04-09-2009, 03:08 PM | #26 |
Re: 1972 2WD Blazer Lks Dcvn Build
Cool just LMK? I have some cheapy ones from AIM for an 88-99 truck and they are powder coated, so I guess I just ASS U ME'd the ECE ones would have been done too, wonder why they aren't?
04-09-2009, 03:23 PM | #27 |
chevy truck fan
when i bought my mcgughy's (??)spindles they were not coated with anything as well. i don't thing manufacture's do any of that so the user is free to do what ever they want.... i guess. it is a interesting proposition for a manufacturer though???
keep up the good work!! |
04-09-2009, 04:32 PM | #28 |
OK, I just figured a powder coat would keep the parts looking good, but a color change makes sense?
BTW rodstored-72, thanks for the parts, can't wait to get to use them! |
04-14-2009, 10:00 AM | #29 |
OK more progress with picts!! I installed the upper rear shock relocators and the lowered rear springs. I know you eastern guys will be upset but I didn't need a cutting torch or anything, just a shot of WD40 and a rachet! She came apart nicely and back to gether with a little wire brush clean up and black paint for good measure! Enjoy!!
Up first out with the old rear upper shock mount, grind an X into rivet, air chisel out and TADAH out it comes. the rest of the picts are the new going in and a comparison between the old OE spring and the new rear lowered spring. |
04-14-2009, 10:16 AM | #30 |
These picts are some profile picts after the lowered springs installed. I didn't do the bottom rear shock mounts as the Dana 60 that is in there now will not stay. I hope to pick up the Burb I am getting for the 5-lug donor stuff (I hope to build the Burb as a 4X4 in the future, but for now it donated it's 5-lug suspension to the Blazer).
06-11-2009, 07:46 AM | #31 |
UPDATE! This was on page 7 so I am providing a bump with new info...
Mike just picked up a 2wd Burb that he is going to swap over to 4x4 sooooo The 5 lug stuff will be swapped over to the 2wd Blazer - Mike is still looking for a posi rear though (I think)... Also - another change to note - the rears will now have Glock's Brackets with the 93-97 rear Camaro disc brakes - |
06-11-2009, 02:11 PM | #32 |
Under Construction
waiting to see this come together....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-31-2009, 01:55 AM | #33 |
Well, I am ashamed to say I have not put a lot of love into the Blazer as of late. I sillily (is that a word? ) anyways I took on a quicky fix up a car for my niece project and it is still here! I have done everything to this thing, 94 Camaro, new front and rear suspension, brakes, bearing etc, etc. Tuned on the 3.4 (new DIS coils, plugs, wires, belts hoses, computer) New trans filter, new cat, etc, etc plus a newer interior out of a 98 Camaro as this one was not 100%. Anyways, I had to pull the top of the manifold off last night to replace the injectors, SO I finally gave the Blazer some love, amazing what I can get done in just a few hours if I get a chance to DO IT!
Here's the picts, I think they are worth a few thousand words!! The 5-lug rear is in for good now and the shock reloators are in upper and lower. I put new axle bearings and seals in it as well. The rear is done with the exception that I want to be sure I have the brake brackets in right before I tighten them down, can anyone verify this is correct?? I also need to get the calipers and rotors but that is easy enough. As you can see the highest point in the rear fender arch is 28" so it is fairly low but not crazy! |
07-31-2009, 02:01 AM | #34 |
More picts of the Blazer love/WORK finally!!
Here you can see I added the adjustable panhard bar and tossed the worn out stocker! Last edited by 70rs/ss; 07-31-2009 at 02:08 AM. |
07-31-2009, 02:06 AM | #35 |
The last of them!! I just recieved the new 1/2 ton upper and lower balljoints so I can put the 1/2 ton dropped spindles on here probably this weekend. The Camaro is DOA untill the man in the brown truck stops by and that won't be till Monday or Tues I'm sure. I hope to get a lot of work down this weekend we start school Monday (staff) and the kids come back Wed!!
This is it for now, not a lot of progress, but progress none the less!! |
07-31-2009, 06:24 PM | #36 |
Awsome! I'm using 4" springs out back as well; glad to see where I'll prolly be sitting. I've made way less progress on my '72 2wd than this; do the days get shorter as we age or what?
08-03-2009, 08:33 AM | #37 |
Always nice to see progress - I was out of town the past few days - so it was even more of a surprise to come back to ta post update.
Hopefully, somebody can chime in about the rear brake setup... Thanks Mike. |
08-03-2009, 08:54 AM | #38 |
Next project: 1970 K10
Mike - Swap the two pieces around. The horse shoe shaped piece goes on the outside, like this:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-03-2009, 10:13 AM | #39 |
Another thing - some people have had to remove a small amount from the hub of the axles to allow for the 93-97 rotors to seat properly on the axle hubs.
Once you get the rotors - check to see if this will be an issue or not - jholley has the same setup - but he didn't have to clearance the rotors... http://67-72chevytrucks.com/vboard/s...d.php?t=345027 |
08-04-2009, 04:42 AM | #40 |
Somehow I never saw this build thread before. I am eager to see more progress. Keep the pics coming!
08-04-2009, 06:02 PM | #41 |
Being held up a bit due to the 3/4 ton lower A-arms being different than the 1/2 tons. I had a full 3/4 ton 8-lug set-up under this thing, but swapping it back to 5-lug, so I need to locate a set of 1/2 ton lowers and a get on to installing the 454/th350 into it then some other stuff as time allows. I was supposed to be done with this thing by now but other stuff got in the way, so now I am shooting for end of Sept so I need to get busy!!
08-05-2009, 10:08 AM | #42 |
Formerly- 1972SuperCheyenne
Looking good man. keep up the killer work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-29-2009, 12:03 PM | #43 |
OK here we go, I have been swamped and had a death in the family so it has been quite a while since I updated the Blazer build. It is coming along, slowly but surely. I have the front mostly done, 2.5" drop spindles on it with stock height springs, new ball joints, upper and lower, along with a-arm shafts, and inner and outer tie rods. I need to finish up the brakes, front and rear, but you kinda get the idea as far as stance goes. The front looks a little high but the BBC and trans should solve that issue. I pulled the front sheetmetal off to give everything a good blast w/my pressure washer. The frame is in excellent shape with some of the oe black paint still on it!
09-29-2009, 12:05 PM | #44 |
I pressure washed the inner and outer fenders as well, look at those, yeah that is the oe paint, never been touched!!
09-30-2009, 12:39 PM | #45 |
- looks good Mike. Nice to see a few pix of the Blazer...being reborn.
How are the other areas coming along? |
10-14-2009, 01:22 PM | #46 |
This project is no longer happening - but I will be looking for another 2wd Blazer or a well executed converision.
10-14-2009, 01:29 PM | #47 |
Under Construction
ouch.... sorry to hear that...
10-14-2009, 01:38 PM | #48 |
PROJECT 7DEUCE
Bummer to hear that
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-14-2009, 01:46 PM | #49 |
Wow too bad it was really coming along nicely too
70 SWB STEPSIDE 70 BLAZER 09 challenger |
10-14-2009, 02:26 PM | #50 |
No problem - life goes on - just need to keep my eyes open for another one...I will probably wait until Spring at this point - since I will need to pay for storage if I get one now.
