Old 07-11-2008, 12:39 PM   #26
hotrodsbyray
Re: Installing Bear Claw Latches
hope these pics work. lock cylinder has a cable running to a little box. the cable pulls a lever to which a rod could be attached. the rod would run to the bearclaw latch
hotrodsbyray is offline   Reply With Quote
Old 07-11-2008, 11:40 PM   #27
GRIMSS
GRIMSS's Avatar
Thanks for the pic.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 07-13-2008, 02:33 PM   #28
weldvair@embarqmail.
Smile Re: Installing Bear Claw Latches
I put the latch on the cab to keep the solenoild dry. I open the door mech. from a threaded rod that is bolted to the latch & has a alum knob att to the other end...you push the knob down to open from the inside or hit the botton on your key chain to activate the solenoid.
Don Meyer - Mech Eng
weldvair@embarqmail. is offline   Reply With Quote
Old 07-29-2008, 07:34 PM   #29
prostreeter58
prostreeter58's Avatar
Well I figured since I was updating the doors I might as well do some work to the motor...........I install a Howards crank (big block snout, small block crank) because I had been having problems with spinning the balancer on the crank......turned into quite an expensive fix...........here are a few pics.....
prostreeter58 is offline   Reply With Quote
Old 07-30-2008, 07:36 AM   #30
entourageguy
Yellow truck club
entourageguy's Avatar
shiny.......
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 07-30-2008, 09:39 AM   #31
YOLO
Custom Truck Lover!
YOLO's Avatar
nice ride. keep up with the pictures.
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-31-2008, 08:42 PM   #32
Hhan's 57
Hhan's 57's Avatar
Now that is a work of art...can I drive it
Hhan's 57 is offline   Reply With Quote
Old 08-03-2008, 12:12 PM   #33
prostreeter58
Well I should be able to fire up the motor today, then I can get back to finishing up the bear claw latch install................here is a pick of the motor as of today.............
Old 08-03-2008, 12:15 PM   #34
prostreeter58
also if anyone is interested in a complete disc brake setup for a Mustang II front end, here is a pic of the one I took off of the truck. It has probably less than 500 miles on it and the calipers are ceramic coated........I will be taking the backs off soon and they are for a F@#D 9" with internal emergency brake and ceramic coated calipers as well.............just make an offer.............
Old 10-11-2008, 04:02 PM   #35
prostreeter58
Well it has been a while since I have added to this thread............here are a couple of pics that I took today after I got the electric openers working.........it turned out to be a very easy conversion and I used the original rod that was between the door handle and the latch.......hopefully these pics will show what is involved, however, if you need a specific part addressed let me know.......
Old 10-11-2008, 04:03 PM   #36
prostreeter58
couple more.................
Old 10-18-2008, 09:05 AM   #37
prostreeter58
here is what the panels look like installed.......................
