Wide Eyed User
1962 Fuel Cell dimensions
I have gone through most of the threads, and can't find the width between the frame rails and cross members... I keep forgetting to measure it (even made notes to myself and lost them..lol) and when I get to work and want to order a cell... Why this has eluded me...lol
ugh... anyways.. if anyone has the dimensions handy... appreciate it. Thanks... DaddyMack
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
Re: 1962 Fuel Cell dimensions
Mark the fuel cell guy might have some plans already
Wide Eyed User
I am not sure that I want a custom tank. May try to see what else is out there.. i.e. fuel cell .. albeit at less gallons.
I didn't want to take his time, if its just an option. But if he wanted to chime in on his own accord, it would be appreciated. Thank you for the response.
Wide Eyed User
Alrighty... So I finally did it myself... guess posting here helped me remember to do it..lol
anyways... I got this: closest point 36 3/16 width between frame rails (closest point nearest the rear axle) it does get a little bit wider towards rear of truck to about 7/16. length front to back... closest point is 15.5 between cross members. It does get as wide as 17 inches... because of the angle of the cross member that the sway bar attaches to. depth... prob around 8 inches I figure. I saw a drawing showing 9in in front (nearest axle) and 7.5 inches in rear. I am guessing that allows a bit more clearance in back and makes for a better pickup point for the fuel. The flanges need to be at 3.5 inches on the short sides to allow the tank to mount to the bottom of the frame rails and clear the bed support. SO ... I guess 36 x 15.5 x 8 (or 9 slope to 7.5 in rear) without creating any odd shapes. approximately 19.3 gallons from outside dimensions .. probably around 19 gal when all said and done.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 12-24-2008 at 01:50 PM. |
So are you looking for someone to build one to your specs or are you just trying to figure out what size of fuel cell to buy from Summit?
Wide Eyed User
I was looking to see what might work from summit. Plus it seems as if the 60-62 tank dimensions are a secret and not a normally built item...lol.. can find 63 and up tanks all day prebuilt...
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 12-24-2008 at 02:34 PM. |
Oh thats weird I dont know why there arent any for the early years. I have noticed there isnt as much aftermarket suspension stuff for 60-62
Wide Eyed User
The suspension on mine was fairly easy....lol.. ford nine inch rear end... and dropped it 2.5 in front and 5 in rear with springs that I bought online...
oh and put the disks on all four wheels... Finding that stuff was a lot easier than the fuel tank. I did find a guy that builds custom tanks... .125 alum... so good stuff... for a good price... I will report back in about 30 days if I decide on the tank...
sounds good, do you have a ballpark price range that he was charging? Would like to see pictures of the tank if you get it
Wide Eyed User
PM sent
![]() final dimensions will be something like 36 x (14 on top sloped to 16 on bottom) x (9 front sloped to 7.5 rear) for clearance and to be sure. about 19 gals. should be 18 usable.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 12-25-2008 at 12:47 PM. |
"Where were you in '62?"
![]() Join Date: Jul 2004
My 20 Aluminum Fuel Cell is from Jegs, and had no troubles on install.
JEGS Aluminum Fuel Cells - JEGS *Hand-Built, Light-Weight, High-Strength! Foam filled, .090" wall thickness aluminum fuel cells include a flush mount aircraft
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-14-2010 at 01:21 PM. |
That looks good prostreet, mind if I ask how much $?
#13 |
Like $250.00 for a 20gallon. JEGS Aluminum Fuel Cells are about the same. Maybe a little cheaper than Summit.
So here is Jegs: http://www.jegs.com/p/Jegster/749961/10002/-1 Summits: http://store.summitracing.com/egnsea...p;autoview=sku I have some close ups pictures of my 20 gallon fuel cell on here of how I mounted and braced it on here. You just have to hunt for it. My BB phone will not alow me to upload anything. http://67-72chevytrucks.com/vboard/member.php?u=12984
#14 |
Sweet thanks
#15 |
Wide Eyed User
Pro
Looks like you removed the rear cross brace and moved it back? That makes things easier for sure. I would only be concerned that no crush zone exizts if someone rearends your truck. Maybe that's not true with the fuels cells? or even a concern? did you just move it back or did you craft a new one?
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 12-25-2008 at 12:48 PM. |
#16 |
Wide Eyed User
I decided to move the brace back and go with a tank a little bigger. 36 x 16 x (9 - 7.5). It is about 20.5 gals. outside dimensions. We'll see.
That will let me move the filler neck back closer to the rear of the bed.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 12-26-2008 at 03:20 PM. |
#17 |
Cant wait to see some pictures of your setup
#18 |
Resistance is Futile
I have my fuel cell in the back, but its in the cargo area above the frame....Ive had people mention getting rear-ended but I figure I cant control that and its gotta be better than in the cab...........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#19 |
![]() Hey Bud, I am in Saint Marys, GA for the Holidays. I will be back on the second of Jan, and I will take detailed pics of my fuel cell setup. I need to get my build tread started. Me and pops are going to get all the pics and info together soon. We did all that for his 69 AMC Rambler American. The frame has been altered a bit to Accommodate for a lot of things; including the fuel cell.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-14-2010 at 01:22 PM. |
#20 | |
![]() Quote:
Hey Bud, Yea, there is another brace underneath the fuel cell. She is pushed up a little too. I will take some more detailed pics and post them on Jan. 2nd or the third. I have to clean her up good and shoot some pics.
#21 |
Ok cool
#22 |
http://mphotos.live.com/p.ashx?url=h...=240&mkt=en-US
http://mphotos.live.com/p.ashx?url=h...=240&mkt=en-US http://mphotos.live.com/9169aad55cfc...1163&mkt=en-US
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 12-26-2008 at 09:12 PM. |
#23 |
Wide Eyed User
Here is the finished tank....
What do you all think?? looks pretty good to me... baffled... fittings including drain... .125 aluminum made to marine specs.. ![]() ![]() ![]()
#24 |
nice!
who built it?
#25 |
Wide Eyed User
