#26 |
Re: LFD's some day 2wd Blazer Build
#27 | |
How low do you want to go with one? If you want it down with the rest of the cool kids Dad's rigs you might as well just get a PorterBuilt DropMember for the front and a 4link set up for the rear and be done! Kevin LFD Inc. |
#28 |
![]() Join Date: Aug 2005
How about ZERO with no drop spindles, or with bigger wheels, or with less negative camber
![]() Last edited by Frizzle Fry; 10-17-2008 at 10:11 PM. |
#29 | |
Why would you want to keep stock 30+ yr old spindles on what will end up being a very expensive rig when you can get the latest in metal process and design with new drop spindles. Just how big of a tire do you want because the last time I checked fender blisters were not meant to conceal your tire popping through the top of your hood! Negative camber, that is so before the modern world of the DropMember! Do you kids make you drop them off a block away from school so their friends don't see you ![]() J/K almost ![]() Kevin LFD Inc. |
#30 | |
The LuvShack Garage
![]() And I know were a flawless restored one is for sale or trade you could get ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#31 |
Just pointing out that there are attributes that make the 4x4 frame desirable for dropping. It may be more suitable for those who do not want/afford to use a dropmember (who wouldn't want one...). You have a 2wd that's getting a DM and I won't argue that it's a great plan. Would I put a 2wd on a DM with a big 'ol step notch if I already had one available?: In a heartbeat. Hell, I'd probably cut the floor out and sink the tub down over a full C5 roller
![]() As far as the kids; you'll have to ask them what they think of their Dad's rigs ![]() |
#32 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I say start with a couple of dropmembers front and back and build your own frame like josh did with his truck. I am sure that what ever you do will be approved of and as far as cutting up 2wd blazers...................who cares its only metal as someone once said.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#33 |
Next project: 1970 K10
Great discussion guys, thanks!
He wound up getting the Blazer dirt cheap, just as well been free. Needs more work than he thought. It has truck doors that have been cut, no rear hatch, and it needs some serious glass work on the top. But the tub is cherry.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#34 | |
OK I missed something! Kevin LFD Inc. |
#35 |
Oops. Forgot I made another thread in this forum. It's only my third time in here!
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=309754 Turns out not to be the sweet deal he thought it was, but he ended up getting it for an equivalent of $500. Dad is doing some excavating for this guy, and is taking $500 off his bill for the Blazer. He wants to make a 2wd out of it, and put the extra 68 front clip on it that we have. Does anyone make an aftermarket top for these, or do we need to find someone good with glass? Sorry for the hijack Kevin!!
#36 | |
I don't know of an after market top unless you go with a soft top. I am thinking about building my own out of Alum once I get my wheel and bead roller set up. Fiber glass is not very hard to work with if you find an OK top to start with. Kevin LFD Inc. |
