06-27-2008, 05:37 PM | #1 |
Installing Bear Claw Latches
Well when I decide to do something I just can't wait, and this was the case today. I have been wanting to install bear claw latches but really didn't want to cut my doors or the cab. Oh well, I did it anyway. Figured it couldn't be that difficult and it really wasn't. Just had to sit and look, think, look, and think some more. I wanted to install them so I could move my electric openers off of the doors and make it where I could use the original door panels..........here is where I am at so far. What you see is about 4 hours of looking, thinking, cutting, cussing, welding, cutting, cussing........ect.
06-27-2008, 05:41 PM | #2 |
Re: Installing Bear Claw Latches
a few more.......................
06-27-2008, 06:05 PM | #3 |
Glad to see you are taking plenty of pics for us TF guys. Your install looks great so far.
You've got a set. I would have hated to cut and weld on a truck that looks as nice as yours.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
06-27-2008, 06:19 PM | #4 | |
It wasn't an easy decision............just decided to do a bunch of upgrades and this happens to be one of them..............you will be seeing a lot of changes posted in the next couple of weeks.......... |
06-27-2008, 06:27 PM | #5 |
I take those are the large bearclaws?
*just saw that you didn't even take the seats out when you welded. New seats in the changes.
06-27-2008, 06:29 PM | #6 |
Any pics of how much you cut out where the latch goes?
06-27-2008, 06:42 PM | #7 |
na....I use a tig welder much easier to control the heat. I will take more pics of the opening when I cut the other side................I believe these are the small bear claw because they only have 2 positions on the latch. I have had them for several years. (that's how long it took me to get up the nerve to cut the holes!!)
06-27-2008, 08:21 PM | #8 |
Tripple Five Fanatic
Interesting, what mechanism are you using the open the door or release the latch?
06-28-2008, 09:43 AM | #9 |
I could be wrong but it appears those pieces need to be swapped. Latch goes on door. Check out this article detailing the install of bearclaw latches.
http://www.rodandcustommagazine.com/...all/index.html |
06-28-2008, 10:24 AM | #10 | |
06-28-2008, 10:27 AM | #11 | |
06-28-2008, 10:32 AM | #12 |
OK. How is the latch released? Most are attached by a cable to the door handle. But I suppose an electric solenoid like Autoloc offers will work.
06-28-2008, 10:33 AM | #13 |
Just wondering how do you open the door with the claw on the post of the cab?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
06-28-2008, 10:58 AM | #14 | |
I have built several fail safe points into the system, however, they are all dependant on a battery. Also, you can open the door manually by reaching behind the pillar and pushing the lever. But mostly the doors will be opened electronically...............a button on each door and a remote. |
06-28-2008, 12:39 PM | #15 |
I know Autoloc makes an emergency release cable that you might consider. My concern for you is if for some reason you needed to get out in an emergency and the power were to fail you might have a hard time getting out of your truck. Just want you to stay safe!
06-28-2008, 02:41 PM | #16 | |
I understand your reasoning for doing it this way and want to actually see how it works. I'm thinking that this method would not work for me because I want to cover behind the seats which would cover/block access to the latch if I were to use your method. Thanks for posting this info. Tri5 Last edited by Tri5Nerd; 06-28-2008 at 02:42 PM. |
06-28-2008, 05:13 PM | #17 |
I did my bear claws the same why. Check it out at http://71.65.61.198/web/photos/toms_...icture110.aspx. This way the solenoids can be mounted right below the latches. This is a unusual why but I think the best way. I have seen it done on outer cars and trucks. My brother did it this way on his truck. Here is a picture of his truck where you can barely see the latches http://71.65.61.198/web/photos/48_gm...picture11.aspx.
Tom Meyer |
06-29-2008, 10:37 AM | #18 | |
06-29-2008, 12:37 PM | #19 |
Hollister Road Co.
I like the idea of the latch in the post, why couldn't you use a cable from the original inside door handle to the latch, It would be long but cables don't care, Run it like you would a power window wire out the door then down under the rocker up to the latch. You could have a switch in the original outside handle to operate the latch and popper and the emergency cable hanging under the cab corner if the battery died.
06-29-2008, 12:53 PM | #20 | |
06-29-2008, 09:33 PM | #21 | |
But you could run the cable up the rocker to just below the dash and have it in the positon like a vent pull.
07-01-2008, 03:34 PM | #22 |
I like this installation location better too. I would never do shaved handles in any of my cars because of all the issues I have seen others have when they become out of adjustment; or just plain quit working. It's hard to get the door apart when its closed.
I saw them done this way a few months back on a 51 a friend of mine was painting. Very clean and pretty much fail safe since you don't ever have to depend on the latch thats now hidden in the door. I also had the same idea for a pull cable as well. The installation I saw the latch was barely visible in the door jamb and was actually mounted behind it with the only opening visible was for the striker itself. I thought with it there you can actually just reach behind the jamb on the inside of the truck and release it or you could run a cable down the inside corner of the cab and drill a hole with a grommet under the cab corner for emergency entry. Nice work so far on this one. I was interest on how this would work and look on a TF truck. Thanks for posting!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 07-01-2008 at 03:37 PM. |
07-03-2008, 03:45 PM | #23 |
i'm thinking of the same set up. i think i will run a cable from the latch release on the bear claw to a lever or handle of some type on a console so i can use it manually from inside. i am gonna use the trunk lock from an 88 camaro as an emergency latch if the solenoid fails. it is the lock you put the key in to open the hatchback of the camaro. the lock cylinder has a cable that runs to a lever already on a little mount. will put the lock either on the inner part of the "fin" behind the door or down on the rear part of the cab corner. inconspicuous but not where i have to get on my back or contort myself to reach it. maybe i could find or make a little door to cover the key hole.
07-03-2008, 04:13 PM | #24 |
hotrodsbyray- you got a pic of that camaro lock. I like the sound of having a backup that uses a key.
07-10-2008, 06:22 PM | #25 |
i'm trying to upload some photos but so far no such luck!
