06-09-2008, 12:25 PM | #1 |
Oh crap, i need ideas
changing water pump and broke bolt off in block. 1/4 ich to 3/8 sticking out thankfully. whats your secret for getting it out. thanks, Gary
06-09-2008, 12:32 PM | #2 |
Designated A-hole!
Re: Oh crap, i need ideas
I would try soaking it with some Kroil or PB blaster then use a small pipewrench or vice grips to screw it out.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-09-2008, 01:02 PM | #3 |
my 100th post might as well be constructive
vice grips sometimes work... especailly if... in the past i have used a dremel to flatten two sides of the bolt which almost makes it possible to put an open end wrench on the bolt. similarly, i have seen guys use a cut off disc on a dremel and grind a groove in the end of the sheared bolt and use a common screwdriver. at least you have plenty of room to work! good luck!! *edit* also a good idea to grind a little bit at a time so the heat doesn't warp the bolt and make it harder to get out. and spray the PB blaster on it while it's still hot from grinding, and let it cool... the cooling process will sometimes draw the penatrant into the threads better than just blasting it while it's cold.
RN U OVR Last edited by Senator350; 06-09-2008 at 01:10 PM. |
06-09-2008, 01:10 PM | #4 |
weld a nut on there.
72 Cheyenne Super 80 Silverado Blazer 2wd |
06-09-2008, 01:30 PM | #5 |
Barrito Loco Diablo
Do they still make Kroil? I have like 10 cans, small and large from my girlfriends dad who used to work for a company building aircrafts. I thought i was lucky to have some. Kroil is so much better than the competition. Anyways, good luck on extruding that bolt. Shaving down enough to get a wrench or vise grips on will work, so will welding a nut on the end if you have the supplies. Good luck.
06-09-2008, 01:36 PM | #6 |
On the fast track to nowhere..
I'd say spray it, try vise grips, if that doesn't work weld a nut on it and try that.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-09-2008, 02:38 PM | #7 | |
Gone to greener pastures
But they only place I've been able to find it is online. I used to work in a refinery and the spray cans of the stuff would magically appear in my garage. Unfortunately, I'm working on my last can.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-09-2008, 02:48 PM | #8 |
Decide what you're going to do and get everything ready.
If you go the vise grips route, get the vise adjusted to fit the bolt. Heat the bolt with a propane torch and after it's hot put some was on the bolt. Bee's wax is preferable, but ol' fashioned paraffin (candle wax) works fine. The heat will suck the wax in and lubricate the threads. Start removing the bolt immediately. If you weld the nut on, do the same thing with the candle wax. On the plus side, if you want to call it that, at least you have a little to work with because the bolt's not snapped off flush with the block.
06-09-2008, 03:04 PM | #9 |
put some heat on it and then stick a wax candle to it...it will back out with relatived ease with some vise-grips/channel locks...good luck...scott
06-09-2008, 03:07 PM | #10 | |
06-09-2008, 03:12 PM | #11 |
I'm a big fan of, "Do it once" or "Do what works" and be done with it for good. Get the welder out, a nut and some type of wax and Get 'r done.
R.I.P. Scott Kalitta
06-09-2008, 03:20 PM | #12 |
If all the other good ideas fail you can center punch near center of bolt and drill with a drill bit smaller than bolt. If you use a left handed drill bit it will back out on it on some times. If not a easy
out will work.
1969 cst swb |
06-09-2008, 03:27 PM | #13 | |
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-10-2008 at 01:55 AM. |
06-09-2008, 05:34 PM | #14 |
Chevy nut
Heat always work for me. I havent heard about the wax trick in so long I forgot about it! I remember my dad doing that when I was a kid. Man I am getting old!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
06-09-2008, 06:35 PM | #15 |
I have an easy out set up. I bought it at NAPA for $12.00. Since I don't have a welder, my cigarette doesn't put out enough heat to heat up the bolt, and the wife won't let me take any of her candles, I though it would be my best option. So far it has worked the best for me.
06-09-2008, 07:06 PM | #16 | |
I'm old enough to be your dad!
06-09-2008, 11:45 PM | #17 |
give the bolt a few good smacks with a hammer.
06-10-2008, 12:01 AM | #18 | |
Sgt. Z
welder and a nut..........done deal......works for me every time!!
1967 Chevy SWB 1966 Malibu SS Convertible 355/420hp 700r4 and 373's with eaton posi Quote:
06-10-2008, 12:16 AM | #19 |
looking through all the other ideas looks like you would be done by now. If not, I guess the only idea left is if you can't get the bolt out of that block pull the motor get a new one once its installed run a bolt in a ways then smack it and break it off close to the block. Then try the above ideas again. If you still don't succeed then remove engine and try another one. sooner or later you will get that bolt out..... oh yeah.. keep in mind you don't have to have the engine in to break the bolt off. You can do that before you put the engine in too. The end result will be the same.
Good luck... I didn't say it would be the best idea i read through the others they took all the good ideas i just threw out the only one left.. OH yeah theres one more. .....nevermind my wife just said that one. It cant be a good idea then.......
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
06-10-2008, 12:25 AM | #20 | |
I have a radical idea!
Count slowly from 10... You're getting very sleepy... When you wake up, you will forget all about 67 C-30 calling you Pops. You will also give him a smoking deal on that rear bumper... You will wake on the count of three.. 1 - 2 - 3!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
06-10-2008, 12:26 AM | #21 |
BTW, I have used most all of the methods above, and I have found welding on a nut works better than anything if you have the means.
06-10-2008, 01:54 AM | #22 |
[Hijack ON] FYI on the Kroil. Kroil can be found at most large and high end firearms supply sites such as Brownells, Midway, and Natchez. You can buy it in aerosols or by the quart.
Once you go Kroil, you won't go back. I tried PBB, it worked OK, but I found that if I spray down a rusty bolt, and forget it for a few weeks, I have a gummy mess. Spaying my wet allen wrenchs to prevent rust was a BIG mistake. Kroil has never left my stuff gummy or rusty. [Hijack OFF]
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-10-2008, 02:02 AM | #23 | |
If the bolt was tight enough to break off, chances are the easy out will break too, then you have a big mess and will need to hunt down a carbide bit to try and get easy out removed.
06-10-2008, 02:43 AM | #24 | |
We may have respectfully agree to disagree. I have used reverse twist, i.e. "left hand" bits before. The end of a bolt is generally harder than the rest of the bolt. When trying to drill a bolt (with a left hand drill) to prepare to use an E Z out often times the twist drill will "bind" and back the broken bolt out. Having said all that, I use the heat/wax thing first. Also, why didn't you say anything about dropping in for the BBQ thing earlier? It's only a 12-13 hour drive from here. I lived in PHX (Maryvale area) for years. Before my son moved to SC, he lived in Surprise, worked in SW PHX. BTW, I love this site. El Jay
06-10-2008, 11:15 AM | #25 |
Hey what a bunch of great ideas. but Houp was right it would not budge. No welder close, and the left hand driil bit would not turn it. I got it drilled out late last night and will re-tap it today. lesson learned: if it aint going in, quit turning the wrench to the right. If that line is not famous yet it should be.Thanks to all who replied. keep the thoughts in mind for next time I have to help someone else with this problem. ( I lied i'm sure i will do it again). what a great site. Gary
