02-11-2009, 07:34 PM | #1 |
Heads for a 350 chevy
Anyone got any suggestions for good heads for a 350 bored 40 over looking for someplace that has something reasonably priced
Thanks |
02-11-2009, 07:39 PM | #2 |
Re: Heads for a 350 chevy
Vortecs, you can't go wrong with them!
02-11-2009, 07:43 PM | #3 |
Ditto on the Vortecs. You will never find a better bang for the buck, EVER! You have to run a Vortec style intake which is available from every manufacturer and also centerbolt valve covers. Dont let the valve size fool you. They flow well.
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker |
02-11-2009, 07:51 PM | #4 |
I put a pair of Summit brand heads on my 350 in my 'burb. The day after I got back from B'ville this summer white smoke came out of the right bank, it was a cracked head. They were double humps and it was more reasonable to replace them with the Summits that find a head and have them both completely redone. I drive my 'burb daily and they seem to be working well.
02-11-2009, 08:19 PM | #5 |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-11-2009, 08:29 PM | #6 |
I would go to a local engine shop and find some rebuild stock 305 heads that are 64 cc, with the largest valve they have and buy them. For about $200, you will really wake your truck up. This will bump your compression over 10:1.
02-11-2009, 08:34 PM | #7 |
72 Chevelle Club
Check Competition Products Web Site for Dart Iron heads I think you can buy them cheaper than vortecs and they are very nice . They are priced depending on what you want . The bigger and badder you want the more money you spend . You don't have to run a vortec intake either . My 2 Cents . Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
02-11-2009, 08:52 PM | #8 |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-11-2009, 08:54 PM | #9 |
Maybe the best money I spent...http://store.summitracing.com/partde...5&autoview=sku
02-11-2009, 09:44 PM | #10 |
It depends on what you want to spend, and what is in your engine right now. I say if it is mildly hopped up go with stock 64cc 305 heads if you are on a budget. Thats what I have and I still managed to run a 13.8 sec 1/4 mile. If you have the extra money go with the world product heads, there going to be better. Just my .02
02-11-2009, 09:54 PM | #11 | |
02-11-2009, 10:28 PM | #12 | |
I would also agree with vortec heads! All day long the best bang for your buck. And if yo don't like centerbolt heads, no worries. They have an adapter so you can run your regular side bolt valve covers. JMHO. SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-11-2009, 10:35 PM | #13 |
By the time you get the heads machined for screw in rocker studs, machined spring pockets for bigger springs and valves and a valve job (assuming you don't want to stick with the 1.94"/1.50") its better to go with Dart Iron Eagles. They will cost around $950 for a complete set with your spring choice and choice of valves 2.02 or 2.05 .
My car with a roller cam and these heads untouched puts down 350hp to the wheels. |
02-11-2009, 11:05 PM | #14 |
For the record guys, 305 have heads do not have 64cc chambers. They range from 58cc - 60cc chambers. Companies like Aerohead and others enlarge the chambers with valve deshrouding cutters and make them 64cc but they come from the factory smaller. The run-on problem they are notorious for is due to a small chamber with severely shrouded valves that create excessive heat. This causes the "dieseling" effect. If the timing is kept on the low side they do perform OK on a 350, but unless I was on a shoestring budget and had them laying around, I'd go another route. I've ran them in past on 327's and 350's with pretty good results, but I wouldn't buy a set and spend money on valve job when Vortecs and others can be bought so reasonably. They actually work really well on a 307 though...
02-12-2009, 12:32 AM | #15 | |
72 Chevelle Club
02-12-2009, 12:33 AM | #16 | |
72 Chevelle Club
02-12-2009, 12:43 AM | #17 |
I love Darts too. In fact, I'm running 215cc Iron Eagles on the 383 in my '82 Z28 drag car. However, for a daily driven street engine, I prefer the Vortecs because of the tall high-flow smaller runner intake ports and the fast burn combustion chamber. The Vortecs bone stock with 170cc intake runners with 1.94/1.50 seriously outflow the Dart S/S's and World S/R heads and give 200cc Iron Eagles and World Sportsman II's all they want up to .500" lift. Their bigger heads kill the Vortec, but Dart nor World makes a comparable sized head that will perform as well or be as efficient as the Vortec. I know that sounds crazy, but it is true. That's why I'm so high on the Vortec. Check out this chart, because I know you racer types (Bob) are gonna want proof!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-12-2009 at 12:44 AM. |
02-12-2009, 12:53 AM | #18 |
Dart Iron Eagle all the way...
02-12-2009, 12:54 AM | #19 | |
72 Chevelle Club
02-12-2009, 01:11 AM | #20 | |
I'm building an engine for my red '69 right now, and its going to be strictly a daily driver, but I do want more power than the 76cc headed smog 350 has that's in it now. I'm basically building a carb'd version of the GMPP Ram Jet 350. It's a going to be a 4 valve relief flattop .030" 1 piece seal 350 with Vortecs and Ram Jet hydraulic roller P/N 14097395. It is a mild, smooth idling cam but makes great torque and very good HP for what it is. This is a proven combination, and I know it will make my truck much more fun to drive. With the same heads and cam and 9.4 CR, the Ram Jet 350 is advertised at 350HP and 400ft lb. I'm going to be running an dual plane aluminum intake and Q jet with ram horns and 2.5" duals, so I won't quite make those numbers, but it will be very stout nonetheless.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-12-2009 at 01:13 AM. |
02-12-2009, 08:11 AM | #21 | |
02-12-2009, 08:21 AM | #22 |
On a mild to moderate build with less than 10 to 1 , you cannot beat the Vortec head, I have seen flow data on "worked double humps" VS. Vortec's and #'s dont lie, Vortec's win, you cannot beat the engineering in those heads without spending $1,000 + . You will as stated need a new intake manifold and some hardware
02-12-2009, 09:09 AM | #23 |
I am a big fan of dart, plus thumbs up on made in America, I would rather have a slower ride and keep some slub here working rather then go fast and keep some party boss in China slurping down eel eyeballs. Personally, I would buy a used set, guys are getting rid of extra go fast parts now for money to pay the rent.
02-12-2009, 09:13 AM | #24 |
Hard to beat the Vortecs.
Here's a link to get the kit to change over. With Edelbrock Performer intake: http://paceperformance.com/index.asp...D&ProdID=73011 With Edelbrock Performer RPM intake: http://paceperformance.com/index.asp...D&ProdID=18329 Of course if you need everything for the top end: http://paceperformance.com/index.asp...&ProdID=219069
02-12-2009, 10:02 AM | #25 |
new vortech heads with a 5 angle valve job and screw in rocker studs, wich you'll need when crossing over the .500 in lift. https://www.patriot-performance.com/...ome.php?cat=76
These heads are tapped for the old andnew type intake manifold, also perimeter v/c or centerbolt v/c.
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules Last edited by milled; 02-12-2009 at 10:05 AM. |
