Old 12-13-2008, 09:10 PM   #26
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Its an addiction
Amazing what $12 worth of engine paint and a few cans of carb cleaner will do, Hopefully I can give this beauty a home before too long, I regasketed it found out the block was painted with hot lap on the inside and the rotating assembly is balanced with some nice looking aftermarket pistons as well
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 12-14-2008, 01:39 AM   #27
caminokid
Chevy nut
caminokid's Avatar
I truly believe its an addiction. I cant seem to stop getting 69's for some reason.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-14-2008, 01:52 AM   #28
chevychase
chevychase's Avatar
Seems to be no shortage of parts around your neck of the woods. And boy that motor sure did clean up nicely!
chevychase is offline   Reply With Quote
Old 12-14-2008, 02:17 AM   #29
phipp13
THE DAMN YANKEE
phipp13's Avatar
god i love them trucks! too old and busted up to be climbing up in them. v/r phipp13
phipp13 is offline   Reply With Quote
Old 12-31-2008, 12:02 AM   #30
bigbadchev72
People know me
Well got a little free time and a clean garage, so I brought it over to my house and found a home for the 400, Looks to be in BAD need of a new harness, not only is it hacked, it is extremely brittle. I put in some Warn premium hubs and I got the beauty rings and caps on.
Any suggestions on AFFORDABLE wiring harnesses? I have a summit brand in my blazer and am really happy with it other than the fuse block, It has the mini fuses and the location of fuses is on the cover. Also, What do these plugs in the engine harness go to? The first one is in with the starter wiring and 2 green wires going to it, the other is attached to the drivers fender well.
Old 12-31-2008, 02:10 AM   #31
lytemup454
lytemup454's Avatar
sweet looking build you have i just found it. I live in pendleton but work near hermiston. I'd love to check out your blazer some time.
lytemup454 is offline   Reply With Quote
Old 12-31-2008, 02:39 AM   #32
Gray Ghost
Gray Ghost's Avatar
Gotta love the small window trucks....great find!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-31-2008, 10:22 AM   #33
CPNE
Resident Curmudgeon
CPNE's Avatar
Wire 1 - Backup light switch on 4 speed tranny. Truck was originally a 4 speed.
Wire(s) 2 - Alternator. Stock alternator location is on LH side of engine
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-31-2008, 09:19 PM   #34
bigbadchev72
People know me
Anyone have suggestions on wiring harnesses?
Old 12-31-2008, 10:08 PM   #35
lytemup454
lytemup454's Avatar
make one that is suited for your truck. i went and bought the wire from napa and only used the wire tat i needed. Bought bulk trailer wire, it ad 10 dfferent ires and it heav gauge wires in it. I did the hei convertion at the same time so that made it simpler when doingthe ing. and starter wires but is reall simple wen you use the diagram
http://67-72chevytrucks.com/vboard/s...wiring+diagram
then i used the clips in this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
make it work for you!
Old 01-22-2009, 02:11 AM   #36
bigbadchev72
People know me
Changed out the drivers exaust manifold, i had 2 passenger side ones.
I also changed out the custom draglink and will be having a new driveline made due to custom modifications
Got some pictures of the guages installed and the dash painted up, started on a rear bumper for it, and will be going in for dual 2.5" exhaust with H pipe and flowmasters in the next few days
Old 01-22-2009, 09:53 AM   #37
theyammieguy
accepting donations
theyammieguy's Avatar
I say go with a real dark red.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-22-2009, 06:31 PM   #38
NEVERENOUGH
NEVERENOUGH's Avatar
I would love to see some side pics of the truck. Trying to figure out how much lift to use on mine.
NEVERENOUGH is offline   Reply With Quote
Old 01-22-2009, 07:32 PM   #39
bigguy69
dazed and confused
bigguy69's Avatar
just found thread and yes it is an addicition but i love it
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-21-2010, 08:39 PM   #40
bigbadchev72
People know me
A little update. I need to add a bunch more pictures. Ive been doing a ton of block sanding and as everyone that has done that knows there is a ton of work involved, but not a whole lot to post pics of. I have bought a ton of parts for it, New poly bodymounts, spring bushings, stainless braided brakelines, new gauge cluster, door sills, weatherstripping, and new wiring harness.
I finally deceided on a color Its sunburst orange metallic. Base/clear. My paint guy has some serious shoulder problems and is going in for surgery this week. So he is going to teach me how to paint. I got a little gun time last sunday and did the inner side of the grille, inner fenders, inside of the fenders and the underside of the hood. Im happy with it overall, I did no prep work at all on any of the pieces painted other than wiping the crap off them and wiping them with solvent.
I also filled in a bunch of the firewall holes filled in as well and got some Als Liner and sprayed the bed, tailgate, interior, and firewall with it. I am really happy with how easy it layed out. I had it tinted body color as well. I was getting up under the dash and spilled a little on the driverside floor board, but Im gonna be running carpet and a dynamat knockoff.
Old 02-21-2010, 08:49 PM   #41
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
thats an AWESOME truck you've got!!!! Cant wait to see it done.
John
1999 Toyota Tacoma 4x4
Old 04-03-2010, 11:37 PM   #42
montsb
montsb's Avatar
Nice shooting Tex! Lol! That color is beautiful/sexy! Looks yummy! I just LOVE your Blazer though!
montsb is offline   Reply With Quote
