Old 06-26-2008, 08:42 PM   #26
Str8Ugly
Re: Show me your projects and builds
heres my 75 dually b4 i bought it.. its at the suspension shop right now getting bagged and body dropped
Str8Ugly is offline   Reply With Quote
Old 06-26-2008, 10:55 PM   #27
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Originally Posted by tvblazer78 View Post
I know what everyone is saying a pic of that thing again! But I would love to have a build forum for us.. So here you go before and after...
Check out the hills of TN in the background! WoW!
OH, almost forgot, nice Blazer too!
Kenny
87Lowrider is offline   Reply With Quote
Old 06-30-2008, 12:24 PM   #28
tvblazer78
Low & Fast!
tvblazer78's Avatar
Kenny
Thanks Kenny, I do love the Hills here...
tvblazer78 is offline   Reply With Quote
Old 06-30-2008, 01:25 PM   #29
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Heres my 74 I just got last week and my 79 Burb that I've been working on for a few years now.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 06-30-2008, 04:26 PM   #30
Str8Ugly
i like the burban
Old 06-30-2008, 04:28 PM   #31
gearhead1968
gearhead1968's Avatar
Here is my 1976 that I bought for $1,000 over the winter. I need some updated photos. I have lowered the truck, added power brakes, replaced all suspension bushings, tierod ends (inner/outer), center links, pitman arm, idler arm, upper and lower ball joints, wheel barings, rotors and drums, pads, calipers, hardware, wheels, tires. Basically everything under the truck.
1976 C-10 shortbed 2wd (work in progress)
Mods:
Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier
http://www.cardomain.com/ride/3136537
gearhead1968 is offline   Reply With Quote
Old 06-30-2008, 04:31 PM   #32
GMBowtie79
GMBowtie79's Avatar
Originally Posted by Str8Ugly View Post
i like the burban
Thanks, it's a labor of love and still no where close to finished. now I have another project to play with too.
Old 07-01-2008, 02:15 AM   #33
Primer70
Superbad
Primer70's Avatar
My 73 Suburban, I'm gathering parts to lay it out on the rockers.
Primer70 is offline   Reply With Quote
Old 07-01-2008, 02:38 AM   #34
duceducenine
duceducenine's Avatar
heres my crew
duceducenine is offline   Reply With Quote
Old 07-01-2008, 09:47 AM   #35
rddiaz
rddiaz's Avatar
Well I finally got my dropmember in (thanks nate) so I decided to get started on my build, here is a couple of pictures, goin to be layed out in a few weeks!!!
So I left the bed outside 1 day and I get a letter from the HOA can you believe that!!!
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 07-01-2008, 10:09 AM   #36
azfab
azfab's Avatar
your kidding man that *ucked up. lol my nabors called the city on me for welding in my garge lol $ss holes. man looks sick love the sqares! any mor pick? pb is the *hit! money though. i have a 86 wating to bag it wanto keep the bed. keep trucken
azfab is offline   Reply With Quote
Old 07-02-2008, 10:25 PM   #37
ChaseDale3and8
ChaseDale3and8's Avatar
Here's an update on mine. Just finished my 350! Got the rest of my parts that I needed to finish it up today, so here it is!
The build went like this:
350 4-bolt main block .030 over
#1182 Forged steel crank
Brand new GM powdered metal rods (had my machinist set up for floating pins)
Speed Pro 2 valve relief hypereuectic pistons
Melling 55HV high volume oil pump, new shaft with steel sleeve, pickup welded on
487 head castings that fellow board member Larry May gave me. Had them cut for 2.02 and 1.60 stainless steel valves, some port and polish work, and Comp Cams valve springs locks and retainers installed.
Comp Cams 268 Extreme Energy Cam. 224 degrees duration @ .050 lift intake and 230 degrees duration @.050 exhaust. Valve lift .477 intake and .480 exhaust respectively.
Comp Cams double row timing set, lifters, pushrods, roller tip rockers.
GM Performance Parts dual plane intake manifold.
Holley 4 barrel carb with vacuum secondaries. Plan to rejet later.
Ceramic coated shorty headers.
Lotsa and losta chrome and polished aluminum parts!
Enjoy the pics. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 07-02-2008, 10:28 PM   #38
ChaseDale3and8
A couple more...
Old 07-02-2008, 11:02 PM   #39
GMBowtie79
GMBowtie79's Avatar
I like your Burb. I've been wantin to bag mine but the back is a pain in the a$$. that and I use mine as a daily driver. Start a build thread so we can see how you do it.
This is what I'm workin with, I'd love to put it on the ground!
Old 07-03-2008, 10:15 AM   #40
pezzy
pezzy's Avatar
when i bought it for $500, a little rough running but nothing draining the gas tanks, cleaning the carb, new oil and all the filters couldn't fix...she fired right up and has been a sweetheart since.
I don't have any new pics (yet) but i have replaced the cab corners, corners of the wheel arches and a chunk of the bed floor. Right now shes in her first coat of primer and i'm just trying to get some time to block it and lay down another coat, block, paint, clear and drive her.
Oh and I'm still collecting parts for the engine rebuild that's in the near future.
pezzy is offline   Reply With Quote
Old 07-03-2008, 09:22 PM   #41
mrenj23
mrenj23's Avatar
This was my dads truck since I was born. Now it's my 4 year project. There has been school, jobs, marriage and now a brand new baby boy. It seems like it will never get done but I'm still grinding away at it.
mrenj23 is offline   Reply With Quote
Old 07-03-2008, 09:44 PM   #42
S10Fan
Old Heap Driver
I'd say you're doing quite well at your current pace!
Look'n Good!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-04-2008, 12:10 PM   #43
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Well my pics are in my sig, but its always fun to show from whence it came to what it be now.. Currently its waiting for me to put plates on, hook up some gauges, swap a cam and intake on the 454, and set the TV cable correctly. Future plans are dropped spindles and springs in front, dropped shackles and a flip kit out back, because right now it has the ghetto blue wrench drop and its sitting on the snubbers. Also gonna replace the box sides, cab corners, rockers, and doors.. then repaint it again..
Still its a beater truck, and if it didnt get 10mpg due to the smogger 454 it would be driven already.. I need my truck running.
From this, with a Pontiac 400 I stuffed in when the 305 died...
Then some sanding and grime removal..
Stuffed a grimy old rat in it..
In bright light before the mirrors when on.
The paint, a bit of buffing, and putting all the stuff back on..
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 07-04-2008, 10:32 PM   #44
bigoates
bigoates's Avatar
Current project truck.. 1974 Chevy Crew Cab from AZ.
Previous owner put the cab on a std cab long bed frame, cut the floor in 2 spots where rails bump up and had intentions of a short bed truck.
I have since replaced the missing floor pan pieces including fabbing up 2 sections of the crossmember to bring the cab back to stock.
Plan is to build a CC stepside 4 linked lifted truck on rockwell rears.
Just finished media blasting it on wed. Im in for the long haul now!
This pic is how I found the truck with a complete interior, nose, doors etc..
bigoates is offline   Reply With Quote
Old 07-04-2008, 10:40 PM   #45
bigoates
bigoates's Avatar
This is just after I blasted the floor, firewall, and rockers on wed(the areas that are a pain in the A$$ to clean up by hand)
Will be starting on the full tube chassis shortly..
http://
Old 07-05-2008, 11:27 PM   #46
flamingbig10
6.0 powered square
flamingbig10's Avatar
1980 Silverado
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
