Old 02-27-2009, 11:26 AM   #26
edflores
Re: CPP narrowed track width drop spindles...
Originally Posted by SCOTI View Post
For years I drove my 68 Beater w/Western Chassis 2.5" drop spindles & 15" van ralleys (6.5" wide w/about 3.5" BS). There was ABSOLUTELY no interference. No trimming or grinding was required (to any portion of the a-arms).
Again, it depends on the back spacing of the wheel.
i have 15" rallys with 2.5 western chassis spindles on my 81 jimmy as well. fits like a glove.
edflores is offline   Reply With Quote
Old 02-27-2009, 11:58 AM   #27
Kayotic
Kayotic's Avatar
2.5" drop spindles will work with stock 15" wheels and the original brakes?
I would like to order spindles and keep these temporary wheels(6 lug), but what to order - stock replacement or one specificly for disk brakes?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-27-2009, 12:21 PM   #28
SCOTI
SCOTI's Avatar
Yes. 2.5" spindles w/stock brakes will work w/15" wheels (depending on the back spacing). If re-using 6-lug wheels, they need to be compatible w/disc brakes (OE 60-70 steel wheels will not work w/later OE disc brakes). You can get aftermarket 6-lug steelies that work w/disc brakes or use 6-lug 4x4 ralleys.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-10-2009, 07:38 PM   #29
northern 85
northern 85's Avatar
Any pics yet of the narrowed track width?
northern 85 is offline   Reply With Quote
Old 03-11-2009, 11:02 AM   #30
Custom 68
Custom 68's Avatar
check out the new classic truck mag. It has an article of these. They make them sound pretty good.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-11-2009, 12:16 PM   #31
SCOTI
SCOTI's Avatar
Dave
CPP has a quality marketing program; it's their customer service that needs work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2009, 09:35 AM   #32
111stony
The pictures are not very good. Camera was set at low res. I can try to take some high res ones if everyone wants to see them.
This is my first attempt at posting a picture. The calipers were unfinished from CPP. I sanded them smooth and painted them with 2 stage to match the truck. Here is the front.
Here is the rear.
The front end is not aligned. I set it a close as I could with my eye. With a plumb bob on the mounting face of the rotors, the track width was 52 3/4". I was told by CPP the track width would be 5/8" less on each side.
I was given the worng rotors when I picked everything else up last year. I talked with Danny and he shipped the correct ones the next day with a UPS return label. CPP has treated me well and I would buy from them again.
111stony is offline   Reply With Quote
Old 03-12-2009, 09:52 AM   #33
Custom 68
Custom 68's Avatar
111stony glad to hear they treated you good. It almost seems to be hit or miss on that. The photos dont show up. I dont know much about posting pictures...
I would like to see them though.
Dave
Dave
Old 03-12-2009, 09:57 AM   #34
jklonowski
jklonowski's Avatar
Last edited by N2TRUX; 03-19-2009 at 07:27 PM. Reason: Please do not offer items For Sale.
jklonowski is offline   Reply With Quote
Old 03-12-2009, 05:49 PM   #35
Number98
Prestige Worldwide
Number98's Avatar
Agreed... I am an ECE fan for sure because I have always had great luck with their products and customer service. On that same note I have used some CPP parts that were of great quality and did their job, just no luck if you need some help from them on something.....
Number98 is offline   Reply With Quote
Old 03-12-2009, 10:48 PM   #36
SCOTI
SCOTI's Avatar
Yep, I'll use them if I must. But, if it's offered elsewhere, they lose my business strictly on the CS aspect (& I've used CPP muliple times).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-13-2009, 01:30 PM   #37
chevyrestoguy
chevyrestoguy's Avatar
chevyrestoguy is offline   Reply With Quote
Old 03-13-2009, 04:03 PM   #38
b00sted
b00sted's Avatar
$299 for the spindles then anothe r$75 for th ebrackets to use stock brakes..... They are going to get you any way you go.... I wonder how these would work with a 15X 3.5 rim?
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-16-2009, 03:10 PM   #39
stunna
Question Re: CPP narrowed track width drop spindles...
just wondering if you have a porter dropmember that already narrows the track width, will these spindles narrow them even more? Or do i even need them if I have a dropmember since it already narrows width? Looking to run 22's
stunna is offline   Reply With Quote
Old 03-16-2009, 03:10 PM   #40
111stony
Sorry, here is my second attempt.
Front
Rear
Old 03-16-2009, 04:45 PM   #41
see ten
WTB this ad
see ten's Avatar
How close do they bring the rotor in to the lower control arm?
see ten is offline   Reply With Quote
Old 03-16-2009, 05:21 PM   #42
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Subscribed.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-16-2009, 08:50 PM   #43
Ackattack
Ackattack's Avatar
These might be my answer to getting my tires to tuck. I ordered 20x8.5 with 4.25BS and the tires rest on the inner wheel well at or near full dump. I'll have to keep these in mind.
Ackattack is offline   Reply With Quote
Old 03-19-2009, 11:50 AM   #44
coast2coast
coast2coast's Avatar
Custom 68, go ahead and pull the trigger on one of these kits. Then maybe I'll bump into you and get to check it out firsthand.
You're running a wider front wheel with some drop, aren't you? What do you have up front now?
coast2coast is offline   Reply With Quote
Old 03-20-2009, 11:06 AM   #45
Custom 68
Custom 68's Avatar
well if I do it of course you can check it out
currently I have only a 2.5 inch drop with spindles and stock springs so the drop is pretty mild but still looks good. my tires are 275-60-15 all 4 corners. I dont know the back spacing as these were bought many years ago... They are an 8inch wheel and looks to be a pretty deep outer dish and yes I get some rubbing only on "dips" on the road. not bad but I dont like it.
Dave
Old 04-02-2009, 02:52 PM   #46
72BlckButy
Tot Roddin'
72BlckButy's Avatar
bump...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-30-2009, 05:15 PM   #47
71Custom10
71Custom10's Avatar
Has anybody figured out if you can run 15x8 rallys with the modular spindles?
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
