02-10-2009, 12:45 AM | #26 |
Re: Drop center crossmember ...
Well... it's still monday in Arizona!
Here's some pics of the version that is NOT set-up with the trailing arm tabs. This version is designed to bolt into the factory holes and has a mount for the carrier bearing: The version that employs the trailing arm tabs is almost identical. The obvious difference is that it has tabs for the trailing arms, and it's frame mounting plates are a bit longer and have more mounting holes allowing the user to adjust the location of the crossmember and center the wheels when compressed.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 02-10-2009 at 12:46 AM. |
02-10-2009, 12:54 AM | #27 |
Very nice pics ... but now for the $64 questions ... price and availability?
02-10-2009, 12:57 AM | #28 |
looks bada$$ nate, now you better get a patent on that before someone else does....
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
02-10-2009, 01:00 AM | #29 | |
The trailing arm version runs $249. Availabilty will depend on my work load at the time, but worst case would be 3-5 business days until it shipped. Keep in mind, this unit is designed to use a two-piece drive-shaft... don't think there will be enough room with a one-piece.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 02-10-2009 at 01:03 AM. |
02-10-2009, 03:42 AM | #30 |
WOW thats nice
nickle and dime |
02-10-2009, 04:02 AM | #31 |
what about the other style carrier bearing, would it work to?
02-10-2009, 08:08 AM | #32 | |
Also, I know that when I set up my 2 piece driveshaft, with the amount of drop I have, I had to alter the location of the carrier bearing to get the proper driveline angles. Is there adjustability in bearing placement? (in regards to vertical mounting height? |
02-10-2009, 08:09 AM | #33 | |
Please see my original question. <sigh> Last edited by Shane; 02-10-2009 at 08:10 AM. |
02-10-2009, 11:13 AM | #34 | |
I know when running an ECE or CPP crossmember it is still necessary to "make modifications" when using a one piece driveshaft and combining extreme lowering. A one piece drive-shaft may be a possibility with this application in certain ride heights or ranges of travel. I have not fit this unit up with a one piece drive-shaft and therefore have NO feedback on this possibility. I didn't mean to whore your thread, and honestly didn't even fully read your first post... just got a little sucked into some of the other's comments and questions. For those with more questions or comments please refer them to the new thread I have just started.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 02-10-2009 at 11:17 AM. |
02-10-2009, 02:01 PM | #35 |
Never Done?
Shane, I'm running AirRide's tubular trailing arm x-member with factory arms. BUT I (still) haven't driven the truck or even installed the driveshaft. If I remember correctly, AirRide is a board vendor now, correct?
