Old 01-21-2009, 01:34 AM   #26
joe231
joe231's Avatar
Re: 1962 Fuel Cell dimensions
you mind telling what you paid?
CHEVY ONLY
Old 01-21-2009, 01:42 AM   #27
DaddyMack
Wide Eyed User
DaddyMack's Avatar
less than 300 ... custom dimensions
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 01-21-2009, 01:50 AM   #28
joe231
joe231's Avatar
plus shipping?
good deal!!
CHEVY ONLY
Old 01-21-2009, 01:51 AM   #29
slepysal
slepysal's Avatar
Originally Posted by protrash64 View Post
I have my fuel cell in the back, but its in the cargo area above the frame....Ive had people mention getting rear-ended but I figure I cant control that and its gotta be better than in the cab............
not hijacking....but ..............any pics ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-21-2009, 10:12 AM   #30
ol Curt
Junior Member
ol Curt's Avatar
What will you do for a sender?
ol Curt is offline   Reply With Quote
Old 01-21-2009, 11:10 AM   #31
ol Curt
Junior Member
ol Curt's Avatar
Originally Posted by DaddyMack View Post
Here is the finished tank....
What do you all think?? looks pretty good to me... baffled... fittings including drain... .125 aluminum made to marine specs..
Wow, that looks great. Now will the flange actually sit on top of the bottom frame rail or will it be mounted with straps?
Old 01-21-2009, 01:12 PM   #32
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Use JC Whitney either ZX528927T or ZX132950R
I have digital gauges (Dakota) so I can set the Ohms to 0-90 for the fuel sender.
all of the fittings are 3/8" - for my ease.
Actually, mounting it to the bottom of the frame rail, bolted in. No straps.
You can design it any way you want, I just thought that was the cleanest way I have seen it done for installation. Hopefully with the two cross braces (one right in front and one directly to rear) it will cut the frame flex. For my install I am actually removing the rear cross brace and then putting it back a few inches to the rear. I was thinking of welding the brace back in after cutting the rivots, but I may bolt it in so that I can remove it if I have to deal with the tank at a later date. comments?
350/350
2.5/5 static drop
Old 01-21-2009, 01:15 PM   #33
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Originally Posted by joe231 View Post
plus shipping?
good deal!!
Yea, plus shipping. it actually came to $317 I think including shipping.
Your price may vary depending on angles, cuts, etc.
350/350
2.5/5 static drop
Old 01-21-2009, 05:13 PM   #34
joe231
joe231's Avatar
that is a good deal, you have to supply your own sender, correct?
thanks for the info!!!
CHEVY ONLY
Old 01-21-2009, 05:44 PM   #35
DaddyMack
Wide Eyed User
DaddyMack's Avatar
yes. but it can be cheap or not so cheap for those.. just depends on your patience..lol
350/350
2.5/5 static drop
Old 01-21-2009, 07:02 PM   #36
joe231
joe231's Avatar
I'm hoping I can mod the original float assembly......
CHEVY ONLY
Old 01-21-2009, 07:27 PM   #37
DaddyMack
Wide Eyed User
DaddyMack's Avatar
They can put whatever bolt pattern you want on there I believe... I just chose their standard pattern for the floats I mentioned above. I could have paid as little as about $25.00 plus a bit a shipping... I found it local for $37.00just because I didn't want to wait for it. Pretty simple one-wire float. And I went with Stewart Warner float because I can make my digital dash recognize it and it was cheaper.
350/350
2.5/5 static drop
Old 01-21-2009, 10:05 PM   #38
joe231
joe231's Avatar
i want to use the factory gauge, so I need to do some research.......
CHEVY ONLY
Old 01-22-2009, 07:37 PM   #39
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Gotcha
I have seen a little mini filter or check valve for the vent line, I wonder where you get that and who makes it... anyone know?
Thanks!
350/350
2.5/5 static drop
Old 01-23-2009, 12:49 AM   #40
62ChevyStep
62ChevyStep's Avatar
Gotcha
Thanks!
This is what I used for my tank on my 62'
http://www.classicparts.com/1947-91-...ctinfo/93-245/
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 01-23-2009, 10:15 AM   #41
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 1962 Fuel Cell dimensions
This is what I used for my tank fuel cell set up on my Ole' 62'
20-Gallon Fuel Cell Natural Aluminum. Needs some cleaning up!
Now they come in different colors! I like the Black Powder-Coat Finish
http://www.jegs.com/p/Jegster/749961/10002/-1
Pictures of my fuel cell set up here:
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 01-23-2009 at 10:21 AM. Reason: Napoleon Dynamite: What tha flip? Cuz I wanted to......."Gosh!"
1Bad62Pro/Street is offline   Reply With Quote
Old 01-23-2009, 05:21 PM   #42
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Thanks!! think I will run by Tucker's and see if they have one.
I saw those... but my custom tank wasn't much different in price and is same gallons. Plus... good or bad, no straps... mounting right to frame.
I should start this weekend... If I do.. I want it finished by tomorrow night cause I found this get together on Sundays here from 8-10 am. Two other 62's show up .
350/350
2.5/5 static drop
Old 01-27-2009, 12:02 AM   #43
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Here are some pics of my progression and the finished install. I still need to get a new cross member for the rear.. it will have to be custom to go across the rails at rear, unless someone knows of one ready made?
cutting away cross member
test fitting
close up
oh yea... rear end shot... had bed off...lol
350/350
2.5/5 static drop
Old 01-27-2009, 12:26 AM   #44
TimE
Hey Y'all!!
TimE's Avatar
That tank looks good under there. Nice job!
Hey! I've got a creeper just like that!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-27-2009, 12:45 PM   #45
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Thanks!!
Yea.. my truck is too low for a regular creeper... so I use the custom model..lol
350/350
2.5/5 static drop
Old 01-27-2009, 01:59 PM   #46
1Bad62Pro/Street
test fitting
close up
Looks good bud! Does it have the foam filled cell (to prevent fuel slosh) like mine?
What's your plans on a Fuel Door? In the Bed?
The way I had mine was temporary. Looked crappy too.
Old 01-27-2009, 04:58 PM   #47
DaddyMack
Wide Eyed User
DaddyMack's Avatar
No foam cell, it is baffled instead. I am not a big fan of foam cell in a tank where it isn't easily removable when it starts to break down.. We use them in race cars, and your tank has a big enough opening since it is a race cell... in my case, baffling was the better idea.
Fuel door will be in bed. I measured and had the fuel filler placed right in the middle of a plank The advantage of the custom build.
Where did you get the cross brace for the back? did you make it? I am thinking I will just have to weld one up.
350/350
2.5/5 static drop
Old 01-27-2009, 05:42 PM   #48
joe231
joe231's Avatar
From the pics, looks like you can move your tank forward and make room to re-locate your original cross member to the back?
or is there a reason you put it back that far?
CHEVY ONLY
Old 01-27-2009, 06:17 PM   #49
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Frame is boxed to that point... I could have moved it up maybe another inch or two, but I wanted to used the holes existing in the frame for the fuel line and sender wire.
Plus I wanted the filler in the floor and back close to the tailgate.
350/350
2.5/5 static drop
Old 01-27-2009, 06:28 PM   #50
joe231
joe231's Avatar
oh now I see....
how about just using angle iron(top and bottom) for a new cross member...
just a thought...............
CHEVY ONLY
