02-12-2009, 12:48 PM | #26 |
Re: Heads for a 350 chevy
Can't go wrong here--->http://cgi.ebay.com/ebaymotors/PERFO...QQcmdZViewItem
I have bought from these folks a couple of times. And will be buying a set of these in the next couple of months. Great prices, great machine work, and a good warranty to boot! If I remember correctly they're out of Texas. |
02-12-2009, 01:10 PM | #27 |
now that's a great deal. i spent a little more than that getting my stock heads rebuilt after having trouble with two sets of vortecs.
70 c10 stepside ,350v8, m-20 4 speed |
02-12-2009, 01:39 PM | #28 |
Not a bad deal for 700 bucks complete. The intake runner is on the smaller side being only 185cc. If your not looking to make any huge power numbers than these heads are probably the best deal out there. Probably support 450hp NA. (referring to the patriot vortecs)
02-12-2009, 06:02 PM | #29 |
02-12-2009, 07:58 PM | #30 | |
I have a radical idea!
Otherwise, they are wonderful heads. That 'bird is one the stoutest N/A TPI cars you'll see.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-12-2009, 11:11 PM | #31 | |
02-12-2009, 11:44 PM | #32 |
I also assume i could use my stock intake and edelbrock elite valve covers?
Also what roller rockers and rods would go good with this? Last edited by djkyle65; 02-12-2009 at 11:58 PM. |
02-13-2009, 04:01 AM | #33 |
Greasemonkey
dude i have patriot performance aluminum heads on my patriot crate lol and i couldnt be happier damn nice heads .
1970 cst-10 longbed speed My Baby http://67-72chevytrucks.com/vboard/s...=1#post3113923 |
02-13-2009, 08:08 AM | #34 | |
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-13-2009 at 08:14 AM. |
02-13-2009, 09:23 AM | #35 |
Well im not going to be making like a drag car or anything but i dont want to be limited if those arent good enough. If im going to spend 500 might as well spend more now and not later
Any other suggestions besides these vortecs ? http://paceperformance.com/index.asp...D&ProdID=73011 I was thinking i might buy it individually so i can put different roller rockers ect. Thats probably at the top of my budget Last edited by djkyle65; 02-13-2009 at 09:24 AM. |
02-13-2009, 09:47 AM | #36 |
If i get a set of just standard vortec heads its best to get the center bolt correct?
02-13-2009, 10:03 AM | #37 | |
I had no idea the intake ports were that high on the pp vortecs, good call.
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
02-13-2009, 10:59 AM | #38 | |
Pay attention to the casting #'s to avoid !!!!!!! These might be why there have been some naysayers in the post. http://www.chevyhiperformance.com/ho...458/index.html |
02-13-2009, 11:14 AM | #39 |
How much horsepower are you looking for? I reworked my own set of the 416 heads, and enlarged the whole chamber instead of just unshrouding the valves. And mine were only 1.94/1.50. I also port matched, and enlarged the intake runners to 170cc. They were on about a 350 horse 350, the truck would run a high 14 sec 1/4 mile.
02-13-2009, 02:17 PM | #40 |
http://store.summitracing.com/partde...5&autoview=sku
Click the link, and they had a save $50 on a $200 order, so you'd get the vortecs for closer to $500 for the set and new, just get the self aligning rockers, and a vortec specific intake, and if you want to use the valve covers you have, they make an adapter to go from center bolt to perimeter so you can use them on the Vortec heads, trust me 30+hp over any of these stock heads mentioned here and better performance than even the Dart's SR's etc, etc under or at .500 lift, after that the Dart's etc out perform the Vortecs, but over .500 lift is not really a daily driven street motor either, plus 6,000+ rpm and that is the only way/time any other head out does the vortecs!! GET THEM!! |
02-13-2009, 02:21 PM | #41 |
http://store.summitracing.com/partde...4&autoview=sku
Heck, here is the full boat, everything you need for $899-$50?! |
02-13-2009, 05:06 PM | #42 | |
02-13-2009, 05:08 PM | #43 |
Plus rocker arms right?
02-13-2009, 06:00 PM | #44 |
Im thinking this might be a better deal sense i dont think the other one includes rocker arms.
http://paceperformance.com/index.asp...D&ProdID=18329 Is there anything wrong with this package ? If so ill get the other |
02-13-2009, 10:56 PM | #45 |
I think if it was me, I would find a good used set,get them rebuilt by a good shop, and spend the money you save on an intake..
I found a set of 1993 LT1 Aluminum heads locally for sale for $175.00/pair...I try to rebuild before I buy new if possible...but I like looking for parts as much as buying them. |
02-13-2009, 11:00 PM | #46 |
Vortec heads and Edelbrock 7516 Small Block Chevy RPM Air-Gap Intake manifold thats what i have on my 70 gmc 4x4
02-13-2009, 11:23 PM | #47 |
What about these?
http://houston.craigslist.org/pts/1033556080.html |
02-13-2009, 11:35 PM | #48 | |
02-13-2009, 11:42 PM | #49 | |
I'd stay away from LT1's if you are not running them on a LT1. They are reverse flow cooling heads, and require welding up some of the coolant passages, drilling new ones where there isn't and resurfacing the head. Then you will need a LT1 specific intake. Not really worth it IMHO and the cost of the machine work would be nearly as much as a decent set of Vortecs, and you would have many more intake choices. The Vortecs flow much better as well. The only really advantage the LT1 head has is that they are aluminum.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-13-2009 at 11:43 PM. |
02-13-2009, 11:48 PM | #50 |
