Resident of Here
Front hub help!
We are taking apart the front hubs on my 84 K10, it has a 10 bolt front. We got the outer collar with the spring and the inner collar with the spring off. Now there is a piece behind the inner collar that held it on with 1 phillips head. What next? Is there a snap ring or something? All help appreciated!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: Front hub help!
Resident of Here
Re: Front hub help!
Thanks. That helps, but I'm trying to figure out how it comes out.
#4 | |
Re: Front hub help!
Pictures of a better discription of exactly what kind of hubs you are working on will help a lot. I don't recall a phillips head screw in any kind of hub? but it could be the work of a PO
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Resident of Here
Re: Front hub help!
Never mind guys. My uncle called and we got it figured out.
Re: Front hub help!
Was it the snap ring on the axle stub?The grease kinda hides it.
Resident of Here
Re: Front hub help!
Yes thats it. How do I get it off?
Re: Front hub help!
A good set of snap ring pliers should take care of it.
Re: Front hub help!
Yeah,or a couple little pen screwdrivers,something small like a little prick.(that`s what we call`em)
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-08-2009 at 02:12 PM. |
Resident of Here
Replace studs?
How do I replace the drivers side front studs on my 84 K10, it has a 10 bolt front diff.
TexasBowhunter
Re: Replace studs?
Wheel studs?
Build in progress for son's first truck. |
Resident of Here
Re: Replace studs?
#13 |
TexasBowhunter
Re: Front hub help!
I held the snap ring with a pair of needle nose (so you wont chase it in circles) and took a scribe (ice pick lookin hootus) and popped one side out.
Assy should slide out. Then take a spud socket and remove outer jam nut. Then remove perferated washer. Then use spud socket to get bearing nut out. Disc should slide off.
#14 |
TexasBowhunter
Re: Replace studs?
Lay disc flat on wooden surface.
Hit studs with large hammer! They are pressed in. If you want to re-use the studs....thread on a lug nut and hit the lug nut to preserve the threads. I would suggesst replacing the studs. They are cheap!
Build in progress for son's first truck. Last edited by Joey~AP; 02-11-2009 at 10:05 AM. |
#15 |
Resident of Here
Re: Replace studs?
No, I mean how do I get the hub casing(?) off? It is separate from the disc.
#16 |
Resident of Here
Re: Front hub help!
How do I lift the ring enough to get anything under it to be able to pull it out? From what I can tell we would need VERY small, curved tip needle nose pliers.
#17 |
TexasBowhunter
Re: Front hub help!
Just get it to stop spinnin in circles. Try to stop it with the gap at the bottom of the hub. Hold one end, pry the other. You outta be able to get a scribe or a very small screw driver under the end of the snap ring and pop it out toward you.
Its not easy and takes time and patience! The trick is to get it to stop spinnin.
#18 |
TexasBowhunter
Re: Replace studs?
Once you drive the studs out, the hub should seperate from the disc.
The stud kinda holds them together. Its not like a Toyota or Ford.
#19 |
Re: Front hub help!
Snap ring pliers are the easiest. If you don't have them, 2 small flathead screwdrivers will work work. You just got to fiddle/pry on one end with it until you get under it, then you'll be able to pry it out in a circular motion. Also, a piece of coat hanger with a very short 90 deg bend on the end works well on the perf. washer.
#20 |
TexasBowhunter
Re: Front hub help!
It takes me a few beers to get it out.
I really love it when you pop it out.....and it pops right back in! ![]()
#21 | |
Resident of Here
Re: Replace studs?
My dad hit the studs loose before we even got anything apart. The disc and the piece the studs are packed into are separated. Will the piece the studs are packed into come off with out me having to get the snap ring out and all the inner stuff?
#22 |
Resident of Here
Re: Replace studs?
Last pic.
#23 |
Re: Replace studs?
Or are you asking how to get the disc off the truck?
1972 LWB 1969 4x4 Suburban 1989 4x4 Jimmy |
#24 |
Resident of Here
Re: Replace studs?
No, how do I get the piece the studs are packed in off. The disc is a separate piece from what I can tell.
#25 |
TexasBowhunter
Re: Replace studs?
Snap ring has ro come out! Along with everthing else in there.
