Old 03-03-2019, 08:33 AM   #26
70 shorty
Where's my beer?
70 shorty's Avatar
Re: Installing Fender Emblems
Just wanted to update this thread. I was linked here by Lockdoc from a thread I started and the exact clips shown above also worked perfect for mounting my C10 emblems on my 70, and my local Napa had them on the display carousel, so they didn't even have to be ordered.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 03-03-2019, 09:08 AM   #27
72c20customcamper
72c20customcamper's Avatar
I used barrel clips last summer for the fender emblems. Got them from Amazon
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-03-2019, 05:30 PM   #28
BugzC10
BugzC10's Avatar
Part Number?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-05-2019, 08:29 PM   #29
72c20customcamper
Originally Posted by BugzC10 View Post
Part Number?
The package is in my truck about an hour from me at my moms garage just search 7/16th barrel clips I believe they shipped from retro motive Bought a few things from them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-05-2019, 09:01 PM   #30
leddzepp
Moderator
leddzepp's Avatar
Barrel clips were used from the factory on the Cheyenne super glovebox emblems and the upper tailgate moulding center piece. I’ve also seen some custom camper door emblems that have them instead of the speed nuts. They do work very well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-31-2020, 03:10 PM   #31
s55mercury66
I know this is an old thread, but it comes up nicely in a web search. I attached mine a little differently. Since my inner fenders are out, but my fenders are not off, I used a barrel clip on the rearward hole, and a speednut on the forward end. The emblems on another truck with the upper molding like this one has, were 3 6/16" from the rear fender edge, and 11 1/8" down from the top fender edge, that measurement being right through the center of the "M", to the lower, outward edge of the emblem. It's hard to find info on the GMC, so I will keep adding what I can as I go along with this one.
s55mercury66 is offline   Reply With Quote
Old 01-31-2020, 03:28 PM   #32
maverickmk
maverickmk's Avatar
Here's a link to some on Amazon:
https://www.amazon.com/Retro-Motive-.../dp/B07FC22NWK
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 02-01-2020, 05:02 PM   #33
LockDoc
The Older Generation
LockDoc's Avatar
Wow! Glad this is still useful and members are adding information to it.
Thanks,
LockDoc
Leon
Old 04-23-2020, 04:22 PM   #34
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Cool as heck Leon. I know the clips are a 10-24 thread, and of course badges are a tapered stud. I haven't bought the barrel nuts yet, but would like to ask how they work. I take it they compress on either stud type, and part's are removed by squeezing the tabs on the back, right?
I suppose they're too long for the front lower door molding clip, due to clearance of the door hinge? I came to the realization the studs on door trim clips are supposed to be cut. At the very least the lower front clip, because if you don't you'll soon wish you did. Otherwise those barrel nuts are cool in a pinch.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 04-23-2020, 08:42 PM   #35
LockDoc
LockDoc's Avatar
Yes there are two small tabs on the back that you have to squeeze in to get them back out. I don't know how they would work on the molding.
LockDoc
Leon
Old 04-23-2020, 09:19 PM   #36
71CHEVYSHORTBED402
LockDoc
Thanks Doc
Tony
Old 04-23-2020, 09:31 PM   #37
Richard2112
Richard2112's Avatar
Thanks for the refresher, Doc. Those clips are the bees knees. Used'm years ago on my truck mirror.
Richard2112 is offline   Reply With Quote
Old 04-23-2020, 11:32 PM   #38
LockDoc
LockDoc's Avatar
Thanks Doc
No problem guys. Thanks.
LockDoc
Leon
Old 04-24-2020, 09:15 AM   #39
bigmac73
bigmac73's Avatar
subscribed
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-12-2020, 11:26 AM   #40
bigmac73
bigmac73's Avatar
Here ia my question when installing aftermarket fender what do you use as a template and guide for drilling new holes for the emblems
Mike
Old 05-13-2020, 09:23 PM   #41
LockDoc
LockDoc's Avatar
I always measure the old fender for the hole location or the fender on the other side of the truck. I'm sure if you post what year your truck is and a picture of the emblem you are installing someone can supply the measurements for you....
LockDoc
Leon
Old 08-15-2023, 09:03 PM   #42
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I was thinking about these barrel nuts and wondering if I could get my "Super" badges on before taking my fender's off for another task. Though the problem is getting the holes drilled properly under the "Cheyenne / 10" emblem.
Might anyone know where the holes would be from measuring from the "Cheyenne / 10" emblem?
I am thinking not and if I wanted to do this then I should cut the stubs off and go the "3M" route - which I don't think I want to do. Anyways, I thought I'd ask.
Edit:
3M really not a option, the back of the Super is hollow except where the studs are. I didn't want to cut them anyways lol
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 08-15-2023, 10:42 PM   #43
LockDoc
LockDoc's Avatar
Edit:
I don't have any Cheyenne trucks or fenders any more. The fact that the back of the emblem is hollow is the main reason I didn't want to use the tape.
LockDoc
Leon
Old 08-15-2023, 10:52 PM   #44
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Thanks for the thought Doc, drilling from the mounted Cheyenne badge is likely very dodgy anyways ;-)
Richard
