, 02:11 PM | #18 |
Re: Brake Lines
All I can say is I paid $100 for the complete kit including mc lines at http://www.finelinesinc.com/
Email or call them and they will set you up. If not, then you can buy the "higher priced spread"....
05-29-2008, 03:16 PM | #19 |
Re: Brake Lines
Don't know about where you are at but in my state it is automatic failure to use single flare brake lines if caught during inspection. Must be for a reason. I used inline tube very minor alteration for fit & reasonable with quick shipping. They are good people to deal with.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-29-2008, 11:25 PM | #20 |
Re: Brake Lines
I prefered Finelines, had no problems. I order everything for a 71 w/power disc brakes. Everything worked great with maybe a tweak here and there.
The lines going for the frame to the propotioning valve needed the most tweaking but works/looking great now....WOOT I have brakes again. Gulf Rat |
05-29-2008, 11:52 PM | #21 | |
Grand PooBaa Member
Re: Brake Lines
05-30-2008, 12:18 AM | #22 |
Re: Brake Lines
Went from no power to power brakes, so had to replace all lines coming from frame to prop valve to master cylinder. Got the master cylinder and power booster from the local parts store. Only thing I had to get was the brackets that mount it to the firewall, if you need them I have some extra's. Can also send you pictures of my setup.
Gulf Rat |
05-30-2008, 12:51 AM | #23 | |
Grand PooBaa Member
Re: Brake Lines
To make it worse, my MC is used for a car. But thats the one that came with the truck. Last edited by VDOG; 05-30-2008 at 12:52 AM. |
05-30-2008, 02:27 AM | #24 |
Re: Brake Lines
Flaring pipe isn't that bad. Being without tools myself currently,I would check if the NAPA shop can't make it 4you. A 6 foot piece with fittings and flares is not any more than $7.00 +or-. They may ask for labor charges but if this is the only flaring you need to do for the next year, it may be cheaper than buying the tools and learning the art yourself. And yes, you can use unions from front to back. Get creative and figure out how to do it with the least amount of unions. They sell them in various lengths so figure out total length and also where you want the union for ease of installation. If figure is inbetween buy the longer and adjust out the extra. David
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
05-30-2008, 03:10 AM | #25 | |
Grand PooBaa Member
Re: Brake Lines
