#26 |
Re: Lets see your exhaust exit locations!
#27 | |
Navy Radioman Veteran
Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
#28 |
Here's mine.....2.5" stainless
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
#29 |
Mine turns down just before the rear bumper. Ya can't see it but ya can sure hear it.
'79' shortbed |
#30 |
My truck is an alcoholic
I would post a pic, but I am quite sure it would result in a perm ban,.,.,
#31 |
not a close up but you get the point...I'm planning on finding a new exhuast system with an H or X pipe one day soon. When that happens i may have to change the exit location, im not sure how much i like where they are now.
JG If you can't find it at the junk yard you don't need it. |
#32 |
Heres what i did on my 76...made out of 2.5" pipe that was laying around, flowmaster 40's, and the headers I used to run on my nova.
#33 | |
I'm just glad to be here!
http://www.spintechmufflers.com/spin...ntechindex.asp
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#34 | |
Sorry it's been so long getting this back to you.. been tied up at hospital with Mom. Here you go: ![]()
#35 |
I'd love to see that on a '67-'72.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#36 |
BAD BOW-Silverado XST
I pull the truck partially out of the garage if I'm running the engine. If you stand around the bed you'll smell the fumes. Especially around the tailgate. If you get down around behind the truck, you definately feel the heat.
#37 |
![]() Join Date: Mar 2006
Thanks for the pic man. I should be getting my exhaust on by the weekend.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#38 | |
Spear and magic helmet!
http://www.73-87.com/7387info/misc/bsb_2.jpg **update** Well, I looked through all 37 pages of feature trucks on that site and couldn't find it. Oh well. The rollpan had two semi-circular cutouts at the bottom where the exhaust tips came through. It looked pretty cool.
-- Will Last edited by killthewabbit; 08-05-2008 at 03:26 PM. Reason: can't find it |
#39 |
I like turtles...
i have mine as turn downs at the rear axel after my 5/7 drop. its loud as hell, but that because i have strait pipes goin to the turn downs. in my opinion if its lowered, its better not to see them unless they are in a good lookin place, but thats just me.
#40 |
I don't think these pills work
i have long tube headers into 2.5 inch pipe then 40 series 2chamber flowmasters with 3 inch dumps in front of the axle. they used to dump under the cab but that was way to loud.
SQUARE84 ![]() 90 SUBURBAN |
#41 |
What does the X pipe do?
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
#42 |
Balances out the exhaust pressure from side to side. A H-pipe does basically the samething, although x-pipes typically make more power by design.
#43 |
My truck sounds like this Vette. I have dual Magnaflows and Xpipe.
http://pysales.com/movies/99corvette...es-racepro.MPG X-pipes explained http://www.pypesexhaust.com/xpipes.html Dumping before the axel is noisy for any muffler. Especially inside the cab. Last edited by gchemist; 08-06-2008 at 05:49 AM. |
#44 |
Thanks!!!
#45 |
Totally. Dumping the exhaust under any car/truck will make it louder for no other reason but because the exhaust note echoing off the ground and echoing off anything under the car/truck chassis, etc.
#46 |
Resident of Here
? Huh?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#47 |
![]() ![]() ![]() the driveshaft was out in the second pic, hence the plastic bag and caked on oil all over the xmember |
#48 | ||
#49 |
if no pipe is to be added that should be nice and loud
#50 |
Here's mine(side exit)
X pipe is a must!!! ![]()
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 08-18-2008 at 02:38 AM. |
