#26 |
Project underway - finally.
Re: Driveshaft 1 pc or 2 pc?
For those who have swapped to a one piece, for a V8, three speed stick, what trucks/cars have a driveshaft of the correct length to use?
Thanks -Brian
1972 GMC Pre-resto... awaiting allocated funding. |
#27 |
does anyone have a part ## for the rear cross over U joint??
89 chevy car to C 10 rear |
#28 |
the boat guy
bowtie
get a shaft with the correct ujoints that is too long have a driveshaft shop shorten and balance. shortstep what series are the 2 ujoints you need to make into one 1310 1330 1350 3r? everybody else, the stock style carrier bearing is a good bearing, and with a little welding the stock bracket works great. at least 3x a week i have to fix a driveshaft that a PROFESSIONAL MECHANIC screwed up... remember your ujoints (on these trucks, and most anything else) will be in time, mark the shaft before you take it out, mark all of the parts before you dissasemble driveshaft (you can put these back together 180 out of time, but then your original weights are on the heavy side and not the light side!) DON'Tput your driveshaft in a vice then hit it with a hammer!!! it makes flat spots in the tube and bends the tube. set ujoint above jarge socket or use a press. DON'T use crappy ujoints (precision is the worst i can think of .030 loose is common) spicer or neapco are great. all of these things can cause a driveshaft to become out of ballance and can ruin a good carier bearing fast, or trans bushing or pinion seal. even if you do all of this correctly you may still need to have your drivshaft ballanced, even from the factory these shafts arrent exactly straight or well ballanced. 2 piece driveshafts must be ballanced as an assembily. ![]()
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, Last edited by brad_man_72; 01-25-2009 at 10:08 PM. |
#29 |
how do u bust a carrier barring... i have a two piece.. and its been able to withstand massive burnouts my dad has done and a few peel outs i did
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#30 |
Longhorn, I think you misunderstood my comment. I am all for the two piece design. The question I asked was assuming that GM knew something from their tests and trials and decided to go with a two piece design. It was probably a torque thing. I agree with you that they are probably stronger than the one piece.
I had a longbed a few years ago that I put a 700r4 in. It had a one piece driveshaft. Once I changed the transmission, the truck vibrated pretty bad from about 50 mph to about 70. Couldn't figure it out. I finally decided to change back to the two piece design and what do you know, the vibration disappered. |
#31 |
the boat guy
the reason for running a multiple piece driveshaft is for lenth, or to lower tunnel inside car.
lenth being the main reason, a long driveshaft needs to be large in diameter to be rigid enough to withstand the forces of spinning, if you were to build a 70'' driveshaft out of 2.5" tubing it would bend at high speeds (visualize a jumprope) the only reason factory production cars have a driveshaft over 2.5" in diameter is lenth. the shafts we build for 500hp dirt track cars are 2.5" .085 dom tubing and i have never seen one fail by itself. vibration will make the rubber part of a carrier bearing fail, lack of lubrication will make the bearing fail. doing burnouts only strains the ujoints.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#32 |
I need the distance between the center of the tailshaft and the floor.
Somewhere to stare the x member bob |
