Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-16-2008, 01:16 AM   #1
whatnow123
whatnow123's Avatar
Shocks and weight transfer
Would switching out my rear (or front) shocks help make the rear squat more for better traction? I'm currently running monroe "stock" shocks but think a little more weight transfer would help hooking those rear tires up..
Any advise on what shocks to use?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 12-16-2008, 01:51 AM   #2
Super73
Super73's Avatar
Re: Shocks and weight transfer
Yes, but the correct spring would make more of a difference.
Do you know what your truck weighs and what the front or rear weighs?
If not, find a local scale around you, weigh it and I can get you in the ballpark for correct spring rates.
Another thing would be to modify the lower control arm bracket to get your instant center of gravity lower which induces squat. But again, with out the right spring rate, it's not going to compress the spring.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-16-2008, 11:42 AM   #3
djracer
djracer's Avatar
Yeah what he said!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-16-2008, 09:38 PM   #4
LuckyHenriksen
LuckyHenriksen's Avatar
How does getting the proper spring rate affect ride height? Is it possible to have springs that help you launch well and also let you keep your 4/6 dropped stance?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-16-2008, 10:32 PM   #5
djracer
djracer's Avatar
yes that's possible! You need a soft front spring with a bunch of stored energy.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 12-16-2008, 11:55 PM   #6
LuckyHenriksen
Where would someone find these soft springs
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-17-2008, 02:25 AM   #7
Super73
Super73's Avatar
Give me the weight of your vehicle and I'll give you spring specs to look for.
What I did was take that info and called Moroso to find a spring that fit my needs. They told me though that the spring I thought was going to work for me was the wrong spring and wouldn't be right. Yet it was the perfect ride height and as you can see from the video in the link, tons of stored energy on the launch. So much that I moved the shock form the 90/10 setting to a 70/30 and it still was too much. Hence why I am swaping shocks again.
when you know the weight, it's easy to figure out what you need as our leverage ratios are the same.
Old 12-17-2008, 09:12 AM   #8
LuckyHenriksen
Ok when I put it back together I'll scale it and let you help me =]
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-17-2008, 10:19 PM   #9
Heavy Evy
born to lose
Heavy Evy's Avatar
I like this thread. My 71 C20 with me in it about 4800 lbs. What would be a good spring for me?
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 12-17-2008, 10:33 PM   #10
djracer
djracer's Avatar
you would need a front and rear weight.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 12-17-2008, 10:38 PM   #11
Super73
Super73's Avatar
Kevin is correct. If you can give me actual axle weights, I can help you out. Also, what are you looking for ride height and are you using a drop spindle?
Old 12-18-2008, 01:04 AM   #12
Lx3
Lx3's Avatar
All that gets you closer but it's a combo just like motor, convertor,
gears etc.....
Front/Rear ratio, spring rate, shock ratio, I/C, even contact patch and
sidewall stiff come into play. You can take it as far as you care to go.
I've heard the PRO STOCK boys are running electronic shocks that
change rates 32 times in a pass. WOOOF
Sorry, I've got to say this again.
Find a book called AUTO Math by John Lawler
Lx3 is offline   Reply With Quote
Old 12-18-2008, 01:20 PM   #13
Super73
Super73's Avatar
LX3,
Im sure the book is a good tool and you are right, there is a lot to any combo. But with out real world trial and error, you never get it all figured out. All I'm trying to do is help people get moving in the right direction. I feel that's all the book is doing too, just like Suspension Engineering by Herb Adams or the Dave Morgan seminar DVD set I have (Which is awesome BTW). There is soo much too it that I don't think any book could possibly have all the answers for all the different combs out there, but rather a good foundation and start. But I have been known to be wrong before I will look for the book.
Old 12-18-2008, 01:24 PM   #14
Super73
Super73's Avatar
I'm assuming this is the book.. BTW, his last name is Lawlor. You threw me off for a few
http://shop.ebay.com/items/?_nkw=aut...wler&_osacat=0
Old 12-18-2008, 10:02 PM   #15
Heavy Evy
born to lose
Heavy Evy's Avatar
No drop spidles just stock height. I'm not sure of the front or rear just the total haha but that don't help much.
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 12-19-2008, 08:16 AM   #16
Wild83C10
Wild83C10's Avatar
I'm not so sure you want the rear to squat, you lose a bunch of energy/power. You actually want the rear of the truck to raise up. This actually unloads all of the energy from the suspension to the tires. Another way is to have the rear end stay at its height and have the front end come up so the CG raises and shifts the weight from the front to the back. I've never seen the rear ends squat on cars/trucks setup for drag racing. When the rear end squats you affect your driveline angles which could actually hurt you more then help you.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-19-2008, 06:41 PM   #17
Super73
Super73's Avatar
I agree with 383 and he has a solid point. Antisquat is going to load the rear tires more "if" you have enough enough stored energy for front end travel. Antisquat "hits" the tires harder and forces them in to the ground by raising the frame and body. But, and this is a big but, if your front end is not coming up to transfer the weight, all antisquat is going to do is move that weight further forward when there is rear seperation. Antisqaut also is also antiraise for the front to an extent.
So if your instant center of gravity is above your true center of gravity then you will induce antisquat, if it's bellow you will induce squat.
Squat puts energy that could be used to move the vehicle forward in to the chasis. Some times you need to put that energy in to the chasis.There are times that you need to lessen antisquat or even induce squat. For instance:
If the track is going away and you can't loosen up the front end anymore than it is through the front shock, you might want to take some antisquat out of the chassis.
Or when track prep is next to nothing.
Or on the street (sorry, just putting it out there).
On a well prepped track with proper suspension adjustability, you would be wise to put antisquat in to the vehicle. Hence the reason I built adjustable lower control arm brackets for the trailing arm set up in my truck.
Old 12-19-2008, 09:21 PM   #18
Heavy Evy
born to lose
Heavy Evy's Avatar
A little off topic but I think my biggest problem is Im topping out a little bit after half track. Im going to put 3.54 gears in the rear to see if that helps I think the 4.10's are to low since my truck is so heavy and the motor doesn't go to 8 grand(atleast I haven't gotten it that high).
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 12-19-2008, 09:54 PM   #19
djracer
djracer's Avatar
What size tire do you have?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 12-19-2008, 11:29 PM   #20
Wild83C10
Wild83C10's Avatar
Super73, I think you got it right. Good explanation.
turbo=
Old 12-19-2008, 11:56 PM   #21
Heavy Evy
born to lose
Heavy Evy's Avatar
I haven't ran my new tires which are 285/60/16's in the rear, The tires I used when I ran at the track were 31/10.50/16.5's, im probably going to get some slicks 29 inchers for the drags next summer.
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 12-20-2008, 12:43 AM   #22
Lx3
Lx3's Avatar
Super 73
I have used this book for many years and found it to be soooo close
it'll spook ya'. Real world conditions allways effect any combo but
that too can be calculated. I've had 3 combos run within .20 out of the
shop and off the trailer. Is that good enough? Hell NO. But it's sure not
a bad place to tune from. I'm 51 and still learning. I 've been real lucky
to be able to watch and listen to some guy's that are real pro's and have set
world ET and MPH records [Randy Merrick, Javier Silva, Earl McCoy] and
they get beat too. Everybody's lookin for that edge and personally that's
my favorite part. Someday I want to tune with my laptop and never pull
the hood.
And the beat goes on...........
Ooops, yes that's the book
Old 12-20-2008, 12:44 AM   #23
Super73
Super73's Avatar
Heavy,
What are you spining the motor too?
A 31" tall tire with 4.10's assuming 10% slip in the converter (which is very high) and 5,500rpm would = 111mph
Old 12-20-2008, 06:59 PM   #24
Heavy Evy
born to lose
Heavy Evy's Avatar
Heavy,
I can't remember but I think I got the motor to 5300-5500 maybe even 6000. I'm running a stock converter and tranny no shift kit yet. but my best time was a 16.8 at 88 mph
Burb Build
Nova Build
Wagon Build
Not giving a truck.
Old 12-20-2008, 07:23 PM   #25
Super73
Super73's Avatar
Again, assuming 10% slip which is very, very high, 88mph with 31" tires, 4.10's would equal 4,350 through the traps.
I would assume a stock converter is probably closer to 5% slip which would be 4,150 through the traps.
If you spin the motor to 5,500, the 3.42's are going to make it even worse. Right now, the steeper gear is multiplying your TQ and making you go faster. Generally speaking, you want as much gear as you can for best ET. You just don't want to run out of RPM before the finish line.
You would be better off putting a looser converter in the truck. Also running a shorter tire with yuour current combo.
The looser converter will get you in the power band faster, multiply TQ as your leaving and get your shift extesions shorter helping to keep you in your power band.
With a 26" tire, 10% slip, 5,500rpm your looking at 93.3mph.
