Old 03-25-2009, 10:15 PM   #26
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 1980 Silverado- Door Panel Speaker option?
X4
I am in the same boat as Jeff, 79-80 option only.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-25-2009, 10:38 PM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
The resident experts have spoken. I think it's unanomious that those were unique to late 79 and 80's only.
Different question. I saw a similar cut hole on the rear door panel of a Burb. Was that same speaker box used on Burbs rear doors?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-26-2009, 08:22 AM   #28
JohnC
JohnC's Avatar
I think that would be pretty rare. Would be cool to have that option though.
JohnC is offline   Reply With Quote
Old 03-26-2009, 09:01 AM   #29
Jonboy
Slots go on anything!
Rear passenger door or rear barn door? There was a nice finished 4x10 grille in the rear side panels (and in some Blazers too) but I haven't seen any in the rear doors. I think the sound from a 4x6 would have a hard time travelling all the way from the rear of the cargo area, though.
Old 03-26-2009, 09:02 AM   #30
bigblock73
yeller
bigblock73's Avatar
Ken, I have never seen or heard of them on rear doors of burbs...but who knows, sounds factory from your desctiption. Did it have them on the front doors too?
bigblock73 is offline   Reply With Quote
Old 03-26-2009, 10:16 AM   #31
N2TRUX
Happy to be here
N2TRUX's Avatar
I will have to see if I can find it now. This was a pic of a door panel from a barn door Burb posted on this site recently. In the pic it showed the back side of the door panel with a cut out that looked exactly like the one pictured here.
I was just curious if those boxes might have been used elsewhere. You know, just in case someone was looking for some....
Articles-
"Refining Sierra"
Old 03-26-2009, 10:21 AM   #32
bigblock73
yeller
bigblock73's Avatar
I have 4 extra covers, but no extra mounting brackets.
I am currently restoring my set, and in the process if installing them on my door panels.
Old 03-26-2009, 01:29 PM   #33
EJC78
No Life Like Low Life
EJC78's Avatar
Wow I learn more and more every day I come to this forum. One more question about these door panels. I see two hole's between the arm rest and the speaker. What are those holes for map pocket? or other type of storage compartment? or maybe they are just drilled by PO
Last question is the brushed aluminum inserts 77-80 only because I'm buying a 76 but I'm going to convert to pw pl and I saw a truck with brushed aluminum pw pl I know 76 door panels are different and pw pl werent offered untill 1977.
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 03-26-2009, 02:59 PM   #34
bigblock73
yeller
bigblock73's Avatar
Factory PW/PL were not offered in 73-76 because they would not fit in the doors, this is why the doors were changed in 77, to accomodate them. You might have problems on your 76, depending on what type of pw/pl you are going to install.
Old 03-26-2009, 05:37 PM   #35
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Can he use 77 and newer doors on his 76 though? I dont know how far along his body work is, but it might be benefical to swap doors now if you can, or look into an aftermarket kit if the stock power window setups wont work.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 03-26-2009, 09:50 PM   #36
N2TRUX
Happy to be here
N2TRUX's Avatar
Jeff are you installing them on your 73? Hows that work with the difference in the door panels?
Articles-
"Refining Sierra"
Old 03-26-2009, 10:24 PM   #37
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Just for more trivia, the Gentleman Jim's had speakers in the kick panels. Same speaker cover as the 80 door speakers, just vertical and in the kick panel. The metal of the cab was cut and there was a plastic cup behind them to seal.
Gentleman Jims had AM/FM 8 tracks.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 03-26-2009, 10:27 PM   #38
bigblock73
yeller
bigblock73's Avatar
Ken, I have 77+ doors on my 73, with 77-80 door panels.
When I bought my 73 back in 95, both orig doors had lots of bondo along the bottom...I bought new GM 77+ doors because they were only like $170 each when the 73-76 doors were a astonishing (sarcasm!) $230 or so. was told by the GM parts guy the ONLY diff was the door panels...well I found out the hard way the insides were different too. Wish I could go back in time and get a do-over.
I also bought a fender while I was there...$70!
Old 03-26-2009, 10:28 PM   #39
bigblock73
yeller
bigblock73's Avatar
No kidding huh?? I never knew that.
Go out and take a pic Joe for us to see.
Old 03-27-2009, 12:08 PM   #40
EJC78
EJC78's Avatar
Still no idea what these holes where for?
Eric
1960 Impala ZZ4
Old 03-27-2009, 01:09 PM   #41
Russell
Professional Grade
Russell's Avatar
Mine are capped off:
http://www.zieglerdigital.ca/public/...r/DSC00005.JPG
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-27-2009, 01:15 PM   #42
xs-style
xs-style's Avatar
Russell do you have a larger pic of the whole door pannel? Looks good done that way.
xs-style is offline   Reply With Quote
Old 03-27-2009, 05:28 PM   #43
75sierraclassic
75sierraclassic's Avatar
Looks like those are the stock holes to mount the door pocket.
75sierraclassic is offline   Reply With Quote
Old 03-27-2009, 05:32 PM   #44
EJC78
EJC78's Avatar
Winner winner chicken dinner. I though thats what it was too, after I posted the question of coarse
Eric
1960 Impala ZZ4
Old 07-01-2009, 08:56 PM   #45
Walts_restoration
Sorry for reviving an old thread, but do you have pictures of this setup?
Old 07-01-2009, 10:31 PM   #46
rustyescott
rustyescott's Avatar
for the record my 1980 modelc10 came with those speakers from the factory
extra hole are for map pocket.
rustyescott is offline   Reply With Quote
Old 07-02-2009, 12:17 AM   #47
ElGracho
ElGracho's Avatar
Yep. I posted a thread about them.
http://67-72chevytrucks.com/vboard/s...d.php?t=346787
Joe
Old 07-02-2009, 12:26 AM   #48
Walts_restoration
how cool! i remember that thread. A guy on ck5 wanted to know, ill show him. Thanks!
Old 09-09-2013, 12:55 PM   #49
8lugnutz
8lugnutz's Avatar
I'm looking for a pair of these speaker covers, I haven't been able to locate any yet. If anyone knows of any for sale, I'd sure be interested.
Thanks!
1980 Chevy K10 Silverado --> Build Page
My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper.
8lugnutz is offline   Reply With Quote
Old 09-09-2013, 07:58 PM   #50
79Betty
79Betty's Avatar
Wonder why the homes are there for a map pocket but the speakers have smaller holes. Wouldn't it look cleaner if they used a door panel without map pockets so no extra holes?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
