Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-21-2008, 12:21 AM   #26
whatnow123
whatnow123's Avatar
Re: Shocks and weight transfer
Originally Posted by Super73 View Post
Yes, but the correct spring would make more of a difference.
Do you know what your truck weighs and what the front or rear weighs?
Any idea on how I can weigh the front and rear? I could go to the dump and get the total weight, but I don't have a clue where I could go for the front/rear.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 12-21-2008, 01:48 AM   #27
Heavy Evy
born to lose
Heavy Evy's Avatar
Again, assuming 10% slip which is very, very high, 88mph with 31" tires, 4.10's would equal 4,350 through the traps.
I would assume a stock converter is probably closer to 5% slip which would be 4,150 through the traps.
If you spin the motor to 5,500, the 3.42's are going to make it even worse. Right now, the steeper gear is multiplying your TQ and making you go faster. Generally speaking, you want as much gear as you can for best ET. You just don't want to run out of RPM before the finish line.
You would be better off putting a looser converter in the truck. Also running a shorter tire with yuour current combo.
The looser converter will get you in the power band faster, multiply TQ as your leaving and get your shift extesions shorter helping to keep you in your power band.
With a 26" tire, 10% slip, 5,500rpm your looking at 93.3mph.
Speak of the devil I have some 26 inch slicks I picked a few weeks ago for cheap. What size and kind of converter would you recomend? I'm trying to get this truck into the 14's/13's and keep it capable for the street.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 12-21-2008, 03:53 AM   #28
Super73
Super73's Avatar
Whatnow,
Any truck scale or dump scale can do it. Just weigh the front axle then get a total weight. Your rear weight is just to total minus the front..
Heavy,
Can you give us a little info on your motor. Cubic inches, Cam, headers, intake, manifold. All that comes in to play with selecting a converter. If I had to guess, with keeping it streetable with out a lock up converter, I'd say 2,400-2,800 rpm is about the biggest I'd go.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-21-2008, 11:33 AM   #29
Heavy Evy
born to lose
Heavy Evy's Avatar
Heavy,
Motor is a 383 stroker edelbrock performer intake,edelbrock carb 650 cfm, roller rockers,268 comp cam, 160 202 fulie heads hedman headers 2 and a 1/2flowmaster dual exhaust.
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 01-05-2009, 05:39 PM   #30
whatnow123
whatnow123's Avatar
Kevin is correct. If you can give me actual axle weights, I can help you out. Also, what are you looking for ride height and are you using a drop spindle?
Hey,
I have the weight of my truck. I'm not sure exactly what you need but here is what I got.
3800 total with me in it.
1480 rear with me in it, so that would make the front 2320.
I'm 190lbs and I had a 1/4 tank of gas. The tank is in the rear, so a little more weight could go over the rear with a full tank.
Build thread:
Old 01-19-2009, 12:50 AM   #31
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Hence the reason I built adjustable lower control arm brackets for the trailing arm set up in my truck.
Hope this isn't a highjack.
Super73, would you post some pics of your adjustable brackets with any details you deem pertinent?
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 01-19-2009, 02:34 PM   #32
Super73
Super73's Avatar
a1953mdl,
I created a link in the high performance section with pics and details. A quick search will most likely find it. If you have questions that aren't answered in that thread, go ahead and post them there. I'd like everyone to have the info under one thread..
