#26 |
TexasBowhunter
Re: Replace studs?
Look to the right of my Hobart.
Disc and hub are held together by studs. Excuse my mess! ![]()
Build in progress for son's first truck. |
#27 |
Resident of Here
Re: Replace studs?
Thanks! You guys really helped!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#28 |
Re: Replace studs?
The hub isn`t always seperate from the disc.The unit is known as a rotor or disc.The studs are "pressed" not packed.With owning a 4wd you`ll get to where taking that hub apart is like putting a battery in.
#29 |
Re: Front hub help!
I hate when you can`t quite get it back in the groove when you`re almost done.Whaaa!!!
#30 | |
Resident of Here
Re: Replace studs?
It's as hard as putting a battery in? GAWD! I'll never get it apart! ![]()
#31 |
Re: Replace studs?
Oh ok.I always feel like saying pressed.
#32 |
![]() Join Date: Oct 2006
Re: Replace studs?
If you havent pulled one apart before, you will need the 4 prong hub socket to get the nuts off. also be carfull when putting it back together. the inner nut has a small nub stiking out that lines up with one of the holes in the washer between the nuts. You must line that back up when putting it back together. If it wont line up then flip the washer over and try again, if that doesnt work the tighten the inner nut a bit more and repete. If done correctly the nuts wont back off. Ive fount that snap ring pliers work very well to put in the washer.
Remember to repack you wheel bearings while it is apart! |
#33 |
TexasBowhunter
Re: Front hub help!
You get it off yet?
#34 |
Re: Replace studs?
How zit goin?
#35 |
Resident of Here
Re: Replace studs?
I've had strep real bad since Sunday. I am so tired of being cooped up in the house all day, I was so tempted yesterday to start working but I cant! I should be well enough Saturday or Sunday to work on it, I'll tell you guys how it goes. I just have to see if we have snap ring pliers or if I have to go buy some.
#36 |
Resident of Here
Re: Front hub help!
Check the stud thread.
#37 |
Re: Replace studs?
You can get by with two thin objects like a pen screwdriver or pointer/center punch.
#38 | |
Re: Front hub help!
No reason for two threads to do the same thing.....merged.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#39 |
Resident of Here
Re: Replace studs?
When I was messing with it the other day I was able to push in hard with the pen driver and pry the ring up a bit, but the other pen driver couldn't get under it. Anyone have pics of where to get it under or any pics to help?
