Driveshaft 1 pc or 2 pc?
I am working on my 67 SWB 2WD Pickup. I do not have the orig. driveshaft. It has a spot to bolt on a carrier bearing. Did all SWB 2WD Pickups have 2pc driveshafts? Since I am droping the rear 4"-6" it looks like I could remove the bracket that holds the carrier bearing and use a 1 pc driveshaft. Does this make sense or have I lost my mind?
Re: Driveshaft 1 pc or 2 pc?
Use a one piece. I've got a short bed with a 700r4 and I used the original (i think) one piece that was behind the 3 speed. Less parts to wear out.
Under Construction
one piece on my sons swb ' 67 as well.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
RIP BigDaddyDave ~7-23-09~ You will be missed~
I have replaced two carrier bearings inside of a year and a half. Go with the one piece drive shaft. You will be glad you did! Some will tell you that a two piece is just fine, but in my opinion, the carrier bearing will always be the weak link in the drive line.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
WTB this ad
SWB 6cyl manual trucks used a one piece shaft. SWB V8 auto trucks used a two piece shaft. I swapped my two piece over to a one piece when I installed my ECE extreme drop trailing arm crossmember.
Nothing wrong with a two piece shaft if you can keep the bearing in it. |
its all about the +6 inches
a quality bearing will last 40+ years. The problem is, most of the ones on the market are not of quality. Not high quality anyways.
Its a Truck Thing......
Hmmm,
My SWB 6cyl,manual came with a 2 piece.....now I need to find some shims to adjust the pinion angle after putting in new springs after I put in a 1 piece.
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Junior Member
A long while ago I drove a '72 GMC with a 2 piece drive shaft for 15 years and only had to replace the carrier bearing once.
On my short bed we had to use a two piece drive shaft because of the compound 4 speed. We used the two piece out of a 3/4 ton and it looks to be pretty strong. We did have to shorten the back shaft some, though. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
I removed the carrier bearing and housing, replaced it with a one piece driveline!!!!!!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
One piece shaft for like 12 years now, and I'm dropped almost 6" in the rear.
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
I went with a new two piece because it was original to my truck. The carrier bearing I replaced 20,000 miles ago looked to be original, and the one that's in there now is as solid as the day I put it in. You have to be careful about how you put them in though.
If you are do any suspension mods. I would say one piece because of the drivetrain alignment becomes criticle factor. Off even slightly can couse problems and coupled with todays quality parts - well, part failure is bound to happen.
#13 |
Resident of Here
Shortbed - 1 piece.
Longbed - 2 piece. Just my opinion.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#14 |
a 2 piece can be benificial, esp on a truck that is slammed with a c notch or on bags... lwb or swb.
#15 |
WTB this ad
Yep, Nathan Porter has been suggesting the use of a two piece driveshaft with his backhalf dropmember setups. It cuts down on the tunneling of the bottom of the cab for driveshaft clearance.
#16 |
yep, and it divides the drive line angle in 1/2 too (if done right).
#17 |
I have a two piece. I just replaced the original center carrier bearing about a year ago. You gotta ask the question: why did GM opt for a two peice to begin with? You think maybe they knew something?
#18 |
had a one piece in my tubbed out and lowered 71 and IMHO its a better choice.... only thing they did was cut a bigger hole in the cross member where the shaft went thru.....
#19 |
this one will take all the abuse you can throw at a street driven ride.
can be purchased from Inland Empire Driveline.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
#20 |
![]() Join Date: Jul 2007
how much is it?
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#21 |
When replacing my carrier bearing last week I found bearings made in China for around $20.00 and bearings made in the USA for $59.00. I paid for the made in the USA version. You get what you pay for.
69 sweet long fleet, David |
#22 | |
They've been in use for may many years, and in way more aplications than you'd ever think. |
#23 |
![]() Join Date: Jun 2006
I have a 68 swb 350/700r4 and I used a one piece lwb shaft cut down to fit with a 700r4 yolk. Also remove the carrier bearing mount and have a ECE 4/6 drop. Fits very nice and less parts to replace regardless.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#24 |
price is 131.99 @summit racing.
#25 | |
Old member
lofly'a
If this is the price for the center carrier bearing then I just made my decision. I want be needing that for my truck. This last one has done fine since about 1990. That's as much as the drive shaft work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
