06-10-2008, 07:46 PM | #26 |
Re: Oh crap, i need ideas
I was under the impression it was while taking out the water pump the bolt snapped. If that was the case, the easy out has worked everytime for me. (Ok, I'm 2 for 2)
My wife has said this to me a few "if it aint going in, quit turning to the right" That's usually when I am trying to put the gallon of milk in the frig. |
06-10-2008, 07:49 PM | #27 | |
Beeswax available from Goodson: http://www.goodson.com/store/templat...c6eccf66045ea0 |
06-10-2008, 09:15 PM | #28 |
Gettin By on Gettin By
I had bad luck with welding a nut. But i'm just using a flux core wire welder.
I had 3 exaust bolts break off in the head and tried the welding a nut on and the heat/wax at the same time. Put the nut on, welded it to get it super hot, then hit it with wax. Even tried welding the vise grips to the bolt. The 70's steel bolt wouldn't take the weld, it broke off first through 5th turn, and the wax caught on fire when it dripped off and hit the power stearing soaked motor mount. I wound up drilling and tapping the old bolt for a slightly smaller hole. I also had about 1/2 inch clearence to play with. Vice grips and pipe wrenches didn't help a bit. I tried left handed bits and an extractor set. Drilling and tapping was my only option. lesson learned, tap everything on these 30 year old trucks before you reinstall anything.... like i'm going to buy EVERY bolt that doesn't go in smooth.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" Last edited by jayharrell; 06-10-2008 at 09:35 PM. |
