02-23-2009, 11:35 PM | #1 |
WTB this ad
CPP narrowed track width drop spindles...
I got my new issue of Classic Trucks in the mail today and there was an article about CPP's new modular dropped spindles. The article claimed that they allowed the use of larger diameter rotors/calipers (or stockers) as well as narrowed the track width 1" per side and provided 2.5" of drop. I searched their site and the info I saw claimed that they provided 2" of drop and narrowed the track width 1 1/8" per side. I'm generally 100% ECE when it comes to drop parts but the possibility of a narowed track width for $299 sounds interesting...Anyone tried these yet? Opinions? Comments??
http://www.classicperform.com/NewPro...op_Spindle.htm |
02-24-2009, 01:18 AM | #3 | |
Re: CPP narrowed track width drop spindles...
02-24-2009, 02:00 AM | #4 |
Junior Member
I have them on my 67. They did pull the wheels in about 1" per side. They are a 2" drop spindle (not 2.5"). I got the standard size rotors (not the big brake setup). They would not work with my old 5x8 rallys and my buddy had to grind a little on the A-arms.
02-24-2009, 02:11 AM | #5 |
BlahBlahBlah
I plan on getting a set of these...why wouldnt they work with your 15x8 rallys?
02-24-2009, 06:52 AM | #6 |
WTB this ad
I'm considering trying to get a 9.5" wide wheel under the front of my next 72 project. Narrowing the track width would help cut down on the amount of offset I would need. In theory, I could get a 9.5" wheel under there with about 4.5" of BS instead of 5.5" of BS (which is what I was figuring/guessing to begin with). I'm not sure how large of a diameter wheel I'd need to keep all the control arm clearances issues at bay...I'm guessing a minimum of 17"??
I also prefer to buy from ECE, but their spindles don't narrow the track width...But I do know that theirs will fit and they have excellent customer service. |
02-24-2009, 07:20 AM | #7 | |
67-72 parts collector,…
I'm interested in the answer to this question also.
02-24-2009, 08:43 AM | #8 |
Happy to be here
see ten- It might be a good idea to contact CPP and ask them. They have some very good product, but not so much on customer service. Read the review forum for more details on that subject.
Please keep us informed as several of us hav been considering that as an option.
02-24-2009, 10:10 AM | #9 |
I had 18's on my 74 (18x8 w/5.25"BS using 3" spindles) & they still rubbed the a-arm. The only difference diameter makes is where the rim contacts the a-arm. Smaller diameter rims contact the a-arm closer to the BJ where a larger diameter will contact the a-arm closer to the shock mount.
02-24-2009, 11:52 AM | #10 |
Junior Member
02-24-2009, 01:34 PM | #11 |
To elaborate, this is a common problem for all drop spindles; not just CPP's.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-24-2009 at 01:35 PM. |
02-24-2009, 04:13 PM | #12 |
I have these spindles with their big brakes. I should have them mounted in the next few days. I can measure track width & try to post a couple of pictures if it would by helpful.
02-24-2009, 06:17 PM | #13 | |
WTB this ad
On a side note...Are these the same spindles/brakes that there was a thread about a while back? It seems like there was a thread checking interest in larger brakes for our pickups and it was being monitered(followed up on? commented on, )by someone from CPP? |
02-24-2009, 06:38 PM | #14 | |
I started a 'cheap big-brake' thread about a system I was trying to convince a manufacturer to build for us DIY truck guys. CPP had no interest in this idea when I originally contacted them about it but did post info later in the thread that they were soon going to market their brand 13" brake 'kit'. CPP is marketing theirs. The guys that built my DIY style set-up aren't marketing them but seem to have the customer service routine down pat vs. what I've read about CPP in the review forum.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-24-2009 at 06:42 PM. |
02-24-2009, 06:43 PM | #15 |
WTB this ad
Hmmm...I wonder if the difference lies in that your spindles are 3" and mine are 2.5"? I'm also curious as to if their 2" drop spindle would change things much either... My desire to see a driveable truck with a static drop and 9.5" wide wheels on the front may just be a pipe dream I'm afraid!
Who were using for your big brake kit? Gotta link handy to the thread? Thanks Last edited by see ten; 02-24-2009 at 06:44 PM. |
02-24-2009, 07:43 PM | #16 |
Wide n'Low
Just to add to the mix,
I just installed a set of McGauhys Classic 2.5 in Drop Spindles and using a 15x7 Rallye it rubs just a tad on the lower A-arm. To give you an idea of where it rubs, when I first put them on it scrubbed of the balance weight that was on the inside lip.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
02-24-2009, 08:20 PM | #17 | |
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-24-2009, 09:24 PM | #18 |
BlahBlahBlah
It sounds like these may not work for me either. 15x8 wheel with 4.25 inch backspacing will probably rub.
02-25-2009, 04:06 PM | #19 |
I don't have a reference with me, but I always kept this in mind....
All spindle drops, 2" drop may not effect the wheel at all. 2 1/2" require 17" wheel minimum. 3" you are on your own, not sure when or where the arm and wheel will meet. |
02-25-2009, 06:05 PM | #20 |
WTB this ad
02-25-2009, 08:52 PM | #21 | |
I'm using those exact same van ralleys on the front of my 74 now & it has 3" Bell Tech spindles. It did require trimming the a-arm lip near the ball-joint & will still contact the wheel weights before full lock turns. It does not rub making normal left or right hand turns. Those same Bell Tech spindles were on the truck when I had my 18" TT2's on there. 8" wide w/5.25" back-spacing & they rubbed the a-arm before full lock turns. The larger diameter rim required trimming the lip further up the a-arm because they contacted the arm in a different location. Again, it depends on the back spacing of the wheel.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-25-2009 at 08:53 PM. |
02-26-2009, 04:50 PM | #22 |
Junior Member
I put my Intro wheels on (20x8 5" backspace front) and have no rubbing problems. I also have a set of rally wheels (15x7 & 15x8) that I was planning on running. I did't install the brakes/suspension, but if you guys need me to check w/rallys or pics let me know!
02-26-2009, 07:03 PM | #23 |
WTB this ad
Could we have some pics please!!
02-26-2009, 09:32 PM | #24 |
Pics pics please.
02-27-2009, 01:54 AM | #25 |
Junior Member
Just got my issue of Classic Truck mag-Full article on this setup with mult. pics!!!
